Question about Xerox WorkCentre PE16 All-In-One Laser Printer
Xerox PE220 scan
How to do scan documen with empy toner in PE220 xerox
  • 34 Answers
You do it by install the driver and then the scanner cd and you have the possibilte to scan via pc
Posted on Sep 16, 2009
3 Suggested Answers
  • 72 Answers
SOURCE: new toner xerox pe220 laser and it prints dark pages now
Make sure the electrodes between the drum unit and the printer is clean. Use a soft cloth or Qtip to clean, maybe slightly moisturized with vodka (not kidding). Vodka is actually perfect for cleaning most stuff that needs cleaning in printers, even the photosensitive layer on the drum if there happen to be dirt spots on it (gentle rubbing with Q-tip, very carefully).
Also clean the corona wire as per instructions in the manual, don't know your particular printer but there is usually some kind of knob on the drum unit that you are supposed to use for this purpose.
This should fix the problem.
Posted on May 21, 2009
SOURCE: Xerox PE220 workcenter shows LSU Error message.
XEROX WORKCENTER PE220 , ITS SHOWING LSU ERROR . ITS NOT PRINTING OR COPYING ANYTHING . PLEASE GIVE SOLUTION
Posted on Jan 24, 2011
My workcenter PE220 Xerox is displaying scanner locked and it is not printing or copying. What do I do?
The manual says to unlock it. You will probably need the same password that you used to lock it.
Mar 23, 2011 | Xerox Phaser 3300mfpv/x Print Copy Scan...
LSU error in XEROX workcentre pe220. What is the
R/sir,
I have a Fax machine of Xerox make model PE220.From BSNL line connectivity is allways out of order.I want to connect FIXED CELLUR TERMINAL (FCT).After conecting machine give dial tone for outgoing calls.and other end caller received a fax tone on their machine when they want to make a call on my machine.But printer is not printing after some LCD diplayed a massage communication error.Kindly GUIDE me for change in settings.
Thanks and regards
PK Jain
(Pennywise)
Dec 15, 2010 | Xerox WorkCentre PE220 Series
Dec 17, 2009 | Xerox Phaser 8500/DN Printer
New toner xerox pe220 laser and it prints dark pages now
May 21, 2009 | Xerox WorkCentre XD130DF Laser Printer
Xerox pe220 cannot copy
i have the same problem too with my pe220. fortunately, i just purchased a new one which i planned to give to it to a relative, and I was able to figure out that the cause of the "function impossible" displayed.
the problem just occured this morning and I have tried downloading and updating the firmware too, clearing the memories, etc but cannot get the copier to work (can't print thru the pc also).
i then borrowed the new toner cartridge of the new pe220 and installed on my old one and i was able to print and copy again. the problem then is due to the chip memory.
the problem now is how to reset the serial eeprom chip in order to reuse the toner cartridge again.
hope this helps.
Feb 24, 2009 | Xerox WorkCentre 220 All-In-One Laser...
I can not scan in xerox pe 220
I found the solution today. First you go to Autralia Fuji Xerox website at http://www.fujixeroxprinters.com.au then select Driver - Xerox WorkCentre PE220. Download the Control Centre and Scan to PC together with WHQL_PE220_2K_Vista_SCAN (scan Driver) and WHQL_PE220_2K_Vista_GDI.zip (GDI Driver). Setup files are in Control Centre and Scan to PC folder. The rest will pop up new hardware found and browse to two other files dor perfect driver.
Hope this help because it's help me today. Thanks to Miss Chin from Pineaple Computer Store One Utama Malaysia.
Nov 01, 2008 | Office Equipment & Supplies
Xerox WorkCentre PE16 All-In-One Laser Printer Logo
753 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
