Question about Microsoft Xbox 360 Console
My xbox 360 beeps then freezes to random screens
So when i turn my xbox 360 on it beeps then later freezes and constintly demonstrates this how can i fix it?
  • 27 Answers
This happens a lot which is then i followed by the 3 red rings(red rings of death). is what you need to do is open your'e console, their are help video's on U tube for this. Once your is console open and you have the mother board taken out you need to remove the heat sinks which are on top of the chips. just un-snap the x clamps (on the bottom of the motherboard) and take off the heat sinks. unscrew the tabs on the bottom of the heats sinks and take them out. now take one of the heat sinks to a hardware store and find 8 screws about an inch long that screw into the heat sinks, also buy 16 plastic washers and 8 metal washers that fit onto the screws.also trey to find a BUTANE Torch this will save you from the expensive heatguns and work just as good. the last thing you need is Artic Silver 5 which can be found for 5 bucks on ebay. now once you have this you need to lay your motherboard on a flat imflammable area. light the torch and make shure it is on the LOWEST setting and that the flame is about 3/4 inch long and make a sort on hissing sound. make shure the top ofthe chips are cleaned with a paper towl of the paste. start with the torch about 3 inches over a chip and keep it moving with a sweeping motion after about 30 seconds start to get close but not to close about an inch an a half away and keep making sweeping and circular movements for about 2 min. do not get to close. now move to the next chip and do the same thing. now after ur done with the chips move the torch away about 3inches and keep heat on both chips for another minute and let them cool for a total of 10 to 15 minutes. once they are cool to the touch clean off the metal parts of the chips with alcohol (I preffer acitone too) make shure they have a mirror like finish and put a very little glob of the artic silver on the metal chips and evenly flaten it out till it covers them evenly, make shure to apply enough! ( i used the side of a allen wrench, its less messy). now on the bottom of both heat sinks, clean them off with acitone or alcohol and scrub them very firmly to get off the grime from the paste. now put one plastic washer on each screw and insert them through the bottom of the holes surrounding the chips flip the mother board over and put the other 8 plastic washers on the screws and on top of these put on the 8 metal washers. then put the heat sinks on and tighten them down. once you put the mother board in the metal casing, plug it in(dont fully essmble it yet) now test out your xbox by pressing the little button on the ring of lights board and let it boot up a usual. If it works then ur done, but if 3 red lights start blinking or two red light start blinking you need to ajust the 8 screws. through the 8 holes in the bottom of the metal casing stick a small srewdriver in there and make shure they are all snug but not to tight and then loosin each one about an 1/8 of a turn till there just a little loose. keep testing and adjusting the screws till it boots up with the green lights.
16 platic washers
8 metal washers(make shure all the washers fit snuggly around the screws and are very thin)
8 screws about an inch long that fit heat sinks
Butane blow torch, just a small one will do
small torx wrench kit. big and small flat and phillips head screwdrivers
Posted on Feb 21, 2009
Xbox 360 will randomly freeze and the screen will get pixely in some place and random colors appear on screen.
Let me run through how you can fix the freezing problem:
The reason it happens is because of heat build up internally and as the heat builds up the 2 main chips called the GPU and the CPU which are connected by some thin soldering snap off and then you get the freezing up.
You can fix it by sending it in and they will repair it for you, this will take about 4 weeks and cost $140.
The other way you can fix it is with a good Xbox 360 Repair guide and this site will give you a list of the best ones HERE.
I hope this helps and please rate this so it can help others.
Jan 25, 2011 | Microsoft Xbox 360 Console
Xbox 360 Elite keeps freezing up
random freezes during game can be result of playing black ops fallout series oblivion or poor placement for fan of the 360 (when in doubt unplug and replug cords in 360 do not move 360 or unplug while its on)
Jan 15, 2011 | Microsoft Xbox 360 Elite Console
When i play a game on my xbox 360 the screen will freeze at a random time, sometimes half way through the game, sometimes when i turn the xbox on, sometimes when the game is loading. it makes a strange...
This is a problem with the gpu (graphics chip) the console will need stripping down and new thermal paste applied or the motherboard needs re-balling. sorry but there is no real quick fix for this.
Hope this helps.
Jan 15, 2010 | Microsoft Xbox 360 Console
Shuts off randomly.
do red lights show up? if so look up red light errors ten ask about a fix for that specific error.
Nov 28, 2009 | Microsoft Xbox 360 Console
Fallout 3 xbox 360 freeze
If your playing on a disk clean the disk with clean cotton or a clean cotton clothe and the disk reader with a vacuum with brush head. Installing it on a hard disk would also sometimes prevent the game from frequently freezing. Freezing randomly or at a certain scene is a glitch on the game. Hopefully it will be patched soon.
Sep 29, 2009 | Microsoft Xbox 360 Console
Xbox 360 Freezes Up With Lines Across Screen And Funny Noises
I had the same problem, i tried the towle trick "As seen on Youtube" nothing works, if I were you I would get ready to ship it off to Microsoft and let them fix it.
Jul 04, 2009 | Microsoft Xbox 360 Console
Xbox 360 Freezing Problems
Shutting off the Xbox corrupted the Hard Drive... Have you ever got a Live System Update? You can also reset your Xbox without shutting it off using the controller. You probably have the Three Red Rings of Death... Go to this...
Nov 29, 2008 | Microsoft Xbox 360 Console
You might check out the Informative article to fix the freezes problem as the articlegives the information about a DIY guide, (though I don't remember thename of the site) but you can check the article from
Oct 16, 2008 | Microsoft Xbox 360 Console
Xbox 360 freezes
There are some recalls on this unit. Call microsoft for help.
Dec 13, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
2,470 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
