Hoover Nextra HNWF 3137 Front Load All-in-One Washer / Dryer
Problem for Hoover Nextra HNWF 3137 Front Load All-in-One Washer...
Noisy washing machine
By Melissa - usenet poster
I have a Hoover nextra 1600 washer dryer.
It is fine except on the spin cycle there is quite a bit of vibration and
noise. The machine seems to be set level when idle (no play when trying to
rock from side to side or front to back) and is on a vinal floorcovering.
Is there anything I can try, before getting expert help?
Same Problem
Jul 04, 2008
-   The washing machine is very noise only on the spin cycle. Conrete weights seem very well secured - no loose nuts. When rocking the inside drum there is no play but when the machine ramps up in speed during the spin cycles it feel of balance as if there is a pair of shoes inside. What's wrong with it ?-   frarl
Jul 04, 2008
Jul 04, 2008
Best Solution
posted on Aug 01, 2007
Helpful)
Phoebe
Rank: Apprentice
Rating: 0%, 0 votes
Happened to me recently.
I thought the bearings had gone, so called in an engineer. He said that the
concrete weight used to stabilise the machine and reduce vibration had come
loose. He re-connected it, tightened up the nuts and bolts and it's as good
as new.
Neil
Was this helpful?
Yes
No
Solution #2
Helpful)
Peter1
Rank: Apprentice
Rating: 0%, 0 votes
Don't forget to turn off when carrying out any work and unplug it
empty the machine and place your hand inside the drum and turn it
if it rumbles, sounds like the bearings are gone.
you can disconnect the belt, to see if it still makes a noise, thus
disconnecting the motor bearings.
also check for any dents inside the drum, loose coins etc may have gotten
between the drum and the outer drum
coach
Was this helpful?
Yes
No
Solution #3
Not Rated)
LiZzIe
Rank: Apprentice
Rating: 0%, 0 votes
You never said but if it's always been like that, then you need to put
it on a solid surface. That is, if it's on wooden floorboards, you need to
build up a breeze block plinth underneath for example. Not much you can do
with it otherwise apart from ensuring a level surface...
Cheers,
Will.
Was this helpful?
Yes
No
Solution #4
Not Rated)
Cornish
Rank: Apprentice
Rating: 0%, 0 votes
Sounds like the bearings to me. I had the bearings on my Hoover 1100
Washer/Dryer replaced last year at a cost of ??70. It was like a new machine
afterwards.
Was this helpful?
Yes
No
Popular Solutions for Hoover Nextra HNWF 3137
Questions and Unsolved Problems for Hoover Nextra HNWF 3137
Do you recommend Hoover Nextra HNWF 3137 Front Load All-in-One Washer / Dryer?
Answer
Answer
i bought this washing machin and facing drying cloth problem and also machine once start never... (More)
Answer
Option selector buttons pushed back through front panel! How do I get to them? Still appear to be... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Hoover Nextra HNWF 3137...:
Top Washing Machine Experts
Rank: Guru Guru
Solutions: 14846
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Washing Machine Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
