I am trying to repair an RCA 9" Color TV #E09344 (5/2002)
I need to find a replacement Horz Output Transistor # ST1803DHI Where would be the best place to get one? Most places have a min order price and I only need 1 part.
Guaranteed something else caused this part to fail. You need to post the complete CHASSIS number and your deflection stage troubleshooting.
Was this helpful?
Yes
No
Solution #2
posted on Aug 01, 2007
M0nica L - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
Part number is 198794. Don't sub because it won't work. I agree though. This transistor does not short without a cause. These are a complex set to fix. I assume it's shorted center lead (collector) to one on the other 2 leads? It's normal to measure a short between the 2 outer leads E-B in circuit, and out of circuit normal to read about 25 ohms.
Was this helpful?
Yes
No
Solution #3
Gary10 - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
Your local service shop that does RCA/GE repair may be of assistance, probably charge full list price for it though. Maybe you can shop on line, "Google", for the item or see if E-Bay can supply a working 9" at modest charge? BTW what caused that transistor to blow out, is the LOPT ok?? May want to check out the associated components also, including, do you have drive to the output and proper bias voltages. ...
I bought this tv about a year ago and just now am going to use it and I hooked it up to an external...
(More)
I bought this tv about a year ago and just now am going to use it and I hooked it up to an external antenae, not cable, and I get uhf channels but no vhf channels. I get upper range channels, like 20-66, but I only get a blue screen when I try to get lower range channels, like 2-5-7-9, which are my local channels. The channel search does not grab them and they should be the strongest signal. Can you help?
My Screen just has a blue screen on it. What should I do? What channel will work with this? I...
(More)
My Screen just has a blue screen on it. What should I do? What channel will work with this? I have this TV Connected with a Leapfrog Receiver because I don't hava cable outlet in the kitchen so I have this leapfrog on so its get the TV with the cable Hookup. It was working but somehow I can't get any picture back. Any Ideas.
Thanks
