FixYa.com
Tags:
RCA VR612HF VCR
RCA vcr problem
By Kim1 - usenet poster
I have an RCA vr612hf that's about 9 months old and has been played
very little. This afternoon while watching a movie some video noise
began to appear. By the end of the second film, it became unwatchable.
Tracking has no effect nor does swapping cables or running it through
the second TV. I ran a dry head cleaner through it (once) but still no
improvement. It's still under partial warranty (parts). Is there
anything else that I can try before taking it to the shop?
ThanxPat
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 01, 2007
Not Rated (0)
Chandler
Chandler - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Sounds like clogged heads. Try that cleaner again. Sometimes it can
take several attempts. Also try scanning the tape forward and back.
That might just do the trick. If it weren't under warranty I'd just
take some head cleaning swabs and alcohol to it.
Stephen
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
Gary10
Gary10 - usenet poster
Rating: 0%, 0 votes
I didn't see the first part of this, but if you are discussing really
dirty heads, window cleaner on a q-tip, touching, not rubbing the tip
onto each head two or three times after loading the tip with cleaner.
Then clean normally. If you don't have a test jig, hand spin the
cylinder several times to get the cleaner out. It does not dry quickly,
so a little bit makes things worse.
This is my last resort and works about half the time. It has fixed cola
to smeared roaches (although roach shells normally break the heads).
Solution #3
Not Rated (0)
Rogers
Rogers - usenet poster
Rating: 0%, 0 votes
Agreed on dry head cleaners. However, see the FAQ.
--- sam : Sci.Electronics.Repair FAQ: #
Coming soon to a computer screen near you: #
Preview of V3.00 (ASCII): #
Solution #4
Not Rated (0)
kioner
kioner - usenet poster
Rating: 0%, 0 votes
In <5vgg5s$@bgtnsc02.worldnet.att.net installed. Found out q-tips and ethyl don't get it!
Pat...Just wants to watch "The Rock"
Solution #5
Not Rated (0)
Odud
Odud - usenet poster
Rating: 0%, 0 votes
I don't like those "dry" head cleaners for two reasons. You still aren't
sure if the heads are just dirty after using it (did it work or not?) and
more importantly, they are abrasive. They are no friend to the video heads
on your machine. Get it cleaned professionally would be the best advice.
Solution #6
Not Rated (0)
Reynolds
Reynolds - usenet poster
Rating: 0%, 0 votes
It sounds like the video heads are clogged. I don't know how your warranty
works, I would check it first to see if you can get it serviced under
warranty. If not, it probably just needs a good cleaning. Cleaning will
take care of it 9 out of 10 times. Still, could have a problem somewhere in
the head amp circuit on through the video circuit, but I doubt that.
Good luck,
Kurt
Can you Help with these VCRs problems?
VCRs
timer recording, more than 1...
I have a Sylvania 6260VF VCR. I... Answer This...
VCRs
I don't know how to set the...
I was unable to set video to... Answer This...
VCRs
no reception from vcr
when I plug the cable wire into... Answer This...
VCRs
When I only want to set the...
I select from the menu the... Answer This...
RCA VR612HF VCR
No sound from dvd running thru...
The set-up is: 1985 curtis... Answer This...
Repair Service
Find VCR Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
