Question about Frigidaire FRS23KF7AB Side by Side Refrigerator
How do I remove the doors?
Hello, I have a fridaire side by side with ice and water in door and I need to move the unit outside of the kitchen to retile the floor. The problem is the doorway is only 32" wide and the refrigerator is approx 36" with the doors on. The solution is to remove the doors in order to move the unit. How do I remove the doors?
  • 117 Answers
Refrigerator side is easy. Remove the top hinge cover and then the hinge. Lift it off the bottom hinge and set it to the side. The freezer side is a little more entailed as it has a water and electric connection. Remove the lower kickplate (Grille) and then you will see a plastic tube coming out the bottom of the hinge. Follow it to the connector and removed it. A little water might come out but it will stop. Next, go to the top hinge and remove the hinge cover. Unplug the electric connection and then remove the top hinge. Lift the door off the bottom hinge sliding the plastic tubing through the hinge...This should do it. If you need further asssistance, we are here.
Eric Campion
Posted on Feb 21, 2009
I moved my GE TFX277PFSB (new in 1994) side by side to my enclosed sun porch 2 years ago when i got a new fridge for the kitchen. Today, I decided to run a water line to it to allow it to make ice again. ...
Make sure the arm on the icemaker is in the down position,if it is up and locked in place the icemaker is off. If it is down and the icemaker is turned on,each time it got cold enough the to cycle the icemaker(usually about a hour) the icemaker started and for 7 years power was sent to the water inlet valve to fill the icemaker and the icemaker side of the water valve is burnt up. The water valve has 1 inlet teh house water supply attaches to and 2 outlets 1 for icemaker and 1 for door dispenser
Aug 07, 2011 | Kitchen Ranges
How do you remove the face plate off of the ice/water controls on the outside of the freezer door? The spring came off the flapper door that covers up the ice delivery hole, nothing has broke, but I need...
Remove the dispenser cover by gently prying starting at the bottom going round and round a little at a time to prevent from breaking it. When it's off the screws will be exposed to access the other components.
Sep 23, 2010 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
GE GSS25 continuely has frost on cube chute preventin cubes from discharging. Have had doors replaced under recall but problem came back.
I had the exact same problem. My neighbor has the same refrigerator, and told me that there is a solenoid in the door, behind the panel where you select between water, crushed or cubed ice. You can carefully remove that panel to expose the solenoid, which is on the right side of the dispenser water line. I have the model GE GSS25. The plunger on the solenoid gets rusty buildup on the outside of it from the moisture and water splashing from the dispenser. You might try wiping the exterior of the solenoid, and working it up and down so that it moves freely. If not, it's a cheap replacement part you can order from GE. The solenoid shuts the trap door which opens when you get ice from the dispenser. If the solenoid plunger does not move freely, then the trap door hangs open, and warm moist air enters the freezer through the ice shute, causing frost.
Sep 16, 2009 | GE GSS25JEMWW Side by Side
Removing fridge door?
Try opening the doors and moving it through the doorway with the doors open? If you have the room twisting the fridge around the doorway with the doors open my work.
Jun 27, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Leaking by freezer door in bottom
your drain line is clogged remove back wall and trow hot water in hole please unplug unit
Apr 05, 2009 | Kenmore 57029 Side by Side Refrigerator
GSS25LGMF WW Will not dispense ICE or Water, lights are on
Hi, I have had a similar situation. In my case the filter needed to be replaced. Otherwise the water solenoid is bad or clogged. And check the water supply valve. Best of luck. , Tim
Feb 13, 2009 | GE GSS25LGM Side by Side Refrigerator
Maytag MCD2257KES ice maker shoot door does not open
Yes, the ice/water unit can be removed from the door to give access to the switch and solenoid that opens the ice door.
Dec 28, 2008 | Maytag MSD2656G Side by Side Refrigerator
Water & Ice dispenser quit on Kenmore 106.9535110
recheck the electical connection at upper frz door hindge sometime a wire could be pushed out but check to see that the control lock was not set by accident
Dec 11, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Can fridge doors be removed easily
If your unit has ice and water in the door, it IS a big deal. The doors cannot be removed without damage to the wiring that runs throught the door for the ice and water dispenser. You should cancel and order a unit that will fit through your doors.
Mar 09, 2008 | Refrigerators
Kitchen aid Supra
At the top left hinge there shuld be a cover over the hinge. Remove that cover and check to see if plug connectors are securly plugged together. Double check the right top wall of the refrigerator section and verify the model # I did not locate info on the model you posted.
Nov 21, 2007 | KitchenAid Superba Architect KSCS25INSS...
Frigidaire FRS23KF7AB Side by Side Refrigerator Logo
150 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
