Question about ASUS P5PE-VM Motherboard
Hard drive not recognized in setup
Hello folks,
You helped me greatly last Nov diagnosing a hard drive that got corrupted by a power outage.. Now it seems the new hdd is defective. It sounds like it is spinning, but makes a crackling sound for a couple seconds, and just continues spinning. In the setup menu there is no hdd recognized, and the computer won't boot up. I subbed the old hdd that I reformatted and it works fine.
I tried the freezer fix and repositioning the drive but no difference. Seems toasted to me but do you have any suggestions?
Thanks
Rick
  • Rick Bilodeau Feb 22, 2009
    Thanks for the tip. Looks like it's toast.
    Problem Solver:
  • 14 Answers
Hi Rick
It seems like you have a faulty HDD which will not initialise properly as a result of internal defect. Have you tried shaking the drive, which sometimes settles the HDD. Try nudging it against your hand.
If this does not solve the problem you will require a new drive as repair may make it uneconomical.
Let us know if this helps. Good luck.
Posted on Feb 22, 2009
Me harddrive is not on anymore, i left it on last night?
There was probably a power outage and you didn't notice it because you were asleep. The Computer's hard drive does not turn on by itself after a power outage.
Aug 02, 2011 | Computers & Internet
I just upgraded my Windows Vista 64-bit computer to Windows 7 64-bit. Backed up all my documents onto a ST3200823A-RK Seagate external hard drive. I have used this HD for 3 years, and it has always...
Check the drive with another computer. One with Vista and one with Windows 7 if possible.
This will tell you if there really is a problem or not.
Hope that helps
Jun 20, 2011 | Computers & Internet
Hi I am tanvir My problem this below I have Mantor
It is possible that the power cord, data cable or pin selector jumper has been dislodged.
Go in to the bios and try to see if the drive can be recognized.
an outside option is that you contracted a virus that destroyed the MBR (Master Boot Record) rendering the drive unrecognizable.
diagnose top to bottom.
Oct 12, 2010 | Maxtor Hard Drive
External no longer recognized
Right click My Computer, Properties, then click on Device Manager.
Select Disk Drives then on tab menu Action, Add legacy hardware. Go through the setup and use CD's that came with Hard Drive otherwise search company site for drivers.
Oct 05, 2009 | SimpleTech 500GB SIMPLEDRIVE EXT HD-USB...
Problem It reads press f1 retry boot, press f2 set up? How to do it. I do not have a recovery disc. thanks mits
Sounds like its not seeing your hard drive or you have corrupt system files and windows isn't booting.
Press F2 to go into the setup and make sure the hard drive is being recognized. If it is recognized then that means windows is corrupted and you'll need to reinstall your laptop back to factory defaults. If the hard drive is not being recognized in there then you'll need to reseat the hard drive back into the slot.
Then turn the laptop on and press f2 to go back into the setup. If the hard drive is now being recognized then see it if boots into windows. If it doesn't then you'll need to restore your laptop back to factory defaults.
If the BIOS still doesn't show the hard drive then your hard drive is bad and would need to be replaced.
Jul 11, 2009 | Dell OptiPlex GX240 PC Desktop
Booting up Windows after a Power Outage
That power outage probably damage some sectors of your hard drive, or corrupted some files that Windows need to boot up.
You need to install the Windows installation CD, and press R after the Welcome Setup screen.
Once there, it will should you the available drives and partitions.
If you have a computer set up like most people, you need to press 1
Then Windows will ask for the Administrator's password.
If you have no password, just press Enter.
Once on the C:/ prompt type the following
CHKDSK /r
To perform a check disk, and repair any errors on the hard drive.
The process take some time, but at the end, Windows will start up.
Please don't forget to rate this answer if its helpul
Jun 22, 2009 | Microsoft Computers & Internet
The drive not reading
Hello folks,
Sounds like both units are suffering from hardware failure. The most likely culprits are failed USB/1394 to IDE/SATA circuitry or failed drives.
The simplest test/solution is to buy a new, empty, drive enclosure and transfer your drive into it. Test that enclosure, if it works, the drive is fine your done.
If it doesn't the failure is in the drive itself and if you have important files on the drive you will require the help of a pro. State your region and city and I will give you a recommendation for a professional data recovery service.
Chris
May 28, 2009 | Iomega (33222) 80 GB Hard Drive
Pc does not recognize slave drive
Look into the computer bios / setup and see if the drive is detected there.
to get into the bios or setup press the button indicated on the screen right when you turn the computer on, it can be either F1 F2, f10, del, space, esc depends. it should say on the screen.
May 21, 2009 | Maxtor Hard Drive
ASUS P5PE-VM Motherboard Logo
60 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
