It does not print clear and i want to service it from the screen
SOURCE: Canon IR7105 Photocopier
Use either of paper orientation one for printing and one for photocopying
SOURCE: Looking for photocopier user manual
Ok we Know this Model so are you looking for a User's Manuel or the Service Manuels And Yes we will accept paypal payments for this so yes we can help you with both User's Manuel and Service Manuals which one will you need.
User's Manuel is 45 dollars US
and Serivce Guide is 39 Dollars US.
this Service Guide is a Quicj reference to service Canon Copiers, we are not Aithorized to provide you any more stuff on this
SOURCE: Won't photocopy / warning light flashing /
The paper feed system is worn (rollers, and separation pad). What is happening, is extra sheets are being fed into the machine primarily because the separation unit is not doing it's job properly. So rather than just one page at a time being fed, it is allowing an extra sheet to "creep" in intermittently, causing the jam. And the indicator you are seeing is the "jam" indicator.
SOURCE: White stirkes in canon iR2016 photocopying result
It is either the drum unit or developer unit or transfer roller. if your counter is 150 000 copies change dev unit and transfere roller.
Testimonial: "Thanks and God Bless "
SOURCE: the problem issue the photocopy machine canon
you have the system botton near the display you can stop any work that the machine have,go to copy and cancel the work.
