Question about Philips 43PP9202 43" Rear Projection Television
Red Convergence issue. Can't adjust. 3d picture.
Red Convergence issue. Can't adjust. 3d picture. Bottom two rows and top row. Need schematic to repair.
  • Philips Master
  • 3,459 Answers
Get a kit from www.TvRepairKits.com to fix the convergence.
Posted on Mar 22, 2009
  • 4,234 Answers
If you can solder, try resoldering the pins on the convergence ICs. If that fails to resolve the problem, replace the ICs. Please note that there are potentally dangerous hogh voltages present inside hte set even when unplugged.
Keep us posted on your progress.
Dan
Posted on Feb 21, 2009
Sony kp-51 ws500 rear projection tv. when turn on tv there is 3 duplicate images overlayed...green, white, red. looks like I am watching an old school 3d movie, but without the glasses. i already took the...
The problem is your convergence circuit board gone bad. This is commonly caused by shorted/open IC on that board. First try to spot if there is a bad solder joints and resolder it. If nothing replaced the convergence IC. Also check the resistors around.
Hope it may help you.
Have a nice day!
Thanks for using Fixya.
Feb 13, 2011 | Sony Televison & Video
LG Projection TV Model# RT-49NA11T Green color gun shows bent arc on top & bottom.Red & blue guns are ok.How to adjust the green gun to remove the bent arc. This is causing picture shows mix...
This problems ur tv have can't not be fix by adjustment.The tv have a problems known as convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,must be replaced to repair the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Jan 10, 2011 | Panasonic PT-53WX53 53" Rear Projection...
My Toshiba 51 inch projection tv has red squares on screen
The model indicated is a projection set and the question is does it look 3d looking etc or something else?
See attached photos of typical convergence problem which MAY be what you have.
SD TECH
May 02, 2010 | Toshiba 51H83 51" Rear Projection...
Blue outlines on screen. not a screen burn or convergence problem
I am not familiar with that particular model but most are similar.
It may need the blue focus adjusted. Most tv's have some type of automatic focus. If the blue is out of focus it can "bloom" beyond the red and green. There should be a focus block with 6 adjustments (2 rows of 3) behind the speaker cover. I wouldn't mess with the one labeled screen or block. Adjust very carefully. They are usually in the order Red-Green-Blue with the focus on the bottom row.
Mar 02, 2010 | Panasonic PT-47WX53 47" Rear Projection...
Picture looks like its 3D what is the problem
The D52W20 had an issue with solder joints around the flyback. When you take the back off the flyback is on the very left closes to the back of the tv and has a large red wire coming out of it. Looking from the top down you will see three small orange rectangles in a row. These are fuses and one of them is going to be opened.
All you have to do is resolder the pins on the flyback and replace the fuse and you should regain convergence.
Jun 10, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Text/images overlap each other in 3 colors, 3D distorted picture
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick email and they will put one together for you. Their kits includes photo instruction guides, original Sanyo STK chips, convergence resistors, pico fuses, etc.
Jan 28, 2009 | Sony KP-51HW40 51" Rear Projection...
Im trying to fix my dads old big screen projection tv its an rca home theater tv and the problem is that the picture is curved at the top and bottom and the colors are seperated and it shows 3 of...
This is a common problem on older RCA projection tvs. There is a small power supply that powers the convergence circuit and that is what usually fails causing this issue. The model # will help you get the correct part. If you open the back of the set, it is the power board mounted above the convergence board (above the board with row after row of heatsinks). There will be a red and black wire that drops down to the convergence amp.
Dec 07, 2008 | Televison & Video
Phillips rear projection tv model #60pp9202/17f
  • Screen looks 3D
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Feb 25, 2008 | Philips 60PP9202 60" Rear Projection...
CONVERGENCE PROBLEM
Yes sir anytime you move a projection set ,theres a chance that the convergence could go out of alighnment as it dosent take much. First off your gonna need a cross hatch generator and a service manual and a good kno how on convergence alighnment as when you adjust some controls you need to counter it withanother completely differant alighnment control> so in some cases to get a section or a linearity correction your gonna spend some time. I myself remeber one set I spend 5 hours on after a customer tryed to adjust the confergence them selfs. Not only did it cost a bundle to realighn the gentleman need to go to the hospital as i results of touching a spot on the chassis that he shouldnt have and gave him a shock that threw him across the room. My advice, unless you have convergence experience is to invest in a service person to come out to your home and adjust it for you. I would try first an authorized repair center as they should have all the tools and secrits to the convergence in that set. And Please without electronic experience, even an unplugged set can harm ya. Good luck Try the # and the link 800) 252-5722 or proinfo@jvc.com
Jun 04, 2006 | JVC AV-56WP30 56" Rear Projection...
Distorted Color and geometry of Picture
I've posted this solution several times but here goes. Try setting up the convergence through the menu by accessing the convergence setup menu. If this fails to work you have a bad digital convergence box and need a tech to replace it. About $60 to $100 fix.
Nov 03, 2005 | Panasonic PT-47WX49 47" Rear Projection...
Philips 43PP9202 43" Rear Projection Television Logo
115 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Brian Sullivan
Brian Sullivan
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
