1. Download the winsamp -package from Blank Frank's site (http://www.veg.nildram.co.uk/remote.htm).
This innovative piece of software allows you to send standard home electronics IR signals using a PC IRDA port.
2. Extract the package onto a bootable DOS floppy disk.
3. Download this IR code file and place it in the same directory as the package above.
This file holds the five necessary IR codes converted to the format
used by Blank Frank's winsamp.exe. Please do not bother Frank with
questions concerning this particular procedure.
4. Boot up your PC from the floppy disk and run winsamp.exe.
If your IRDA port doesn't appear as COM2 you may override this by
using an appropriate command line switch. For example, use COM1 by
running 'winsamp C1'.
5. Press the 'r' key to load up the codes into winsamp.
6. Make sure your DVD player is in standby mode and your IRDA port is within range.
7. Run the IR codes from 1 to 5 by pressing Enter on each corresponding button.
8. Your DVD player should start up and display the text "SUCCESS".
9. Repeat step 7. Your player should return to standby mode.
I want to unlock my Sony DVP-NS55P to play region-free discs. I tried an unlock code from here, with...
(More)
I want to unlock my Sony DVP-NS55P to play region-free discs. I tried an unlock code from here, with no results, although I can apparently now play Region 2 discs. Any recommendations? Thanks
the DVD does not load - It appears to be fine it reads loading for approximately 3-4 minutes - then...
(More)
the DVD does not load - It appears to be fine it reads loading for approximately 3-4 minutes - then the message can not p;lay disc shows in the DVD screen
player only flashes LOADING. Then I'm prompted to clean the possible dirty disk. Player won't even...
(More)
player only flashes LOADING. Then I'm prompted to clean the possible dirty disk. Player won't even accept lazer cleaning disk.Disc door opens alright...however seems to be slow and delayed. Help!
