Question about KitchenAid KESC307 Electric Kitchen Range
Kitchen aid stove oven shutting off reading error f2:E5 what happened?
  • Anonymous Mar 27, 2009
    I made the mistake to let water boil over under and into the front control panel.
    The unit now shuts off after 5 seconds or so whenever I turn it on. What could I have possibly shorted out and destroyed?
    Is there a schematic or wiring diagram somewhere? I am willing to replace and parts.
    Thanks,
    Keith
    President:
  • 1,902 Answers
Electronic range clock failure. You will need to replace this part. It is located where your keypad is. You will need to get behind it and pull the part out and replace it with the exact kind from repairclinic.com
Posted on Feb 21, 2009
Tip
Troubleshooting KitchenAid oven, range and microwave error codes
Here list of Kitchen Aid range and oven codes.
4 Digit Failure Codes
F1 - E0 EEPROM communication error
F1 - E1 EEPROM checksum error
F1 - E2 UL A/D error
F1 - E4 Model ID error
F1 - E5 Calibration shifted
F1 - E6 Latch signal mismatch error
F1 - E9 Stack overflow
F1 - E3 Wiring harness cavity size does not match stored value
F2 - E0 Shorted touch pad
F2 - E1 Keypad cable connection error
F2 - E5 Cancel key drive line open
F2 - E6 Cancel key drive line open
F3 - E0 Oven temperature sensor (RTD) opened (upper oven on double oven models)
F3 - E1 Oven temperature sensor (RTD) shorted (upper oven on double oven models)
F3 - E2 Oven temperature is too high (Cook mode)
F3 - E3 Oven temperature is too high (Clean mode)
F3 - E4 Oven temperature sensor (RTD) opened (lower oven on double oven models)
F3 - E5 Oven temperature sensor (RTD) shorted (lower oven on double oven models)
F3 - E6 Drawer sensor open
F3 - E7 Warming drawer sensor shorted
F4 - E1 Meat probe malfunction - shorted
F5 - E0 Door Switch
F5 - E1 Self clean latch will not lock
F5 - E2 Latch during CLEAN error
F5 - E5 Self clean temperature not reached within 45 minutes.
F5 - E6 Door is open, but latch is locked
F5 - E7 Self clean latch will not unlock
F6 - E0 Return line not connected
F7 - E1 Common switch wire defective
Two digit codes:
F0 ERC Board failure
F1 ERC Board failure
F2 Oven temperature is too high
F3 Oven temperature sensor open
F4 Oven temperature sensor shorted
F5 ERC Board failure
F7 Function key stuck on ERC
F8 ERC Board failure
F9 Oven door lock failure
Microwave and Microwave combo error codes:
F1 - E3 or F1 - E4 Electronic control malfunction
F2 - E0 or F2 - E1 Keypad connection error
F2 - E3 Keypad held down too long, or keypad is shorted.
If you get an error code, try first resetting the code:
1. Disconnect power for about two minutes.
2. Connect back power.
3. If code re-appears, test and eventually replace faulty part.
on Apr 24, 2015 | Kitchen Ranges
Tip
F5 - E0 Door Switch
Two digit codes:
Regards.
on Mar 27, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
My kitchen aid stove keeps displaying F2:E2 - Why? and what does that mean?
That code means that the oven is over heating.
Replacing the temp. sensor should do the trick. The sensor
is the rod that protrudes from the inside back wall of oven.Usually in the top left corner.
Feb 05, 2013 | KitchenAid KESC307 Electric Kitchen Range
Heartland metro f2 error code
bad sensor or bad computer board or clock assy.read out the sensor and find the tech sheet for your stove and it will tell you what the sensor should read out on,if the sensor is good then you have a bad computer board or clock assy.you can look up the error codes on the tech sheet too,look on the back of the stove,the papers are usually there on the back of the top console.F2 Oven temperature is too high 1. Look for welded relay contacts on bake or broil relays. If this happens, replace oven control (also called clock or ERC).
2. For SELF CLEAN models: check door lock operation.
3. Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective.
Remember: Oven control (ERC) measures resistance of sensor circuit, not actual oven temperature
Nov 08, 2011 | Kitchen Ranges
I have a Kitchen Aid Slide in Range model KESC300BBL8. When using the oven it keeps shutting off after a short time. F2-E5 will be displayed.
F2-E5 is "Cancel Key Drive Line Open"
Here is the procedure
1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Thanks to: http://www.appliancepartspros.com Make sure to have your model number handy.. before calling a repair man or ordering parts.. Hopefully it's a lose connection.. Best of luck!
Apr 22, 2011 | KitchenAid Kitchen Ranges
F2 &F3 error codes, oven keeps beeping, I already tried turning off circuit breaker did not solve problem
F2
- E0 Shorted keypad (also called touch
pad) 1. Check keypad connector for firm
case, replace control board (also called ERC or clock). F2 - E1 Keypad cable unplugged F2 - E5 Cancel key drive line open F2 - E6 Cancel key drive line open F3 - E0 Oven temperature sensor (RTD) opened (upper oven,
if double oven) Replace Oven temperature
sensor (RTD)
Note: Applies to all F3-E...
codes. F3 - E1 Oven temperature sensor (RTD) shorted (upper
oven, if double oven) F3 - E2 Oven temperature is too high (Cook
mode) F3 - E3 Oven temperature is too high (Clean
mode) F3 - E4 Oven temperature sensor (RTD) opened (lower oven,
if double oven) F3 - E5 Oven temperature sensor (RTD) shorted (lower
oven, if double oven) F3 - E6 Warming drawer sensor open F3 - E7 Warming drawer sensor
shorted
Dec 20, 2010 | Whirlpool Accubake RF362LXTT Electric...
Error code F2 E3 r:02 E:03
Kitchen Aid Error Code F2-E3
Called kitchen aid, they said you need a new control board part #9782455.
Mar 16, 2010 | KitchenAid KEBC107 Electric Single Oven
Kitchen Aid KESC300 smooth top electric stove
Look on the back of the oven for a tech sheet. This will tell you what the code means and what to check. May be an oven temp. sensor or oven control bad. Can't remember what f7 is without looking at the tech sheet.
Sep 30, 2007 | KitchenAid KESC300 Electric Kitchen Range
KitchenAid KESC307 Electric Kitchen Range Logo
562 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
