Question about Epson Stylus RX680 Color All-in-One InkJet Photo Printer
Using printer location
How do identify which paper location I want to print from?
  • 67 Answers
Http://files.support.epson.com/htmldocs/rx680_/rx680_ug/wwhelp/wwhimpl/js/html/wwhelp.htm
Go to this address and the search tab on the right hand side type "select tray" and then look at the"78. Select basic print options."
Good Luck :)
Posted on Feb 21, 2009
Why am I getting double or treble spacing on the printed lines
It could be that the disk located to the left side of the paper feed (when looking inside from front) is soiled with ink.
The disk has tiny lines on it that are read by a sensor like steps so the printer counts the "steps" to work out how far the paper has progressed through the feed. If this is dirty with ink, grease or similar, it will not be read properly and result in the paper feeding further than it should.
This assumes that the issue is printer related however. It could be that your source document/editor is causing the problem by not displaying what you want to print. You can identify if this is the case by printing from some other application like a web browser or similar to see if the spacing still takes place. If it does the printer is the fault... if it doesn't it's your software.
Hope that helps.
Mar 13, 2015 | Epson Stylus Sx445w Inkjet Print Scan 5760...
HOW DO I CHANGE PAPER SIZE FOR PROJECT??
are you asking how to load different size paper? or how to make your printer recognize what type of paper to use now that you are ready to print?
Normally specialty paper can be form fed in the back of printer (depending on what type you have). If you have no problem loading the paper, your program that you've designed your project in should control the print size. Try going to the advance options on the program you're using when you ask it to print. Also, use the print preview to make sure it has the right size paper.
Jul 31, 2011 | HP Office Equipment & Supplies
What do symbols on top mean?
Welcome to Fixya
Half circle symbol means printer is in ready state. The printer control panel is comprised of six lights and two buttons. The lights produce patterns that identify the printer status.
1 Jam light: Indicates that there is a jam in the printer.
2 Toner light: When the print cartridge is low, the Toner light illuminates. When the print cartridge is out of the printer,
the Toner light blinks.
3 Paper out light: Indicates that the printer is out of paper.
4 Attention light: Indicates that the print-cartridge door is open or other errors exist.
5 Ready light: Indicates that the printer is ready to print.
6 Go button and light: Initiates action or indicates status.
7 Cancel button: To cancel the print job that is currently printing, press the Cancel button.
Thank you for using Fixya!
Feb 08, 2011 | HP LaserJet P2015dn Printer
Suddenly a paper got stucked and jammed inside the printer..... So after that we not able to do any operation... its processing no response... please make an immediate solution... because we are using it...
To clear the paper jam, please turn off the printer and it will attempt to clear the jam by itself.
You might see an error code on the printer too which will help you identify the issue.
To remove the paper jam manually, turn off the printer and then remove the paper tray.
Check for paper that is trapped in the same. Also try to access other printer areas where paper travels in the course of printing.
You could remove the ink cartridge go gain access to hidden areas in the printer.
Try to roll the gears and rotate the paper feed mechanism to free up the jam.
If you locate a piece of paper hold it with both hands and attempt to get as large a grip as possible, then slowly pull.
The objective is to not to cause a tear in the paper and pull it out in one smooth motion.
Put the cartridges and paper tray back in it's place.
Switch on the printer and check by printing a test page.
This should resolve the issue for you.
If this doesn't work for you, please comment and let me know, and I will be more than happy to assist you to further resolve your issue.
Thank you.
Jan 12, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
Printer wont print replaced ink pulls paper through and sounds like its printing
Use the HP Print Diagnostic Utility to help you identify and fix common problems when printing.
LINK.
Oct 22, 2010 | HP DeskJet F4280 All In One Printer InkJet
Completely paper jam
To clear the paper jam, please turn off the printer and it will attempt to clear the jam by itself. You might see an error code on the printer too which will help you identify the issue.
You could remove the toner or ink cartridge go gain access to hidden areas in the printer.
Ty to roll the gears and rotate the paper feed mechanism to free up the jam.
Put the toner and paper tray back in it's place.
This should resolve the issue.
Sep 06, 2010 | HP Photosmart C3180 All-In-One InkJet...
Epson ACULASER CX11NF paper Jam error every time I print
you may wanna check if the paper that your using is a laser paper, check the mp tray, reload the paper and check the settings on your computer using thicker needs to match the setting on your driver you may also wanna check if your printer can do a stand alone copy so that we can identify if this a hardware issue or a driver issue.
hope this will help u
May 10, 2010 | Epson ACULASER CX11NF All-In-One Printer
Paper tray?
Two possible solutions;
1) Check the settings in the printer driver for the default tray. The other user could very well have changed them and set tray 1 as the default tray.
2) Check the paper size settings in the paper tray. Pull tray 2 out and check the paper guides. Make sure the paper guide in the front and left of the paper tray are set for the correct media type (letter, legal, etc.)
The printer reads the tabs in the back of the papertray to identify the paper size. If someone moved it while loading paper the printer identifies another paper size and defaults into the tray that has the size of paper required to print.
Hope this solves your problem.
Nov 19, 2008 | HP LaserJet 4100n Printer
Load Noises
If the HP LaserJet series printer is experiencing a grinding or odd noise when printing or on power-up, open the printer and remove the print cartridge. Close the printer door.
If the noise does not recur with the print cartridge removed, replace the print cartridge.
If the noise persists, this may indicate a hardware failure. If possible, isolate and identify the location of the noise and contact a local HP sales and service ofice at the number noted in the product User's Guide . A list of phone numbers can be found at
http://www.hp.com/support .
Feb 15, 2008 | HP LaserJet 1320 Printer
Epson Stylus RX680 Color All-in-One InkJet Photo Printer Logo
29 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
