Why I want to set my laptop back to Factory settings...because I can't do anything else on it. All I can do is, put in a pass word once it is on, then the Windows Repair Dialogue box appears, saying windows trying to fix problem. But then it's saying and showing window's is unable to fix problem.....etc etc etc. Hence Why I want to set it back to Factory Default settings, but I can't because I need password, which I can't remember what it is.
Step 1:
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer Windows Advanced Options Menu Please select an option: Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode Start Windows Normally
Reboot
Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice select safe mode with command prompt Click start run type cmd press Enter black screen should open DOS mode this will vary depending on your operating system type in net user username For eg. If you want to change administrator password , type net user Administrator It will prompt you to enter the new password. Enter the new password and the password is changed http://wiki.ljackson.us/Control_Userpasswords2 if this fails you will need to Select safe mode with networking to download you could download all of these or just one save them to a usb drive for later use if one fails to remove the password Windows Password Recovery Basic http://majorgeeks.com/CmosPwd_d239.html A CMOS BIOS password recovery tool Editors note: This tool should only be used by experienced computer users. Please see the enclosed read me if you would like to run it from Windows. Failure to follow instructions (from Windows) will cause your anti-virus to flag this as a virus. http://majorgeeks.com/Dr._Freeware_System_Utilities_d6416.html Dr.Freeware System Utilities which includes data recovery software, data backup, password reset tools for Windows helps you to maintain your system. Dr.Freeware is freeware, you can download and use it for free. http://download.cnet.com/lazesoft-recover-my-password/3000-18501_4-10973339.html Lazesoft Recover My Password Home Edition is a very easy to use Windows password recovery freeware
http://download.cnet.com/password-cracker/3000-2092_4-10226556.html password cracker free
SOURCE: I got an Aspire One netbook from Acer. I had
go tot Start->All Progs->Accessories->System Tools->restore. and restore the notebook to the earliest date (shown in bold numerals) possible.
SOURCE: I have an acer 5315-2153,
You do know you can only re-install the OS if it is on your hard/ssd drive in the first place and only certain models have this function.
Have you tried while in Windows, to use the Start Menu, find Acer on the All Programs list, and locate the recovery utility? I have an Acer laptop - an Aspire - and had to do exactly that. I used the built-in recovery routine on the Acer Laptop and was able to rebuild my laptop to the condition of when it just came out of the box, brand new.It will delete all your installations since you got it, applications and documents and photos, etc., will be gone, but your laptop will function as if brand new. Good luck with it. -a.
A week ago, I didn't remember my Windows account password. At last, my workmate Brandon advise using Windows Password Seeker. This helpful tool help me get back into windows successfully. You can Search windows password seeker or check out their website: http://www.passwordseeker.com/howtouse.html
SOURCE: how to reset acer laptop to factory setting without cd or password
You can remove or change the Window's User or administrator's password. You need access to a computer with Internet access to download the Hiren's Boot CD and burn it onto a CD. Then insert this CD into the laptop/computer and boot up the laptop/computer with the Hiren's CD and follow the instructions. There are very useful utilities CD and it a Linux boot CD which contains quite a lot of Utility programs including a password removal program. Click on one of these links to download HIREN'S BOOTCD :- http://www.hirensbootcd.net/ http://67.20.82.163/
Unfortunately, there is no way to recover a lost or forgotten password from a router or access point; you will need to reset the device to factory defaults. However, once the device is reset to factory defaults, you can use the default username ("admin") and password (either "password" or "1234" depending on your router) to reconfigure your router settings.
or
if there is a small hole in the front or back of the router push a hair pin in to reset to factory settings
hope this helps
