Question about Whirlpool WTW5550S Top Load Washer
Loud clicking while agitating
Whirpool washer wtw5550sq0 makes loud clicking sound while agitating and also tripped the circuit breaker recently
  • Whirlpool Master
  • 3,361 Answers
You may have debris stuck in the pump.
This can cause the clicking sound and also bind the pump causing a circuit overload.
Posted on Feb 21, 2009
My washer is making a loud nosie when agitation starts
That is a normal sound when the transmission shifts from the last spin cycle to go into the agitate cycle. It should make a loud click sound that does not last longer than a second. There is nothing wrong with your washing machine.
Aug 07, 2015 | Kenmore 24032\24036 Top Load Washer
I have a MTW5620TQ1, The other night I turned it on to fill with water & the power shut off, it flipped a Circuit breaker. Now when it is turned on it will not fill with any water, hot or cold. & when the...
Sounds like a bad water pump, and or bad agitator motor if the washer will not spin. Breaker probably tripped due to one of the 2 drawing too much current.
Aug 23, 2013 | Sears Parts Direct Agitator - 8578210
Electric box keeps tripping out when machine turned on
You have a short or overload fault in the washing machine that causes the circuit breaker to trip out and this prevents a possible fire.
Feb 20, 2013 | Computers & Internet
Spin cycle trips house circuit breaker on my GE top loading washer
The very likely reason the breaker trips only on spin is because the tub bearing is locked up on the washer since it is locked up its causing way excessive friction at the motor which causes the breaker to trip.Can you rotate the tub by hand or does it seem really hard to rotate by hand indicating that the tub is ceased up due to the tub bearing??
GENE
Oct 29, 2011 | Washing Machines
Washer keeps blowing fuses
Do you mean the houses circuit breaker? If so, WHEN in the cycle does it blow the circuit breaker? WHEN it trips will tell you what to look at. I.E. If the circuit breaker trips during the fill cycle then it would be the walter inlet valve or the timer in the control panel; if it trips as soon as it is in the agitator cycle - then the motor or transmission; if it trips in the spin cycle - then the drain pump or transmission or control panel.
Jul 15, 2011 | Maytag LSG7806A Front Load Stacked Washer...
Blows circuit breaker
sounds as if there is a short in the starting switch but there is a short somewhere in the controls good luck
Dave
Sep 15, 2009 | Amana ALE331RAW Gas Dryer
Washer filled up but will not agitate or
Does the motor run? May be a tripped circuit breaker on the motor. If motor runs, may be a broken belt.
Jul 27, 2009 | Washing Machines
Whirpool lsq9244eqo fills and drains but does not spin or agitate
It sounds like the agitator gripping teeth are worn out. To check this, take the agitator cap off with a strong knife or flat-head screw driver, pull the cap off and check the plastice teeth and four plastic hooks that grab the teeth. If they are worn out, then you will have to replace the agitator. To replace it, you will see a nut that is between the circlular teeth. Unscrew the nut and pull the agitator up hard.
Jan 12, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer problem
THE SPEED SELECTOR SWITCH MAY BE SHORTED CAUSING THE MOTOR TO TRY AND RUN ON BOTH THE LOW AND HIGH SPEED WINDINGS. THIS WILL PULL TOO MUCH CURRENT AND TRIP THE BREAKER.
THE MOTOR WINDINGS FOR THE HIGH SPEED COULD BE SHORTED CAUSING EXCESSIVE CURRENT DRAW.
Apr 10, 2008 | Kenmore 22422 Top Load Washer
Washer trips circuit breaker
Is washer relatively new? Check circuit breaker for proper size (20 AMPS). Washer must also be on its own circuit. It appears that when the motor starts up it is causing a spike in current (as with any motor), so the breaker is either undersized (Note that if breaker is undersized and you up it to the next size you would also need to replace the wire with the next size up which would be 12/2 with ground), or if you have had your washer a while which I believe is your case the circuit breaker is weakening and is tripping on the current spike. Try swapping out your circuit breaker with a new one and try running the washer again.
Sep 04, 2006 | Maytag LAT2600A Top Load Washer
Whirlpool WTW5550S Top Load Washer Logo
154 people viewed this question
Dan Webster
Dan Webster
Sal De
