Question about IBM ThinkPad R51 Notebook
R51 Thinkpad Monitor Problems
I have a 2003 or 2004 R51 Thinkpad. My monitor has started cutting out where I can see the screen for a couple seconds and then black. The power is still on and I can kind of see the activity on the screen, but it's pretty much blacked out. It's like my screen is burned out or something. Is there anything I can do? Can I get a replacement "bulb" for lack of a better word? Thanks, Morgan
  • matty88 Mar 30, 2009
    not sure if I have an inverter problem or just a backlight bulb issue.
    Since I can "see" the very very dim image on the screen if I look hard, and since the VGA plug works fine to drive an external monitor... I am suspicious that all I need is the replacement bulb--- a ten dollar item.
    Question is.... can this be done by me? And is there a cookbook out there I could follow? And who is the best vendor to use to order said replacement bulb?
    Thx
    M
  • 38 Answers
To answer your question Morgan, yes you can get a new LCD display for your laptop! Typically people sell the entire assembly which is the screen, backlight, display cable. It then fits into the thin plastic casing around your current screen. They are actually pretty easy to replace the problem is you oftentimes have to remove the computers keyboard, and other pieces of plastic on the top that might be in the way. Also there are usually anchoring screws on the bottom that have to be removed as well. There should be one little teeny tiny cable you have to pull out that connects to the mainboard, and then reconnect with the new display. Try this website if you want to order a new one their price is only $120 (which is great for a new LCD screen).
http://www.blisscomputers.net/servlet/the-44892/IBM-R51-THINKPAD-LAPTOP/Detail
Posted on Mar 05, 2009
Thinkpad R51 will not boot
Try remove ALL media DVD.CD,USB,etc. Shut down, unplug, remove battery, plug in, reboot. Do you get anything on the monitor? Can you access the restore/recovery software? Open the Memory bay and reseat the Memory, open the HDD bay reseat the HDD, Reboot. If no change remove HDD, test, replace if necessary. Have you changed the CMOS battery?,
Jan 18, 2013 | IBM ThinkPad R51 Notebook
My Lenovo Thinkpad R51 has a fractured screen, any easy fixes?
you can't fix a broken monitor. Contact ebay or the shipper.
Dec 28, 2012 | IBM ThinkPad R51 Notebook
I have a dotted line of one pixel missed as green color in my lenovo thinkpad R51 monitor. how to correct it
Hi
I have that same thinkpad, and recently have problems with the monitor. What I have experience, which may not be the same for you, is that the machine, which I got second hand, has landed on it's left rear corner, and that seems to be where the video stream is emanating from. I still have trouble, as this is a laptop that isn't being supported as it used to be, so when my color is messed up, I have to press down on that area of the keyboard, just above the USB ports, and it fixes it. I usually have to keep this pushed down while I adjust the screen as well. If you need a better fix, it's most likely something you will have to bring to someone to repair.
Best luck, rate and comment please, thank you
Joe
Sep 02, 2011 | Computers & Internet
I have a R51 that when it boots up it only shows a white to gray shade screen
If it is at all possible, connect an external monitor to the computer. All laptops should have a port for an external monitor. If the external monitor works then you screen is most likely bad and needs to be replaced. If the external monitor does not work then your motherboard is probably bad.
May 06, 2011 | IBM ThinkPad R51 Notebook
IBM Thinkpad R51, screen went dark. At the right screen angle, I can see some light from the windows and cursor, but very faint. At that light angle I can maneuver the mouse and click on windows, so all...
The problem
1 The LCD screen is out or
2 The invertor board behind the LCD screen is out or
3 The backlite is out
You have 2 options
1 To use an external monitor for the time or
2 get the laptop fixed by a tech shop
Nov 18, 2010 | IBM ThinkPad R51 Notebook
My R51 thinkpad screen keeps flickering and is quite garbled it blanks out alot and stays black until you hit FN + F7 (the key to switch from laptop screen to desktop screen) in wich case the screen would...
Sounds like the lcd is toast.
Hook the laptop up to an external monitor and see if you get normal video. If you do, chances are it's the lcd. You'll have to replace it.
Jun 19, 2009 | IBM ThinkPad R51 Notebook
Blank Screen
First, confirm that it is the screen itself. Connect the video output to a known working monitor and then power on your Thinkpad. if the known working monitor behaves the same way you can rule out the laptop's monitor as the source of the problem. This may be the BGA, Ball Grid Assembly, leadless soldering problem related to video chips on the motherboard, but first test the monitors.
Apr 15, 2009 | IBM ThinkPad R51 Notebook
IBM Thinkpad Screen won't come on.
Check your drivers, and make sure they are up to date. Also try to hit function F5 to switch your monitor.
Feb 04, 2009 | IBM ThinkPad R51 Notebook
R51 2887 NQ2 Thinkpad (not under warranty) not powering on. The problem appeared 3 months ago for the first time, but going through some forums, the problem got temporarily solved by removing the...
First, the simple things need to be checked. Is the power supply line, from the wall socket to the computer input socket, in good condition. Best test is to try it on a known working Thinkpad or with a multimeter if one is handy.
Second, connect to an outside monitor to rule out faulty laptop monitor. If the known working monitor paired with the R51 works perfectly then you know it is your screen.
Third, does moving or flexing the computer by its base when running exacerbate the problem?
That will get some preliminary data.
Jan 24, 2009 | IBM ThinkPad R51 Notebook
R51 thinkpad display problem
I think the LCD screen is not working properly. The only solution is to replace it.
You can find replacement LCD screens for IBM R51 here:
http://www.piezas.biz/epages/wwwpiezasbiz.sf/en_GB/?ObjectPath=/Shops/demo132390/Products/%22Pantallas%20portatil%22
May 27, 2008 | Lenovo ThinkPad R51
IBM ThinkPad R51 Notebook Logo
957 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
