Question about Samsung SGH-U700 Cellular Phone
The screen goes off when I slide the phone from unlock to open
The phone works but the screen goes off when it's slide open so I can't get to any of my info or write txts etc
    Genius:
  • 1,011 Answers
Dear,
it is most probably the strip problem. get it repaired by an expert repairman. the flip or swap phone have these kind of problem with the passage of times.
regards,
as it will fix the issue so dont forget to rate it
Posted on Feb 21, 2009
Slide finger across wont open
Hi Anonymous,
if sliding your finger across the "slide to unlock" bar won't unlock your iPhone it's possible that your touch screen is (partially) broken.
Try a reboot first: Hold the Power-Button until the "Power off" slider appears. Hopefully you can slide that. If not hold Power and Home-Button for approx. 10 seconds until the phone is off.
If after starting your phone again you can't "slide to unlock" you should see to get a screen replacement.
Mar 04, 2015 | Apple iPhone 4 Black Smartphone
How to unlock the main screen
Locate the Sleep button and press it, once you press that the screen shows up a lock screen and asks Slide to unlock. Slide it and then it unlocks.
Oct 18, 2012 | Sony Ericsson XPERIA X8 Cell Phone
If i have the slide opened the screen and image works ok but if i slide to close the keyboard, the screen goes dark with some glitchy images sometimes and then if i open it again and use the direction keys...
There is nothing wrong with your screen, the problem is from the flex that connects your screen to the phone's main board. This flex must have worn out that's why your screen is not displaying any picture.
The problem is common with flip and slide phones. The flex gets worn out as a result of constant opening and close of the flip or slide phone.
I would urge you to replace the flex and I am assuring you that your screen will display picture again. You might also be lucky to find out that the flex is not well fix, that is, it may have loosed contact.
If you cannot change the flex yourself, maybe you should take the phone to a local repairer within your vicinity, so that the flex can be fixed/replaced.
Take care.
Aug 25, 2010 | Nokia N95 Cellular Phone
How do i unlock my sciphone i9
The SciPhone i9 is not locked to a specific carrier from the factory. That is, it comes from the factory SIM unlocked.
Jan 27, 2010 | Dual Electronics CECT P168 Cellular Phone
My lg voyager touch screen is not reponding at all. i press the screen to unlock and nothing..
You can also unlock it on the side by sliding little slide know down. I have LG Vojager and this always works for me. If the phone opens to the left it will be on left side towards top of the phone. It is the top most button. Hope this helps.
Jan 18, 2010 | LG VOYAGER VX10000 Cellular Phone
Can't get my sciphone to slide to unlock
use a pen and slide it slowly
Mar 21, 2009 | Cell Phones
Cect i9 slide to unlock will not open
THIS WORKED FOR US: Hold down the power button until you see the "CANCEL" icon; tap around the screen until the "CANCEL" button turns blue - this will take you back to the slide feature. MAKE NOTE OF WHERE THIS SPOT IS ON THE SCREEN. Repeat the "cancel-screentap" process to find a 2nd spot in another area of the screen. While on the "slide" screen, draw a line between the 2 spots; when you return again to the "slide" screen, the "slide" should work.
ONCE YOU HAVE OPENED THE PHONE do 2 things:
  1. RECALIBRATE the screen
  2. LENGTHEN the screen saver time-out to something other than the shortest time available.
Hope this works for you - GOOD LUCK!
PS - dunderground posted the following solution in Apr 2009:
"The fastest way is to be on the slide-lock screen & hold the side volume button in the Up position until "Press volume down key to check" comes up onscreen. This may or may not work on all firmware versions on the current i9, but works on most. Make sure to hold the button firmly in the Up position. You will first see the normal volume speaker icon show onscreen and the volume rise, but just keep holding it Up, and eventually you should see the pop-up box noted earlier. The moment you see that pop up onscreen, immediately press the side volume button in the down position. A white calibration screen should now show & you can calibrate the touch screen using the stylus."
Jan 20, 2009 | Dual Electronics CECT P168 Cellular Phone
Samsung SGH-U700 Cellular Phone Logo
67 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
