Question about Canon Cameras
On my Canon EDS 1100 D Digitial camera I was taking a series of pictures when an error appeared on thescreen Err 20 Shooting is not possible due to an error. Turn the camera off 7 on again or re-install the battery. I tried those instructions but still the error appears - How do I fix the error please
    Prodigy:
    An expert who has answered 500 questions.
  • Canon Expert
  • 512 Answers
Error 20 refers to a mechanical malfunction probably a repair shop job.
Posted on Jan 21, 2019
SOURCE:
SOURCE: Please help...I can't take any pictures!
I actually figured out it's the flash that is broken...just wish I could fix it myself!
Posted on Sep 03, 2007
yitzy
  • 12 Answers
SOURCE: Canon EOS 40D - err. 99 while taking photos
update your firmware to 1.0.3 , this will fix your problem
http://web.canon.jp/imaging/eosd/firm-e/eos50d/firmware.html
Posted on Oct 29, 2008
  • 155 Answers
SOURCE: ''err 99'' code appearing fairly often recently on Canon Rebel XT
To isolate the cause of the issue, do the following: -
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert only a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99′ message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99′ message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
3. Reattach your lens.
4. Turn on the camera.
If the “ERR 99′ message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99′ with a different Canon lens attached, then the camera is faulty and should be serviced.
Posted on Mar 19, 2009
  • 47 Answers
SOURCE: I have a Canon EOS, 1000D which I purchased in Feb
I did some digging and found that this error is most often a lens communication error. Are you, by chance using a non-Canon lens?
Try the following:
1. Remove the lens and take a picture without any lens on. If you get an ERR 99, then it is a camera issue and you will need to contact Canon for further troubleshooting or repair (ie. not the lens).
2. If you do not get the error with the lens off, try it with a Canon lens or any other lens. If no error, it is a problem with the original lens.
3. If the error occurs on both lenses, clean the lens contacts both on the lens and the camera (refer to your manual).
Hope this helps.
-Tor
Posted on Nov 21, 2009
  • 94 Answers
SOURCE: Camera won`t shoot
Camera shutter or lens diapharm unit faulty. itss need to replace it
set camera on M mode and change shutter speed to bulb and press shutter button and can you see sensor or not. if you not see sensor and geting err99 then shutter unit is faulty
Posted on Aug 04, 2010
Err 99 message on canon 450d
CANON ERROR 99 1. Turn off the camera. 2. Remove the lens, battery, and CF card. 3. Allow the camera to sit without power for approximately 20 minutes. 4. Insert a fully charged battery, and turn on the camera. 5. Depress the shutter button as you would to take a picture. Does the "ERR 99' message appear? If it does, then the camera should be serviced. If it does not, then please proceed to the next set of steps: 1. Turn off the camera. 2. Insert the CF card. 3. Turn on the camera. 4. Format the CF card in the camera. 5. Depress the shutter button as you would to take a picture. Does the "ERR 99' message appear? If so, then the CF card is the most likely source of the issue. Try using a different card. If the message does not appear, please complete the following steps: 1. Turn off the camera. 2. Clean the lens contacts by gently rubbing them with a pencil eraser or soft cloth. Be careful that you do not let any debris fall into the camera body. 3. Reattach your lens. 4. Turn on the camera. 5. Depress the shutter button as you would to take a picture. If the "ERR 99' message only appears when one particular lens is attached, then that lens should be examined by a service technician. If you see the "ERR 99' with a different Canon lens attached, then the camera should be serviced. http://www.youtube.com/watch?v=WkXyLieNUDI - - - - - VIDEO & VOICE INSTRUSTION. Error 99
Aug 12, 2012 | Canon Cameras
Canon error 99
.1. Turn off the camera.
camera body.
Jun 08, 2010 | Canon Rebel XT / EOS 350D Digital Camera
I HAVE A CANON EDS 20 D IT KEEPS CLICKING ERR
Try removing the batteries and wiping the connectors on the batteries and the connectors in the motordrive with a lens cloth. This worked for me. Sometimes the connectors get dirty and need to be cleaned for a complete connection. Hope this helps.
Apr 23, 2010 | Canon EOS-20D Body only Digital Camera
Canon 450D, ERROR 99 only when flash pops up
Err 99 usually means your lens contacts are dirty either on the lens itself or on the camera.
Does the “ERR 99" message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
Does the “ERR 99" message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
If the “ERR 99" message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99" with a different Canon lens attached, then the camera is faulty and should be serviced.
Mar 31, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Mar 19, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Err CF then Err 99 - Canon Rebel XT / Hitachi 4GB Mircodrive
Not all CF cards are created equally, so yes, it could be your batch of cards. To determine if the error is CF related, and not anything else, try the following steps which are used to diagnose err 99's
Feb 13, 2009 | Canon EOS 30D Body Only Digital Camera
Error 99
Error 99 is an "unspecified" error. It can sometimes be due to poor communication between the lens and camera. Here are some things to try:
1) Turn the camera off. Remove the memory card. Remove the lens. Replace the lens. Turn the camera on. Replace the memory card.
2) If that doesn't fix the problem, try cleaning the contacts on the lens and camera. Turn the camera off and remove the lens. Hold the lens upside down (contacts down) and gently rub the contacts with a clean pencil eraser. Be very careful to ensure that the eraser debris falls on the table and not into the lens. Repeat with the camera body, also holding it upside down (contacts down) as you clean. Replace the lens.
If neither of these work, then you need to send the camera in to Canon for repair.
Dec 16, 2008 | Canon Digital Rebel XT / EOS 350D Digital...
Error 99
Does the “ERR 99′ message appear? If it does, then the camera should be
Does the “ERR 99′ message appear? If so, then the CF card is the most
camera body.
Jun 28, 2008 | Canon EOS-20D Digital Camera with 17-85mm...
Error 99 on 30D Canon
Had this problem before and i found this guide online
camera body.
Feb 22, 2008 | Canon EOS 30D Digital Camera with 18-55mm...
Cameras Logo
276 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
sathish kumar
sathish kumar
Are you a Canon Camera Expert? Answer questions, earn points and help others
