Question about Yamaha Audio Players & Recorders
Sound Control I have a RX-V661 AV Reciever. How do you control the volume in regards to commercials and regular tv? I will be watching a show at one level but when the commercial comes it blasts you out of your chair. Is there something that can be done to prevent this?
    Problem Solver:
  • 6 Answers
Unfortunately outside of turning down the volume. there isnt anything you can do. the reason that is is because its the networks own volume preferences that cause that. the only way you can fix is it call them and tell em to turn down the damn commercials. lol. sorry
Posted on Feb 21, 2009
I cannot make any changes to my Zone 2 -- cannot change the volume or change the setting from what Zone 1 is on. A blinking symbol that looks like a mushroom appears when you are trying to switch between...
Hi.
Looks like the the unit is locked to region 1.
The Yamaha receiver you listed is region free, therefore I assume you are talking about a different unit, in that case give model please.
If you have the problem with a Yamaha RX-V661, then simply disconnect power cord for ten minutes. And disconnect from power all devices connected to the receiver.
This should reset the system.
Let me know in case it does not work.
Regards.
Nov 17, 2009 | Yamaha RX-V661 Receiver
System shuts off when the volume is moderate to high, now the system shut off and will not turn back on.
unplug the reciever for at least 15 minutes. then replug in all of your speakers making sure there is no bare wire showing. if the reciever doesnt ower on replace the fuse inside(make sure unplugged from wall)
May 17, 2009 | Yamaha RX-V661 Receiver
Zone 2 volume control
Sounds like the Zone 2 amp was set to external, see below for instructions on setting it back up.
How do I setup Zone 2 on the RX-V661 Using the internal power amp.
Setting the RX-V661 remote control to operate Zone 2
1. Using a ballpoint pen or similar object and press the Code set
button. The Transmit indicator on the remote should flash twice.
2. Using the numerical key pad on the remote and key in 9992, the
Transmit indicator should flash.
You will now need to assign the receivers internal amp for Zone 2.
1. Set the remote control selector to AMP. Selector is on side of remote.
2. Press the Set Menu Button.
3. Arrow down to Manual Setup.
4. Press the Enter button.
5. Arrow to the Sound Menu option and press Enter.
6. In the Sound Menu arrow to Speaker Set and press Enter.
7. Arrow to the EXTRA SP ASSIGN and select ZONE2. This may require using LEFT or RIGHT arrow.
8. Press the Return button to exit out and return to the Manual
Setup.
Apr 05, 2009 | Yamaha RX-V661 Receiver
Shuts off within seconds of turning on.
Sounds like the "crack!" was a capacitor that got fat and blew up.
Feb 28, 2009 | Yamaha RX-V661 Receiver
Remote
Hi jimvandy
Most yamaha codes will work some of your unit functions. try 0176 or 1176. These are for a dvr3 comcast remote. You can get the whole list and manual from here
I am more than happy to answer any other questions you may have about it, just give me a hoy :) If you still have problems, before you give a rating for this advice, please get back to me and we can try some more things.
Thanks for using FixYa, If you consider the advice I have given you as sound, a FixYa rating is a great reward for my efforts to help you. Cheers.
regards
robotek
Jun 02, 2008 | Yamaha RX-V661 Receiver
RX-V661 Receiver
your receiver has zone 2 output which is operated independently of the main reciever. so you can have a dvd playing inthe main reciever and the tuner playing over the intercom. read about it in your manual page 89. in will hook up to 2 RCA jacks in the back Zone 2 out.
Dec 29, 2007 | Yamaha RX-V661 Receiver
Sound goes up from tv show to commercial
There are two reasons for this. Firstly, the commercial channels are deliberately boosting the volume during commercial breaks to grab your attention. Secondly, the commercials use compressed audio (narrow dynamic range). This often comes across much louder than program material, which is using a wider dynamic range on which you would have based your volume setting. It is noticeable that the BBC are also sending out wide variations in volume at present - Yes it is VERY annoying. Some sort of ALC (automatic level control) is required but this would need to be switchable. Hope this helps.
Sep 26, 2007 | Yamaha RX-V620 Receiver
Yamaha RX-V793 flashing light on volume control and no volume
Per Yamaha support page: The volume light on my Yamaha AV receiver is flashing, what does this mean ? The "MUTE" function on your remote control has been activated. The reason that you can still hear a very low sound is that the muting circuit within your stereo is not a full mute, but rather a -20dB mute. To deactivate the "MUTE" function, simply press the "MUTE" button on your remote control. (Make sure the volume control is turned down to avoid damage to your system.) If you misplace or lose your remote control, you will have to purchase a new remote control unit, as there is no duplicate function on the front panel of your stereo. Unplugging the stereo will not deactivate the muting circuit, as the microprocessor "remembers" if the muting circuit was active prior to being turned off or unplugged. If you need to purchase a remote control, you may order one directly from our parts office. You may reach them by dialing (714) 522-9888 from 8 am to 3 p.m. Pacific Time, Monday through Friday. If you have any other questions, please contact our customer service department by dialing (800) 292-2982 Monday through Friday from 8:00 a.m. to 4:00 p.m.
Sep 03, 2006 | Yamaha RX-V793
258 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
