Question about Frigidaire ATF6000ES Front Load Washer
Frigidaire affinity atf6000es1 - control panel locked
The lights come on but the control panel is "locked". It shows PAU and 55 and eERR, if I try to press any buttons. I beleive my 18 month child initiated this lock out by playing "press buttons"
I have been told to "Disabled door switch to reset board ". How do I do that?
  • 2 more comments
  • thedgs Feb 21, 2009
    I fixed this myself thanks to a solution by Mr JP Fixit and it only took about 3 minutes and saved $100 service call. The problem is the door latch needs to be reset, which requires unplugging it's three idiot proof plastic electrical connections (there are only three and they are all different colors). This has to be done inside the washer big rubber outer seal (the big rubber seal you see as you put clothes in the washer), but it is easy to get to. First remove the outer ring that holds the seal on (the thin metal ring is hidden in the groove and can be pulled out with a flat screw driver. Next remove only the side of the seal closest to the door latch (again only the outer seal needs to be undone). With this done remove the two screws holding the door latch in place. Remove the latch, unplug the three connectors, plug them back in then reassemble everything. When all is back in place hit "cancel" and it should be good to go.
  • mamamarla Feb 21, 2009
    my frididaire front loading washer displays LOC and ERR. I tried to reset the door lock with no luck. Any other thoughts??
  • Anonymous Apr 23, 2009
    Front loading washing machine with ERR LOC
    President:
  • 1,294 Answers
Try buttons "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 3 seconds.
Or press "options & select" till the light goes off.
Works for other machines hope it may for you..............And please rate me if helped
Posted on Mar 26, 2009
  • poutinequeen
    poutinequeen Aug 28, 2012
    Work for my frididaire affinity Thannks
Washer machine is locked
Posted on Oct 15, 2009
ATF8000FS1 washer is stuck in pause. Any suggestions?
Hi friend, thanks for your inquiry!
If your washer continues to display an error code of "PAU" it could be an issue with your door lock but if the door strike is not sitting properly within the latch your washer will continue to provide the error code "PAU". Additionally, if your control panel is registering that the door is closed you may continue to experience the "PAU" code. I would recommend having a professional come and properly diagnosis your washer to prevent any unnecessary part purchases. I hope this is helpful. -OOS
Oct 12, 2014 | Frigidaire Affinity ATF8000FS
I have teh atf6000ES1
Pau? as in end of life? seems that perhaps the control board is speaking in a foreign language? anything happen recently to make it this unhappy?
May 23, 2008 | Frigidaire ATF6000ES Front Load Washer
Fridgidaire affinity washer Pau lights every time hit start
Did you check to see if the water outlet valves (that connect to the washer) are Good, Turned On and water comes out? Anyway you are not getting water into the machine either from that or you have 2 (Hot and Cold) water inlet valves are bad (very rare for both to fail). The fault code is usually "PU", not PAU!
Jul 26, 2014 | Frigidaire Affinity ATF8000FS
Frigidaire washer model ATF6000ES1 door not locking, the door closes, but it's not recognized by control panel.
You are having a problem with the door latch sensor indicating everything is connected correctly. Check to make sure your door is not sagging and then make sure the door latch is not broken or cracked.
Jul 22, 2012 | GE Energy Star WCVH6260F Front Load Washer
Won't start led read pau then 45
Hi!!
The error code 45 means control board communications problem. And Pau shows when the cycle was interrupted, try disconnecting the unit form the wall outlet, wait for about 10 secs. and plug it back in. If this do not clear the error code. Replace Board.
Good Luck!! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Nov 02, 2010 | Frigidaire Affinity ATF7000E Front Load...
Dryer shuts off, no heat, AD code
During normal operation, the display may show: “ad” - dryer is in an auto dry cycle. “dn” - cycle is done in auto dry. “PF” - a power failure to the board has occurred. “Err” - an error has been detected. “LOC” - control lock is activated. “PAU” - cycle has been interrupted.
Jun 18, 2009 | Frigidaire Affinity ATF7000ES Front Load...
Fridgidaire Affinity ATF6000ES1 washing machine
Checked the internet for manuals and found one that had a blowup of the parts sequence. Also found instructions at the manufacturers site for trouble shooting and repair.
Jun 13, 2009 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire Affinity ATF7000E Front Load - shows pau and the number of minutes left
Its an issue with the front door sensor and the motherboard. I had to replace the mechanism since it could no longer work. Cost me 250 and almost 2 years later its happened again
Sep 15, 2008 | Frigidaire Affinity ATF7000E Front Load...
Affinity Washer: Will only display 56...Pau, Err on any button
This was exactly what was wrong with my washer!!!!!!!!!!!!!!!!!!!! Stupid Easy Fix! I would recommend leaving it unplugged until you are ready to undo the plug for the door lock. This was a perfect solution!!
Feb 27, 2007 | Frigidaire Affinity ATF6000ES 3.5 Cu. Ft....
Frigidaire ATF6000ES Front Load Washer Logo
1,384 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
prem mathew
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
