Question about Panasonic CT-20D11 20" TV
Hissing sound from a Panasonic old TV...Sound and picture are OK. The hissing sound even continues when the MUTE on the Box is ON. The hissing only stops when the MUTE on the TV is ON. I am using the INSIGNIA converter box with an older model Panasonic TV. I have tried different settings on the TV, but nothing helps. Thank you for your considerations!
    Problem Solver:
  • 9 Answers
If you disconnect or power off the converter box does the hiss go away?
If you connect a VCR or DVD player does it still have the hiss? We
need to isolate what source is causing the hiss if it is from the set or
if it is from the converter box.
When you turn the volume control down on the set, does the hiss
reduce in level? If mute stops it, it should reduce in level as you
turn the volume down. Then turn up the sound level control on
the converter box whether its a manual control or by remote. If you
can get a combination that minimizes the hiss and gets higher sound
level from the programming that may cure it.
I am not familiar with the converter box you are using. Are you using
Audio/Video cables from it to the set or is it coming out with coaxial cable
and used on a channel? If you are using a very old set with a tuner input
perhaps the fine tuning is out of adjustment.
Posted on Feb 21, 2009
42PFL9900D/10 Philips LCD Television Hissing Speakers
Check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Pull up older posts. Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts. http://electronicshelponline.blogspot.com/
Mar 13, 2017 | Televison & Video
LCD Television Philips 42PFL9900D/10 Hissing Speakers
Sanyo 25" 10yr old model
is the sound like hissing or like a spark something like?hissing can caused by leaking of high voltage that is dangerous and sould be fix right away
Jul 13, 2011 | Sanyo DS25390 TV
Philips widescreen flat TV model #50PF9966-37 50" plasma, as the tv warms up a loud hissing sounds comes from the back. The hissing sound does not go away when you mute the broadcast sound. when you change...
From what I'm seeing online, the bulbs in the Ambilight may be the culprit. I also read that a firmware upgrade could fix the issue too. There was also a recall of some TV's with that issue, so I would check with Philips about your model and serial number and see if your TV was included in the recall. If you raise enough cain and threaten to never buy from them again, they may get your set fixed for you... even if the warranty is up!
Good luck and please post feedback!
Oct 10, 2010 | Philips Televison & Video
Sony Videoscope TV continuous hissing sound from back of tv and picture seems to be getting worse model kp 46c36 year 1997 once tv has warmed up hissing sound stop but picture still a little iffy
Ur high voltage is dying,the FBT,the flyback transformer is the prob.the big block of plastic with a red wire a with a cap hook to the CRT(crt tv).
Sep 29, 2009 | Televison & Video
No Sound Issues
Hello!
Try the audio out. Run the audio to a receiver to see if the audio is there. If it is, then I'd leave it hooked up to the receiver and save yourself some money. If there is not any low level audio out then I'd fix the set. The only Sony set I've ever seen that was not worth fixing was a 32" model from the early 1990's that had bad picture tubes after only 5 years. I am a Sony factory trained tech. Good Luck!
barneyluc
Oct 13, 2008 | Sony KV-32FS13 TV
Panasonic tv old model
curve picture and auto shutdown
May 10, 2008 | Panasonic CT-20D11 20" TV
Sharp TV Problem
everythin ok that what you hear is work of oscilator from tv set
Feb 04, 2008 | Sharp 27C-240 27" TV
Soundcard
I have found that sometimes this can be interference from your line input. If you don't use the hardware that is plugged into it(if any) when recording TV shows, then mute it in your sound card volume settings
Jan 15, 2008 | Genius Soundmaker Value 5.1
Sanyo TV DS32224
Is the hissing or static sound comming from the speakers or from the back of the set itself?? Need more info please.
Mar 23, 2006 | Sanyo DS27910 27" TV
Panasonic CT-20D11 20" TV Logo
834 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
