Question about Sony Video Cameras
Transferring to dvd
Hi, I had a Sony Camcorder in the early 90's but have no longer got it. I have some tapes I would like toplay as my children are now in their 20's. How can I transfer them on to dvd's without the old camcorder.
I now have a Sony HD camcorder which is brilliant.
Thanks
Bev Swift
Without knowing the model of your cameras or their tape format I can only suggest using 3- way cables for Video, L & R audio. you can use all RCA connectors Sometimes an S connector (mini 4pin) is available & gives Higher bandwith & quality.
Hope this helps
Jaskaran Singh
Posted on Feb 21, 2009
Can I hook up to the DW 100 Canon burner with my ZR200 to burn mini tapes on DVD?
No. The Canon USA web site says the Canon DW-100 has a USB terminal and works with "USB 2.0 Hi-Speed (with compatible Canon camcorders only)." In other words, the Canon DW-100 burner works only with Canon's USB 2.0 camcorders. I have a Canon ZR200. The ZR200 has Firewire 400 digital video output, not USB 2.0 output. The USB port on the ZR200 is ONLY for still images. Video will not and cannot be output through the USB port on the ZR200. (Page 121 in the ZR200 manual mentions using the USB port on your camcorder for transferring still JPEG images to your computer.) You need a DVD burner with "DV Input" (also called Firewire 400 or IEEE 1394) to hook up your camcorder to burn Mini-DV tapes onto DVD. The Sony VRDMC10 Stand Alone DVD Recorder/Player has DV Input. The ZR200 camcorder did not come with a Firewire cable, but you can buy one at any electronics store or at a cheaper price online. Make sure that you get the right kind of Firewire cable, 4-pin to 4-pin or 4-pin to 6-pin, whatever the DVD burner you choose requires. (Your ZR200 has a 4-pin DV port on the camera's end.) USB 2.0 Hi-Speed (with compatible Canon camcorders only)
Mar 15, 2011 | Canon ZR200 Mini DV Digital Camcorder
How can i convert tapes to dvd
You can connect the Camcorder to the Computer using A/V interface to transfer the recordings to Computer.
Once you transfer the recordings from tape to computer, you can use any burning software to burn the recordings to DVDs.
In order to capture the analog videos, you can use the Windows Movie Maker available in the Computer.
If you need further assistance please click hear to reach me..
HOping a positive thump after your issue is solved.
Jan 13, 2011 | Sony Hi8 CCD-TRV138 Camcorder
I CAN NOT TRANSFER FROM THE CAM TO COMPUTER I HAVE WINDOWS XP PROFESSIONAL AND MY COMPUTER SAYS THAT THE FORMAT ON DVD IS NOT SUPPORTED
There are three ways of transferring the videos from the Camcorder to the Computer. One is by using the Picture Motion Browser Software, other by using the A/V, USB cable after finalizing the disc in the Camcorder and finally using the DVD-ROM Drive in the Computer after finalizing the disc. If you're trying to transfer using the 2nd and 3rd option, the the disc in the Camcorder should be finalized.
Also make sure that the disc is formatted in DVD-Video mode instead of DVD-VR mode. VR mode recorded discs can only be played back using a VR Compatible Software/Player or in the same Camcorder. DVD-Video mode recording will help you in playing the discs in all the Players and DVD Viewing Software.
I always recommend transferring the videos to the Computer using the supplied PMB Software.
Please check transferring steps and information from the link given below:
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&externalId=C409768
Thanks.
KenSolutions
Oct 23, 2010 | Sony Handycam DCR-DVD108 DVD Camcorder
Sony DCR-DVD105 Error message C:13:02
The problem is that DVD disks simply never worked in cameras, that is why Sony no longer make old cameras that use DVD, Hard-Drive cameras have same problems, grab a digital 8 camera (tapes) they do work, and picture is best on tape too.
Jul 10, 2010 | Sony Handycam DCR-DVD105 DVD Camcorder
I donot have software for transferring my video
You will have to buy a capture card to transfer the dv to your computer. Try a Pinnacle made device.
Dec 22, 2009 | E.Digital Sony DCR-TRV265E camcorder Pal
Sony Hi-8 plays new recorded video buy not playback
Are they PAL or NTSC tapes ? They may not be compatible with your new equipment.
Jun 13, 2017 | Sony Handycam CCD-TRV40 Camcorder
Sony Handycam DCR-TRV460E PAL
I don't know about the PAL version, but the NTSC version does. It automatically detects the type of tape and adjusts.
Sep 19, 2007 | Sony Handycam DCR-TRV460 Digital Camcorder
Transferring camcorder tapes to VHS
It depends on what speed these tapes were first recorded on. Maybe the camcorder your trying to use to play them back do not support this tape speed I have seen this in the past. Are these 8-MM or VHS-C tapes.. Also the tapes that were recored, maybe tyhere was something wrong with the tape path and was slightly out of alighnment. I had once a Sony 8-MM camcorder and tapes a lot of stuff and then gave them to someone to watch and they would not play. I tryed the tapes again in my camcorder and they worked great. I got a test tape and tryed it in my camcorder and it turned out the tape path alighnment was off, so i had to rerecord everything I had from one camcorder to DVD so i could fix my camcorder. Good Luck
Mar 26, 2007 | Hitachi VME545 Camcorder
Video Cameras Logo
105 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
