Question about Garden
Old homelite XL chainsaw pumping bar oil into engine while runnin
Checkvalve in bar oil tank keeps blowing off while running
    Guru:
  • 597 Answers
Check that the oiler hole and the hole in the bar that it pumps into aren't clogged. The sawdust running under the chain and be deposited in the oiler hole in the bar until it plugs it solid. That will keep the oil from havintg a place to go and build up pressure.
Posted on Sep 23, 2009
  • johndogfu465
    johndogfu465 Nov 27, 2012
    I think you could be right on the oiler as of now.. I`ve been tinkerring with the oiler hose and now going to replace it and go from there.. May need carb kit, not sure Ity is A Homelite 49-109 HDC, Homelite brand.. Thank you for the info Jofn
I need to remove the automatic oiler in my homelight chainsaw z3850b
Chainsaw Oil Pump Replacement - Homelite ... - YouTube
? 5:57
https://www.youtube.com/watch?v=8dj0Voh3TTM
Jan 21, 2014 - Uploaded by RepairClinic.com
The most common reason for replacing the oil pump is ... ...Chainsaw Oil Pump Replacement - Homelite Chainsaw Repair (part #309514001) ... spark plug wrench, cord, clutch removaltool, adjustable wrench, needle-nose pliers ... The chainsaw guy shop talk Repair Homelite 150 chainsaw Auto Oiler ...
How to Repair a Homelite XL Chainsaw Oiler - Home Guides
homeguides.sfgate.com > Real Estate Advice > Basic Real Estate Advice
The Homelite XL chain saw is designed to use one tank of oil per each tank of fuel. Fill the oil ... Push the guide bar toward the saw, and remove it and the chain. Clean the ... Automatic Oiler and Oil Line Replacement ..... My Ridevisit'Cars-My
Dec 21, 2015 | Garden
Help! carburetor pulse oiler on homelite xl chainsaw ut-10694-a
there is a breather hole somewhere you need to clean it up so you can find it probly on the cap
Mar 29, 2014 | Garden
Does a homelite chain saw have a crank case youn put oil in homelite xl
Hi, it needs a two cycle mix at a ratio of 25 to 1 in the fuel tank and bar and chain oil in the oil tank. Hope this helps, regards Phil.
May 31, 2011 | Homelite Garden
I have a HOMELITE XL-12 chain saw. Web sites say it takes a mix of oil and gas. But mine has a place to put oil in. Which should I do?.
The mix of oil and gas should be a 32:1 ratio which is 4 oz. of oil to every gallon of gas. I am assuming that what you are seeing is the oil tank for the bar oil. You need to use bar and chain oil for this tank as it is what keeps the chain lubricated. Do not use two cycle oil for the tank marked oil.
Apr 15, 2011 | Homelite Garden
Chain oil tank full, feed channel behind guide plate clear, but no oil going to chain when running. This is a homelite 16.
There should be a oil adjusting screw on the bottom of your saw next to the bar beside the oil tank. Some models actually has the screw inside the tank. Drain the tank to make sure there isn't any debris clogging the hole where the oil feeds to the bar.
One way to check to see if the bar is oiling is:
1. Start the saw
2. Put a board, piece of cardboard or an uncolored old shirt in front of the bar
3. Press the trigger on the saw to allow the chain to circulate around the bar.
4. While keeping constant pressure on the trigger, look to see if there is a vertical line of oil on the piece of material you have placed on front of the bar. If the saw is oiling you will have a vertical line. If not adjust the oil set screw accordingly.
Nov 15, 2010 | Homelite ZR10926 16 Chain Saw
Gas oil mixture
The header says that it is an electric saw which would only require bar oil. A 2-stroke gas engine, however, does require fuel mixed with a modern saw oil at 40:1 ratio plus bar/chain oil in it's own tank as well. Always premix the fuel and oil in a separate can and shake well even before filling the saw. Hope this helps!
May 24, 2010 | Homelite Consumer Products 9.0 Amp, 14 In....
The 330 homelite chain saw bar is not getting oil.
If the pump is a piston type, there must be valves on both sides of the pump to control the flow of oil in one direction. The one in the tank is called is called a 'duck-bill' valve and may be mal-functioning. Can you move the diaphragm by hand to see if it pumps anything? Did you run the engine without the bar and chain attached to make sure the bar oil-ports were not choked up. Oil should ooze out of the engine side port when running. Hope some of this helps!
Apr 10, 2010 | Garden
I have a homelite xl, UT# 10655- the chain oil seems to be leaking and coming out of the exhaust and continues to leak after shutting off the chainsaw. Any ideas on the possible cause?
Your saw is listed as an "XL Chain Saw UT-10655" here:
Homelite/Ryobi.com (authorized parts supplier)
https://www.gardnerinc.com/recons/disclaimer-lg.php - Agree; Choose “Product Line”; “Select OEM” & “Select Catalog” both to “Homelite Consumer Products”. A drop down list appears; self explanatory from here.
The numbers Homelite & Ryobi use do not match the numbers everyone posts. A careful inspection of your saw should find something that matches.
See the "Engine Internals" print. The oiler appears to above the clutch and driven by a pressurized tank. Venting the tank (opening the oil cap) may help help with weeping but only emptying the tank will stop it.
If no oil from engine oiler hole I suspect a failed hose or connection. Use the IPL to inspect and repair as needed.
Oil System Plugged.
  1. Remove the clutch cover, bar, and chain, clean the bar groove, any holes and passages on the rear of the bar (both sides, consider rotating the bar), if equipped with a sprocket nose ensure it rotates easily at least one complete revolution. Clean the saw oiler hole and channel. Insert a blunted, hooked piece of wire through the oil filler hole and pull the hose in the oil tank out. Pay attention to the screen or filter on the free end (clean or replace, difficult to determine serviceability). Start the saw and see if it oils when revved up (oozes down side of saw). If yes reassemble your saw. If no, continue with 2.
  2. Work your way through the linkage (use IPL to identify components and locations) cleaning and replacing any defective parts as you go. Carefully check the hoses for cracks especially at bends and connections. Please take extensive notes & some digital pictures will help during reassembly.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Feb 27, 2010 | Homelite Garden
Garden Logo
1,163 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
