Question about Dell Inspiron 1525 Notebook
Network Vista Wireless Laptop to XP Desktop & Print Documents
Have a Systemax Venture desktop computer with Windows XP pre-loaded connected to a HP LaserJet 4000 printer and a Dell Inspiron 1525 PC Notebook which I use wireless in my office. I have the need to print from either or without using a wireless printer. How do I network them both to do this? I can print fine with the XP computer directly of the ATT DSL modem. I need to be able to share printer.
  • 447 Answers
On the desktop machine - go to the printers folder, right click the icon for the Laserjet and choose sharing (enable print sharing). You should be able to name the printer and make it accessible to anyone within the workgroup. If needed you can run the network setup wizard to change the workgroup names on both machines.
On the laptop go to add new printer and choose network printer, you should be able to browse to the desktop machine by name and choose the Laserjet as a printer (whether you want it to be the default is up to you). The laptop will download and install the drivers from the desktop pc to the laptop and set the correct network path automatically.
It goes without saying that the desktop machine must be on in order to print from the laptop in this scenario.
Posted on Feb 21, 2009
  • John Elliott
    John Elliott Feb 21, 2009
    One additional note - in some cases the XP printer driver is not compatible with Vista and will give you an error message during the described install, if this occurs post back here and I'll track down additional info for you.
How can I copy, the 27 House photos from Facebook, to My Documents File
Copying pictures from faceBook is easy.
Right Click on the picture you want to save choose from options Save image as give a name direct the location my documents on your computer click ok!
Sep 10, 2011 | Systemax Venture Via 2500 Desktop Computer...
I have HP Officejet 6500 connected via USB to office desktop. I also need print from vista laptops on the same wireless network as the desktop. How do you do it ?
Hi, I just completed this same query this week.
to set up my remote network i followed promts from windows and then had to run my windows xp startup disc on my vista laptop.
After that was complete i had to install the hp printer setup cd onto my vista laptop and connect the hp printer to my router using the ethernet cable. I followed the prompts on the vista as the cd continued to install. then at the end of it all it showed i had correctly installed the printer via wireless and asked me to do a practice print which i did and all seems fine.
I can now print from my vista laptop and my windows xp desktop. I hope this helps
Jun 12, 2011 | HP Officejet 6500 AllInOne InkJet Printer
HP photosmart used to print wirelessly from my Vista loaded laptops. printer was usb connected to desktop with XP. Had to get new hd and reload with XP for desktop and now cannot configure for wireless...
As your printer is not wireless itself I assume you shared the printer. To enable this again goto Control Panel on your desktop, select printers, right click your printer and there should be an option for sharing. Enable sharing.
Now using your Vista laptops you should connect to your home network (in your case this is probably a wireless router, as long as your desktop is connected to this router too), goto Control Panel, printers, add printer, search for printer not connected to this copmputer (or network printer).
Hopefully the Vista laptops will then pick it up and install it correctly. You may be asked to install the correct driver for the vista machines. Windows should provide you with instructions on how to do this.
Hope this helps,www.PuterCare.com
Feb 27, 2010 | HP Photosmart 2610 All-In-One InkJet...
Setting up HP C6180 to wireless laptop
if your desktop and laptop connected with same network then open the printer windows on the desktop computer, do the right click on it and select the share option.
after that select the share for everone and click on ok.
then on vista computer open the printer windows and click on add printer after that you will get the option local printer or network printer.
Select the option "network printer: and click on next and click on find the printer and select the printer and click on finish.
good luck
Aug 07, 2009 | HP Photosmart C6180 All-In-One InkJet...
Using HP laptop running Vista wireless intranet connection to HP desktop running xp and desktop hardwired connected to HP Officejet 6110. Can not get laptop to print on network. All internet and other...
The printer needs to be installed by you as "Adiministrator". When installing the printer you need to hold down the "Alt" button when clicking n Add Printer function. It will then give an option of installing as Administrator.
May 20, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Home networking Windows XP
Often this is a simple power management issue. On the laptop check the wireless properties and disable allow Windows to turn off this device to save power.
Apr 05, 2009 | Microsoft Windows XP Professional
Hp Vista Laptop won't communicate with XP desktop when trying Prt
u have share your printer and add your printer in laptop u have to connect both pc in lan (local area connection ) or u can use the cross cable of lan when both pc connected then u have share your printer in xp then u have to add the printer in your vista laptop by using printer add visrd there is option on it u have to select the network printer & add it in to vista then u can print it
or
there is onther way u can install your printer in a laptop u need ur printer vista download
Jan 17, 2009 | Office Equipment & Supplies
My HP Officejet Pro L7580 prints one page and then stops
TRY WITH WHETHER THE PRINTER CONNECTED PROPERLY AND UPDATE IS NOT PROPER
Nov 18, 2008 | HP Officejet Pro L7580 All-In-One InkJet...
Wireless printer
it sounds as if the printer may not be set as the default printer, so check in the installed printers and check and also check that the printer you are sending the print to is the setup one and not a pdf or microsoft office document printer, this is found on the drop down box when the print option appears. i am also assuming that the printer has worked before from vista to an xp machine as sometimes xp needs a small update to be used with a vista pc on the network
Jun 12, 2007 | Linksys (WKPC54GCU) 802.11g/b Wireless...
Dell Inspiron 1525 Notebook Logo
163 people viewed this question
Alun Cox
