here is the setup. Had yamaha 8x4x24 e-ide installed using Easy CD Creator Deluxe 4.02, no problems. Removed Yamaha installed Plextor 12/10/32. Easy CD Creator Deluxe 4.02 can not see Plextor so installed 4.02s that was bundled with Plextor, now ECDC can see Plextor but no deluxe version.Tried to re-install deluxe over 4.02s, made a mess of video driver. Anyone able to use the deluxe ECDC version with the plex 12/10/32? tnx raz
There has been some confusion about which version of ECDC supports the PX-W1210TA Plextor drive. ECDC 4.02c/DCD 3.01c doesn't support the Plextor drive. When 4.02d/3.01d is released it will support the drive. There is a special version of 4.02c that has has been released to Plextor and tested by Plextor, but Adaptec has not released it to the public pending 4.02d. Some users are distributing a bootleg copy of this special 4.02c update, but without Adaptec approval. Use it at your own risk. As soon as the offical update is available we will inform you via the newsletter and the list.
Best regards, Adrian Miller (On behalf of Adaptec Software Products Group) Please reply to me in this newsgroup or via the Adaptec CD-R list Adaptec CD-R Software: # Adaptec CD-R community: # Adaptec CD-R list: # ASPICHK Utility: # CD-R Info Grid: # OEM Support: # Newsletters: #
Was this helpful?
Yes
No
Solution #2
posted on Aug 01, 2007
Melissa - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
I uninstalled The deluxe version. I reinstalled it, rebooted, ran the patch and all is well.
Ray
Was this helpful?
Yes
No
Solution #3
Lizzy - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
I received the same file, same response. This is the SAME patch that comes on the CD packaged with the burner. Still not able to get DELUXE version (4.02) to work with Plexwriter 12/10/32 This is what tech support said "If the update I attached doesn't do the job for you, then you will have to get an update directly from Adaptec for their ECDC 4.x deluxe package" Does anybody have DELUXE 4.0 working with this new Plextor. ( I think we may be at the mercy of Adaptec for a fix.) Raz
>> > tnx
Was this helpful?
Yes
No
Solution #4
Jimmy NY - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
I had this same thing happen. They will send you a 1.8meg patch in an email. I was pleasantly suprised that they responded within 4 hours on a Sunday!! I mostly use Nero but I have EZCD 4 Deluxe and I wanted it to work with my drive just in case
Ray
Was this helpful?
Yes
No
Solution #5
Horner - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
I sent an email to Plextor Sunday afternoon. Sunday evening I received a reply with a file attached that will upgrade 4.x to 4.02c (s10).
I was shocked that Plextor responded so quickly.
Great burners and great support...a powerful combination.
Was this helpful?
Yes
No
Solution #6
Cato - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
email plextor support - they have an update for directCD and EZCD that is newer than adaptec's latest just for this drive.
Hi Artec WRR.52Z scsi DVD/CD-R This machine will not recognise a disc so that I may record off my C...
(More)
Hi Artec WRR.52Z scsi DVD/CD-R This machine will not recognise a disc so that I may record off my C drive I have sony dvd rewritables DPW1200N2 & Packard Bell CDRW 4 speed discs
PX -W4824A I had the old uninstalled EZCD Creator 4 from XP SP3 and had to use the delete the Upper...
(More)
PX -W4824A I had the old uninstalled EZCD Creator 4 from XP SP3 and had to use the delete the Upper & Lower Filters in the registry fix to get Device Manager to remove the yellow triangle exclamation points from my CD drives problem. Once the drives were recognized both in Device Manager & Windows Explorer (this was happening to an old Creative DVD-ROM drive, too) neither would acknowledge a CD in the tray "Please insert a disk into drive #:" even with a formatted or recorded audio CD or an OEM data / software CD. After a firmware upgrade to the Plextor and an uninstall / reinstall in Device Manager for both they will both read a CD sometimes but most of the time they will NOT. Some times if the CD was in the drive on reboot they won't read it until the disc is ejected and the tray re closed. Plextor sometimes identifies in Windows Explorer as CD-RW Drive but mostly as CD Drive. Autoplay also executes intermittently. Help will be greatly appreciated.
I installed my old plexwiter on my newer computer and the drive slows my computer down and it will...
(More)
I installed my old plexwiter on my newer computer and the drive slows my computer down and it will not read any disks. Sometimes it will read music CD's and play them, but it will not reasd any other CD's, software CD's included. Sometimes it will not read any at all. I do have the driver. Sometimes it will freeze my computer, but if I open it and close it my computer ressumes. Also if I do this and just leave it open it will not close after a whils. Please Help.
