Downloaded Liberty book app, asked me to sign into homegroup to get books, went to pc settings and there was a homegroup already created because it asked me for the password. tried every password I know or could possibly have set, none of them worked. reaserched on internet, all pages said that first I must create a homepage when I have never done that. please help me
SOURCE: setting up wireless internet connection , my new acer laptop
hi there i have a problem connecting my new acer laptop to the internet..I've tried your suggestion but i can't still connect to the internet..can u help me to connect my new laptop to the internet? is there a program or a disk for me to open the internet connection of my laptop...thanks a lot and i hope u will help me
SOURCE: Dell Inspiron 700m asks for password on startup
You're not going to find out on the web. Click below to check it out.
http://support.dell.com/support/topics/global.aspx/support/dsn/document?c=us&l=en&s=gen&docid=E21A18454B4A6550E030A68F27286358&journalid=5F0C99FE5E99ACCDE040AE0AB6E10E45&Query=cmVzZXQrYmlvcytwYXNzd29yZA==&SystemID=INS_PNT_PM_700M&ServiceTag=&contenttype=-1&os=-1&component=-1&lang=-1&doclang=en&toggle=false
Good luck.
SOURCE: i forgot my bios password
Laptops often do not have a dedicated CMOS battery, but use a hardwired device which you have to unsolder and solder back.
You don't want to do that without some decent experience.
There are two basic kinds of passwords that will be prompted for by the
IBM BIOS, computer and HDD. (You can tell the difference by the icon
prompt).
If this is a HDD password, there are no options for recovery in
the US. Federal laws prohibit possession of the software to access the
secure portion of the disk. The computer passwords are also not able to
be cleared locally.
The unit can be sent to an IBM's maintenance and
support center and they will either
clear the PW or in some cases replace the planar. If you just purchased
the laptop, contact the previous owner for the passwords. If not, then
sending it in for maintenance is your best bet.
SOURCE: I need to create recovery
Hi.
Please follow the steps to create the recovery discs using the HP Recovery Manager.
Click Start>AllPrograms>Recovery Manager.
Select Recovery Manager. This will open Recovery Manager.
Click Advanced Options. If you are using a laptopand operating on battery power alone you must connect to anAC power outlet before you can go to the next step.
Select Recovery disc creation. Click Next. The Recovery Manager will begin creating the necessaryfiles. This may take a while, so be patient until the bar has reached 100%.
Read the table of requirements thatappears. Depending on the type of discs you use, more or less may beneeded; if you use ordinary CDs, Recovery Manager will require more compared tofewer discs if DVDs are used.
Insert your first blank disc, havingmade sure it is fully labeled, such as "Recovery Disc 01" or"Recovery Disc 1 of 2". The optical drive of your computerwill have automatically opened. If not, open manually. Close the optical driveand click Next.
Understand and confirm you want to gothrough with the operation using the type of disc you have inserted by clickingNext.
Wait while Recovery Manager now createsthe first disc. This may take 20-40 minutes as it collects the files,writes the files and verifies the files to disc.
Remove the disc and insert the nextafter the first has been finished after clicking Next. Continue the creation of discs according to thenecessary requirements, up until the last has finished creating files.
Click Next after removing the disc and then Finish to complete the session. Congratulations! You havejust made yourself a set of recovery discs.
Use the recovery discs to recover yourcomputer in case of system instability or failure.
Thanks!!!!!
SOURCE: Had a problem with Toshiba
Power the laptop off. Unplug it. Remove the battery. Turn it over. Open the bottom panels. Look for a small battery. Unplug this battery. Press and hold the power button for 30 seconds. RE-Assemble everything. Turn it back on - hopefully it has cleared the settings and you will be prompted to enter the BIOS.
A. Create App Password in Microsoft Account 1. Open your Microsoft account security settings page by clicking on following link:how that helps good luck.
Open Microsoft Account Security Settings Page
2. You'll see "App passwords" section at the bottom of the page which shows following information:
Some apps and devices don't support security codes. In these cases, you need to create an app password to sign in. 3. Click on "Create a new app password" link and it'll immediately provide you a new password generated randomly.
Now you can use this new password to sign in to a 3rd party mail app or device.
B. Create Application Specific Password in Gmail Account
1. Open your Google account settings page by clicking on following link:
Open Google Account Settings Pag
2. Now click on "Security" tab given in left-side pane. Scroll down on the page and you'll see "Connected applications and sites" section at the bottom of the page.
3. Click on "Manage access" button and it'll open a new page showing following information:Some applications that work outside a browser aren't yet compatible with 2-step verification and cannot ask for verification codes, for example: email programs including Outlook, Apple Mail, or Thunderbird, older Android smartphones. To use these applications, you need to generate an application-specific password. 4. Type any desired name in given text box and click on "Generate password" button.That's it. It'll immediately provide you a new password which can be used in any mail app or device to sign in.PS: If you want to remove or disallow any mail app or device to access your account, you can remove existing app password or revoke access from devices using the same account security settings pages as mentioned in above instructions.
