Question about Disney Mix Max Digital Media Player
What does it mean when the screen is stuck on it's "OK TO REMOVE"
When I connect the MIX to my Pc the screen says it's ok to remove with a thumbs up picture what does this mean?
This means that the player is not downloading anything or running any programs, and if you disconnected it at that time, the items on your player would be unaffected. Once you have downloaded songs, pictures, or movies, you need to wait for this screen before you disconnect your player.
Posted on Mar 04, 2009
Red and yellow horizontal lines on the last third of the screen
3 Options
LCD damaged
Flex cable from MB to LCD
Graphic card damaged
First try to connect the laptop to a external screen...its ok???
Remove the lcd and try another one...its ok???
If not....change the flex....its ok?
If not...only one option...graphic card (GPU)
Feb 26, 2014 | DELL Inspiron 15 3520 Cnfg 2 Lptp 3Yr 2nd...
How to adjust fuel air mix in Ryobi Lawn hornet
hello sir,, now there are two types of carb.adjustment screw covers,the old one where there are plastic over the screws,simple remove the plastic covers with a pair of needle nose pliers or cutting off,,,second are the new ones that are above the adjustment screws,which you have to take your drummel tool with the cutting blade and cut slots in the screws, after you get this done it is important to count the number of rotations in until stops make note how many. because you are going to reset the same way.now remove the screws,put to the side when you get ready to put screws in put in all the way than back out as many turns that you noted, now that is factory set there should only be a small adjustment to do. the rule of thumb is turn both out 1 1/4 turn and adjust in until saw runs smooth and idles ok, it is hard to adjust the top speed when saw is running wide open,let saw idle when adjusting top speed is easier that way, when you go to cut wood you may have to readjust top speed, the above does apply some what if you are not using fresh gas mix and dumped out the old fuel and starting with fresh,and a new plug CJ8Y,and as you know the saw has to breath in and out by this i mean a clean air filter,make sure the small screen on the muffler is not cloged,this will keep saw from running at peak speed and sawing wood, ok i have ran across a few saws to where the small screen in the muffler is cloged so the saw would idle but not run at high rpm's,if you do and check all of the above your saw should run,oh btw check compression should be above 60 to 160 lbs, hope this helps,any comments welcome,please accept my solution,thank you. 00
Feb 12, 2012 | Ryobi Garden
Cant display anythng on th screen
make sure the monitor is connected to the cpu and it is on just remove all the drive connection and remove RAM and check it give the beeps if it gives the beep that means board is ok but something is wrong with motherboard try to swap you power supply also and check the power connector like 4 pin connector is also connected .try with resetting the bios also.
Have a nice day and do not forget to rate please...!
Feb 03, 2012 | Compaq Evo D510 PC Desktop
It says please remove sd card and reboot the device
OK, this means to remove, from a PC if connected, remove any SD or Memory Cards, that maybe being used, and then to find the little reset button, (usually in little hole at side/rear) and depress it for a few seconds, and the GPS will "Reboot" and restart as usual.
Mar 12, 2011 | GPS
My washer will stop and nf displays and it beeps. what does this mean?
Sorry to read about your problem, I hope this helps you out.
NF means no fill, their is a inbound water issue, water turned off, or clogged hose, etc
remove hoses and check little screens at hose ends..
if thats ok, you may have other issues in the machine.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 04, 2011 | Samsung WF203ANW Front Load Washer
My dell laptop lcd splashes the OS and then goes dark. It works fine with an external monitor. I have a feeling that there is a loose connection since the top is almost falling off
Think you have answered your own problem here. If the external screen is ok, then the fault lies with the laptop screen.
Solutions..
1.) Remove keyboard top cover (download a "how to" guide if not familar with doing this)
2.) Remove screen bezel
3.) Check the inverter connections (inverter looks like a thin tube)
4.) Check cabling from motherboard to monitor /inverter for signs of fraying, tears, bare wires
5.) Check connections of the cable for damage.
If the above are ok, then you may have a damaged inverter. In any event, i'd look to repairing the damage to the loose lid, as its putting a strain on the wiring
Feb 09, 2010 | Dell Inspiron™ E1505 PC Notebook
When I turn on the laptop sometimes the screen doesn't come up and when it does come up it says F10=ROM Based Setup. When I press F10 nothing happens.
Sounds like the hard disk is not able to boot the laptop.
ROM based setup means you need to reset or reconfigure the BIOS.
Assuming the BIOS battery is OK.
This could be because the hard disk itself died, you can remove the disk and attach it to a USB adapter (cheap to purchase) then connect it to another PC. If you can read the disk OK in another PC then you have a motherboard problem.
Apr 18, 2009 | HP Compaq nc6120 Notebook
HELP HELP HELP HELP NOW! We are making copys on a Xerox XL2140df and it is blinking a red squigly light..... it won't print.  Flashes E.. help us. We need the copies ASAP.
OK first don't panic, Second the Squikly line ( does it look like a lighting Bolt sort of ?
this means you have paper stuck somewhere and and it needs to be removed.,Open the cassette and remove paper then open the side door then the front door and remove paper that is stuck ( BE CAREFUL not to touch the GREEN ROLLER THING ) thats called a Drum, you do not want to scratch that ok.
Nov 18, 2008 | Xerox WorkCentre XL2140df Laser Printer
It has a spamware program stuck on the screen
if you dont want it go to controle panel and go to add remove programs and seee if it is there or else just do a end task kon it and see if you can get to go off the screen that way ok best regards mike
Aug 21, 2008 | Computers & Internet
Disney Mix Max Digital Media Player Logo
83 people viewed this question
Top Disney Audio Players & Recorders Experts
Lyle Siemens
Lyle Siemens
Are you a Disney Audio Player and Recorder Expert? Answer questions, earn points and help others
