Dishwashers Logo
Posted on Feb 21, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Thermal fuse has blown 2 times
Wirlpool dishwasher model #GU2500XTPB1. have replaced thermal fuse twice, water was left standing in bottom when fuse blew. What may be blowing fuse
Anonymous
Level 3:
President:
  • Master 1,902 Answers
  • Posted on Feb 21, 2009
Anonymous
Master
Level 3:
President:
Answers
1902
Questions
0
Helped
902486
Points
6294
Check for a bad ground wire. Also while you are check the ground check all the other wires to make sure that they are seated properly and nothing has come lose or te wire plastic has come off or rubbed off and grounding itself out
Kenmore 15892100 dishwasher. Could a vent actuator blown the thermal cut out fuse?
A thermal fuse is a safety device for high amperes due to high temp and it will cut out when a short circuit applied and the moisture is one of a short circuit.
Where is the fusible link for my LG dishwasher?
If the dishwasher won't start the thermal fuse might have blown. The thermal fuse helps to prevent damage to the dishwasher by turning off power so that it doesn't overheat. Once blown, the thermal fuse will have to be replaced for the dishwasher to work. The thermal fuse is usually located in the control panel on the control board or mounted to the bottom of the tank behind the lower panel. The thermal fuse can be checked for continuity.
Kitchenaide dishwasher KUDS25SHBS1
I have listed COMMON problems / reasons why a dishwasher won't start..
The thermal fuse might have blown. The thermal fuse helps to prevent damage to the dishwasher by turning off power so that it doesn't overheat. Once blown, the thermal fuse will have to be replaced for the dishwasher to work. The thermal fuse is usually located in the control panel on the control board or mounted to the bottom of the tank behind the lower panel. The thermal fuse can be checked for continuity.
The door switch, or switches, are sometimes called interlock switches. The door switch prevents the dishwasher from running while the door is open. If the dishwasher won't start, the switch or switches might be defective. To access the door switches, remove the control panel or inside door panel - depending on the model. They can be tested for continuity.
If the dishwasher does not start, the door latch assembly might be defective. These are normally made of plastic and cannot be repaired. If the door won't latch and the door latch is broken, replace it.
The main control board provides power to nearly every component of the dishwasher. If the dishwasher won't start the main control board might be defective. You should first check for more common parts. Many times control boards are replaced unnecessarily because the problem was not diagnosed properly.
Rotor wont spin
make this tests and fix it. God bless you
Thermal Fuse
Enter your model number to see parts for your dishwasher.
Help me find my model number
Door Switch
Door Latch
Main Control Board
Touchpad and Control Panel
If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced. On some models the touchpad and control panel are sold together and will need to be replaced at the same time.
Touchpad
Timer
The timer allows power to flow to the proper parts at the proper times. If the dishwasher won't start, the timer might be defective. Keep in mind that timers are often misdiagnosed as the cause of a problem. Check other components first before replacing the timer.
Ariston Dish Washer LSE620A
test this steps and fix it. God bless you
Thermal Fuse
Door Switch
Door Latch
Main Control Board
Touchpad
Timer
Jul 22, 2013 • Dishwashers
No power
test this steps and fix it.God bless you
Thermal Fuse
Door Switch
Door Latch
Main Control Board
Touchpad
Timer
No front panel lights Whirlpool GU2500XTPB1. Power to dishwash is good.
what most likely is going to be the problem is a blown thermal fuse that attaches to the control panel housing. gain access to the control panel and use should see the thermal fuse,the housing for the control board is grey and this part is white.Remove the wires to it and check for contininity on it (ZERO OHMS) using a ohm meter set to a low ohms setting. If it turns out to be good the next thing to check is the switch(s) on the latch asm using the same method to check them as the fuse.BEFORE CHECKING EITHER OF THOSE BE SURE TO DISCONNECT POWER TO THE DISHWASHER
2helpful
2answers
I have water standing in bottom of dish washer and apparently no power though circuit breaker is on...
hello the fuse in the dishwasher may have blown the fuse will be in the power supply
regards
shaun
Have a Whirlpool Quite Partner II DU1145XTPBA 1 1/2 old just stop working no lights will come on at all. There is standing water in the bottom. We have replaced the thermal fuse and still nothing. What...
Re-verify the thermal fuse.
If the new wire that came with the fuse was not used the fuse will blow again.
Check the door switch for continuity.
The power to all parts goes through the door switch first.
Open the wire terminal box and check the incoming power wires for good contact.
The drain pump may have a blockage in it as well.
Jul 31, 2010 • Dishwashers
I have a Kenmore Dishwasher, it appears to go through the cycle, but it will not remove the water from the dishwasher, the dish detergent and water are at the bottom of the dishwasher
If you truly have power and the thermal fuse isnt blown you may need a new impeller. My impeller and the waste chopper went bad when my son left something on a plate. It broke the impeller and bent the chopper. It wasnt cheap but I did it myself. Make sure you replace to old gasket with a new one, supplied in the kit.
Dec 02, 2008 • Dishwashers
Top Dishwashers Experts
Mike Cairns
Mike Cairns
