Pc wont boot after vista update
Downloaded and installed update for vista restarted as instructed. but will not boot tried to reinstall xp or vista but its asking for drivers for dvd rom.
changed memory and hard drive took battery out for bios for 10 mins and put it back so im on default bios settings.
  • Mike Davidson
    Mike Davidson May 11, 2010
    Have you tried a "Safe Mode" Boot?
  • Mike Davidson
    Do you hear the Hard drive spool up?
    President:
  • 2,653 Answers
You need to boot in safe mode then do a Windows System Restore to before you installed the updates. You can try redownloading and installing them and if the problem occurs again, just repeat the process.
Posted on Feb 21, 2009
Why my hp desktop keep turning off error c000021a
this is how to fix your desk top with xp,if you have another os,this may also work,but,be prepared,you may need to reinstall your os,if this works,then immediately download this and run it, SpeedyPC Pro Download ,and then d/l this and buy it to keep your pc running great,http://www.iobit.com/advancedsystemcareper.html , Things You'll Need
  • Windows XP installation CD
Instructions
  1. Last Known Good Configuration
    • 1Restart your HP computer after the blue screen shuts it down.
    • 2 Repeatedly tap "F8" when the HP logo screen appears during bootup. This will load a menu with various boot options to select.
    • 3 Use the arrow keys to select "Last Known Good Configuration" and press "Enter." The system will roll back recent changes and may fix the problem. Continue to the next step if the computer does not successfully boot.
    In Place Upgrade
    • 4 Insert the Windows XP installation CD into your HP computer's disc drive.
    • 5 Restart the computer.
    • 6 Press any key on your keyboard when you see "Press any key to boot from CD..." This will launch the Windows Setup program.
    • 7 Press "Enter" to begin the installation process.
    • 8 Press "F8" to agree to the Windows XP licensing agreement.
    • 9 Highlight your current installation of Windows XP and press "R" to perform a repair installation.
    • 10 Follow the onscreen instructions to complete the repair installation. Your personal data and applications will remain intact, but all Windows updates and service packs will be removed during this process.
Tips & Warnings
  • Back up your data before running a repair installation on your HP computer.
Related Searches
eHow Now Ask online tech support online now Ask online tech support - get your answers in real time!
Get Your Answer
References
  • Photo Credit laptop with blue screen image by dim@dim from Fotolia.com
SpeedyPC Pro Download Advanced SystemCare Free 7 6 5 4 3 Download Review for Windows XP Vista...
May 21, 2014 | HP Computers & Internet
How to reinstall windows XP
If your computer boots up you should be able to reinstall with your xp os disk, click on your cd drive & choose reinstall or new install, after that you'll probably have to go to windows update & update the system, if that does'nt work you may have to go to bios settings & set the cd rom as your boot devise, restart & install that way, after your done be sure to set the bios to thier default settings.
Dec 07, 2010 | Computers & Internet
Hi, I have problem with my login after U upgraded my PC win xp sp3 up to vista it dislpays blue screen. Though I tried to reform it the my computer back to win xp sp 3, but it doesnt work. Do you have...
download killdisk here http://www.killdisk.com/downloadfree.htm burn it to cd and run it on your pc make sure your pc is set to boot from cd/dvd then restart your pc will take about an hour depending on your HDD size follow on screen instructions then wipe the HDD with killdisk then reinstall your xp or vista
Oct 12, 2010 | Dell Dimension 4700 PC Desktop
Would like to install .net frame work on vista, but it does not support, so trying to install xp sp2 over vista which asks to install sata driver for xp support. how should i do?
cause I do not think that you have a floppy disk on the laptop ..try first to run the xp from a boo-table disk ...and the sata driver should be from the first that will be loaded....if this is not working ..try to disconnect the hdd for a few seconds..and boot from the installer disk ...after the computer is loading the first drivers...(this will take about 30 seconds..) plug the hdd again and let the install to continue.. ..it should work ..
anyway ..I believe that this is happening to you just cause you are trying to install xp from a folder downloaded into the computer or from a disk that is not boot-able ..do not try cause it may not let you cause it sees the Vista installation like a newer one ...and consider it an update already ...
So...if you do not have a bootable xp disk ...go to this location ..and download this image file with xp sp2...and than burn it using Nero or any other burner..(except windows one) but by double clicking the file itself and let this action to open the burner...
use a new blank cd ...
you need a utorrent for download...Nero 7 at least for burning ...and this location of the file..
http://thepiratebay.org/torrent/5388204/Windows_Xp_Genuine
if you follow my instruction you will end up with a genuine boot-able copy of xp ...insert it in the optical drive ...and restart ...press F2 for bios..choose the boot order to be CD /DVD first boot device..and save with F10 and restart ..
it will prompt you to press any key to boot from cd ..and go with a clean installation ...When the time will come ....and check for previous installations..just esc for a clean installation and delete and format again the C:/ drive ..
have a good day ..and Good Luck !
do not forget to rate if this is helpful ...
Apr 18, 2010 | Sony VAIO VGN-NS205N/S Laptop
My Fixya expert utility doesn't work. Error
Download and install the .NET Framework from this link : http://www.microsoft.com/downloads/details.aspx?FamilyID=0856EACB-4362-4B0D-8EDD-AAB15C5E04F5&displaylang=en
A quick Google search tells me this error means you are running .NET programs without having it installed. Surf to Windows update and patch .NET layer to your system. Horizons requires at least version 1.1 I think.
Jun 19, 2009 | FixYa Service
Reinstalled xp after Vista . USB port not working
The usb drivers are part of your chipset drivers, so lets try and get this sorted. The reason that they work in Vista, is probably because Vista has added support for your chipset and XP SP2 doesn't.
Try installing XP from scratch. First you need to completely wipe your hard drive. Use the XP boot disc, you need to delete the hard drive partition as well. This way, you will start with a RAW drive.
Set up a new partition, and let the XP disc format the drive with NTFS. Do NOT use quick format. Then let XP copy the files and install.
When XP has installed, get your internet set up, and download XP Service Pack 3 from Microsoft:
http://www.microsoft.com/downloads/details.aspx?FamilyID=5b33b5a8-5e76-401f-be08-1e1555d4f3d4&DisplayLang=en
You will notice that Microsoft have written not to use if updating just one machine. Ignore this. The reason is because this is the FULL Service Pack, hence it being over 300MB.
Once you have SP3 installed, your system will restart. Open Windows Update, make sure you have this set to update all Microsoft products, then download all updates. Restart your system and check if your usb's are working.
If they are still not working, go to the laptop website and download the chipset drivers from there, but make sure you are downloading the drivers for XP. If not, then go to the Chipset manufacturer's website and download from there.
Let me know how you get on
Tim
Dec 19, 2008 | Computers & Internet
I have a toshiba L300 laptop with vista....i re installed that to XP...after that i download bios update (previous version insyde 1.3 v now 1.5v)from toshiba and installed....the setup was successfull......
I solved that problem with unpluging every kind of connectors (Usb..) Shuting completly down. Unplug the powersupply and restart the whole system. After that, go to BIOS and see the SATA Option, set to compatible and not ASHC(or whatever its called). After the BIOS Update some of my BIOS settings were changed.
Dec 07, 2008 | Intel D845GEBV2 Motherboard
Philips SpeechMike Executive V3.2 wont run in Vista
I had trouble initially with the same error message as deedee 222 8 and cannot give exact instructions. Try intalling old version, uninstall and then install upgrade 390 from Philips web site. I had to restart 3 times to get rid of an error messge on boot up but then it worked!
Jun 01, 2008 | Computers & Internet
Regarding operating systems
ya u can if u have a xp cd then try this first restart the pc>and while restarting it press F8 keep pressing it and u can see choose the first boot device select the CD-ROM-and insert the XP-cd >follow the instruction>i think u need to restart 3 to 4 tims>and finally restart the pc>and while turm on u can see two oprating system which is windows vista and xp-select xp
Oct 09, 2007 | Microsoft Windows XP Professional With...
Computers & Internet Logo
52 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
