Question about GE Profile JTP18 Electric Single Oven
GE mod.JDS27G0P2BG Oven Wont start
Turn oven on , set temp. and immediately kicks off. Neither bake nor broil work. Relay in control panel clicked several times before shutting down. Cannot find control panel. Help !
  • GE Master
  • 3,361 Answers
You have a bad electronic control board.
No repair.
It must be replaced.
Posted on Feb 21, 2009
Broiler comes on on top oven every time you turn bake on and won't go off. Recently replaced temp sensor for similar sporadic problem and worked for a while but now happens every time
Stove will not turn off CHECK
Temperature Control Thermostat
If the oven won't turn off the oven thermostat is often the cause of the problem. The electrical contacts inside the oven thermostat can weld themselves together and then the oven won't turn off. If this happens, turn off power to the entire appliance at the household circuit breaker or fuse. The oven thermostat usually cannot be tested and must be replaced if defective.
Oven Control Board
The oven control board has a set of relays that turn on and off power to the bake and broil circuits according to the customer settings and sensor input. If the oven won't turn off it could be that one of the relays on the oven control board is shorted closed, providing voltage to the heating circuit. It can be dangerous if the oven won't turn off. Don't leave the oven unattended without turning off power to the oven.
Relay board:
Some ovens are equipped with a relay board. This circuit board has several relays which control the switching of electrical current to the oven heat source. If the oven won't turn off it may be that one or more of the relays on the relay board have failed. If this happens replace the relay board. The relays on the board are not sold separately. ALSO CHECK THE BAKE AND BROIL ELEMENT.
: I offer free advice bcuz God is so good!
May 20, 2015 | Ovens
I have a GE double wall oven model JKP45WOA2WW and the oven will not bake or broil. Pulled one of the elemeents and it had continuity. The upper unit has not worked for some time. The lower oven just...
It is possible that there is a bad relay in the control board. This will shut off the power to your burner elements. The control board has a relay for the bake and broil element and one for the common for both. This is usually the one that goes bad. Unfortunately the board will need to be replaced or repaired. The control board will show temperature rise from the sensor but generally it doesn't show the cool down temp. This again is normal from my experience.
Mar 01, 2014 | GE Ovens
My GE Mod #JBP65GS1AD oven recently started acting up. The bake element had a small glowing area 1/4" long even with the oven turned off. We used it a few times, shutting off the power in between...
The way it can be tested is access the back panel so you can get to the oven control(its the clock asm) find a wire terminal on the clock marked as BA for bake and use a volt meter and see if 120 vac is coming from that terminal when the oven is off. The wire must be removed from that terminal so you not getting back feed and has isolated the test just to that. IF it has 120 vac or actually and voltage higher than about 5 vac when the oven is supposed to off the relay board (aka clock) is bad. UNPLUG OR TURN OFF BREAKER TILL WIRE IS OFF OF BA AND READY TO TEST then restore power make sure its marked as BA their is another marked BR thats for the broil element.
Good luck, i hope this helps
Gene
Aug 01, 2011 | GE Ovens
JKP86-27 neither heating element (broil or bake) is working. Other controls and microwave work fine.
having the same problem, microwave works however oven does not heat up. The controls work, I can set the temp and bake, the fan turns on but the oven does not heat.
Nov 25, 2010 | GE JKP86 Electric Double Oven
GE profile lower oven does not turn off...maintains low heat with the convection fan on for several hours.. When i turn oven back on and then off it stops...but the problem continues to happen periodically
Oven Control Board
Relay board:
Sep 12, 2009 | GE Ovens
Oven flashes F2 and beeps in the middle of baking or broiling something. Our oven is all electric and recently whenever we start to broil or bake something, after a little while it will shut off and the...
HI. an F-2 during a baking cycle is the result of an out of control oven temp that has reached Temperatures above 615F-630F
If this actual over temperature condition occurred, Look for welded relay contacts on bake or broil relays. If this happens, replace oven control (also called clock or ERC).
If no over temperature condition occurred, Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective.
Remember: Oven control (ERC) measures resistance of sensor circuit , not actual oven temperature.
Aug 04, 2009 | GE Ovens
JTP18WD01WW no broli, no bake panel works
my wife has arthitis in her hands and the touch screen does not work when she touches it . otherwise it works fine when i use it . is this a body temp problem .
Nov 04, 2008 | GE Profile JTP18 Electric Single Oven
Thermador double oven / Bake wont work /FC code flashed once
I found I have this exact problem. Same bake preheat issue: I can bake if I set broil first. However, the oven doesn't work if I press bake first. The control board has already been replaced a couple times over the years. Is this another replacement??
Aug 30, 2008 | Thermador SC272T Electric Double Oven
GE JRS04BOW3BB Will not turn on.
turn the broil on high by itself wait a couple min. and see if it comes on. if it does the your bake element needs to be replaced or you may just have a burned wire where the bake element plugs in. just remember to turn the breaker off to the oven before trying to pull out the element
Nov 25, 2007 | GE JRS04 Electric Single Oven
GE Profile JTP18 Electric Single Oven Logo
225 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
