Question about Maytag PER5705 Performa Electric Kitchen Range
Can't figure out how to get the oven door unlocked on a Maytag performa electric range.
  • Maytag Master
  • 3,361 Answers
You should be able to take a wire coat hanger.
Snip the long wire off, make a small U-bend on one end.
Insert the u-bend on the left side of the latch at the top of the door.
Fish around until you feel the u-bend overlap the latch.
Press in lightly on the door while using medium pressure to pull the latch open.
The door latch mechanism may need replacing.
Although they do ocassionaly fail to unlatch.
Posted on Feb 21, 2009
How do I clean between the glass on the oven door
carefully tilt door out part way and see if the door lifts off hinges lay on flat surface and remove the screws around edges and perhaps bottom then it will seperate
Mar 28, 2015 | Maytag PER5710 Performa Electric Kitchen...
NEED A WHOLE DOOR FOR MY MAYTAG ELECTRIC RANGE MODEL #MER5750AAW
The door is not available as a entire assambly it is comprised of like 30 individual peices that make up the door, i included this parts breakdown for all the parts on the door.
http://www.searspartsdirect.com/partsdirect/part-model/Maytag-Parts/Range-Parts/Model-MER5750AAW/3048/0124111/X2906094/00005?blt=06&prst=0&shdMod=MER5750AAW
Gene
Aug 03, 2011 | Maytag PER5510 Performa Electric Kitchen...
Gas smell is strong on Maytag Performa when using the oven.........some times?
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or
Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Mar 23, 2011 | Maytag PER5710 Performa Electric Kitchen...
We have a maytag performa electric stove, probabley about 6 years old, and last time we did the self clean on the oven we had a lot of stains that ran down between the inside and outside door panel. This,...
Can anyone please give me the serial number and product number to a 6 year old Maytag Performa glass top stove?? I just broke the ceramic top and need to replace it but don't have a serial number.
Thanks
Liliana.
Dec 12, 2010 | Maytag PER5710 Performa Electric Kitchen...
Maytag MER5765RA oven door won't unlock
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Apr 11, 2010 | Maytag MER5765RAW / MER5765RAQ /...
Maytag Performa Electric Range (PER1510) tripped circuit breaker when immediately following turning the oven on. There was a mild electric burn smell from behind the range. I have left the circuit...
first, un-plug unit and remove rear access cover,it could be a wire with bad insulation that has shorted to the body of the unit,could be an oven/broiler element,could be one of your feed lines to the unit shorted to ground,does it trip brkr w/o anything turned on???you can also isolate the problem that way.good luck
Aug 20, 2009 | Maytag PER5710 Performa Electric Kitchen...
Oven will not unlock
Fault Codes
“Bake” or “Lock” may flash rapidly in the display to alert you if
there is an error or a problem. If “Bake” or “Lock” flash in the
display, press CANCEL pad. If “Bake” or “Lock” continue to
flash, disconnect power to the appliance. Wait a few minutes,
and then reconnect power. If the flashing still continues,
disconnect power to the appliance and call an authorized
servicer.
If this does not work let me know please.
Mar 06, 2008 | Maytag PER5705 Performa Electric Kitchen...
How Do I Use Self Clean Oven Feature?
Kathy - we just figured ours out!! Hit the clean buttton, will light up With "cl n", hit 2nd time and it will start the cleaning. Ours set for 4 hrs! Good luck!! This is for the maytag performance!
May 28, 2007 | Maytag PER5705 Performa Electric Kitchen...
Maytag PER5705 Performa Electric Kitchen Range Logo
192 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
Sal DeAngelo
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
