Question about Siemens Washing Machines
Siemens Lady 480 dishwasher does not complete the normal cycle
The needle indicator on my Siemens Lady 480 dishwasher advances normally for about the first fifteen or twenty minutes of operation, then stops advancing and the washer goes into a repetitive mode without stopping. If the needle is moved off its stuck position by turning the knob on the front panel it will resume its advance for a while and then once again get stuck with the washer going into a repetitve mode.
3 Suggested Answers
localwonder
  • 6784 Answers
SOURCE: Frigidaire top load washer won't rinse
this can be two issues. One could be the control knob. there could be a malfunction here. secondly, you may have a faulty water valve assembly. the relay or solenoid may need to be replaced. i would start with the control knob.
Posted on Mar 13, 2009
lancaster5
  • 245 Answers
SOURCE: Kenmore 70 Series Washer Won't advance in the
Bad timer. Try to find a used one if possible, this item is a little expensive.
Posted on Aug 23, 2010
Dell studio 1737 laptop takes about fifteen minutes or more to boot up
Shelisha, may be you have too many programs to start with. That slows you down. Also extensions take time too. Try cleaning up and keep most used. Rest can go into a folder. Clean registry and clutter. I use advanced uninstaller pro. Have you defragmented the hard drive(s).
Mar 22, 2014 | Computers & Internet
Siemens dishwasher has stopped taking in water red light on indicating this problem, I have checked water supply that's ok
Click this link for tips : Inlet valve
Check the voltage to the valve to confirm that the control panel is working,
Jan 24, 2013 | Siemens Dishwashers
2001 Volvo S80 cooling fan runs for about 30 minutes after turning off the car.
This is normal. The fan will run even after the car is shut off until the engine gets below operating temperature. Most vehicles will do the same thing. Although I think thirty minutes is an excessive amount of time. Most could run up to fifteen to twenty minutes. If the car is retaining heat somehow this would cause it to run longer. Happy motoring!!!
Apr 13, 2011 | Volvo S80 Cars & Trucks
Siemens lady dishwasher is getting stuck on
I removed the dishwasher and put fill hose on mains pressure. (30 to 45psi or 2 to 3 bar). Working ok now. May be issue with water pressure switch ?
Mar 23, 2010 | Siemens 24 in. SL84A305UC Built-in...
Siemans lady plus 25 manual needed plz
I was looking for spare-parts for my dish-washer Siemens Lady-Plus 25, bought in 1993 !....and I find your request.
I still have the multi-language "Operating Instructions" manual for it....
Still needing one ?
I can of course send you via e-mail, the english pages of it.
Patrick Huens.
Belgium.
Oct 10, 2008 | Dishwashers
SIEMENS SE64630GB NOT TAKING IN WATER
  • hot water valve selinoid and cold water selinoid valve are magnetily operated valves located in the lower part of the dishwasher that need electricity-----
  • wire loose?
  • kinked supply hoses and
  • my favorite is the valve at the kitchen sink angle stop is lying to you, indicates open but is really still shut (broken valve stem) or it has corroded shut .
Aug 14, 2008 | Siemens 24 in. SE64A630GB Built-In...
Prg3601p oven
I also have this problem Ihave replaced the igniter twice this helps some for a while  I AM GETTNG READY to order my third one. had dealer replace once they had no answer cut lighting time from fifteen to twenty minutes to maybe five
Jul 03, 2008 | Jenn-Air PRG3601P Gas Kitchen Range
Washing Machines Logo
403 people viewed this question
Top Siemens Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Siemens Washing Machine Expert? Answer questions, earn points and help others
