Question about Denon AVR-1600 Receiver
Front panel switches dont work
I have a similar Denon receiver and the front panel switches dont work. This occured after high wind and the electricity kept going out. It is still usable and I turn it on and off with a power strip. The volume and balance controls still function. I cant switch between sources and it is stuck on CD input. I am constatly changing connections between CD and DVD, and TV. I cant use my phono becuase the CD input doesnt have the required preamp. My only solution is the repair shop, but I hate to be without my receiver that long.
shaggyrat
  • 1224 Answers
SOURCE: Denon 4308
ok sounds simple you ran the lines threw the tv instead all lines should be ran threw the sterio
see once you turn tv off this cuts the outputs out so now no sound will happen
your sterio should be equipted to take inputs of tv
you want everything to be inputed threw receiver thats why they call it a receiver the outputs on tv goto inputs on receiver
you need to redo your wireing so that this which i described is correct again
Posted on Jun 02, 2008
Gurudristi
  • 98 Answers
SOURCE: Connection/configuration issue: I have a Denon
Just confirming my understanding of your connections :
1). The DVD1800BD output HDMI is connected to AVR3808's DVD-in HDMI.
2). The DVD/VHS recorder output HDMI is connected to AVR3808's DVR-in HDMI.
3). The DVD/VHS recorder input (S-video and L/R Audio) is connected to AVR3808's DVR-out(SVideo and L/R Audio).
Right?
What other inputs have been connect to your AVR3808?
Does the recorder have Component Video inputs?
Please also connect DVD1800BD's output(Component video, S-Video and L/R Audio) to AVR3808s' DVD-in similar inputs and try recording onto your recorder.
Actually, its possible that you may be having a HDMI HDCP communication issue(High-Bandwidth Digital Content Protection) with the source product (DVD1800BD). First check with the source equipment manufacturer for any updates to their products.
If HDMI video is not passing through your AVR3808, you can connect it thru the alternate connection method I have mentioned above.
If the connections/recording still does not happen with the added anolog cables, then let me know , we can trouble shoot it further.
I hope the above helps.
Please do rate this solution and thanks for using FixYa!
Posted on Mar 06, 2009
  • 11 Answers
SOURCE: No system configration display on AVR3300 since moving.
Make sure the two switches on the remote are all of the way to left most position before you try using the SYSTEM SETUP button - if the AVR is going into SETUP, the LCD display should be saying "SYSTEM SETUP". (I think that model does - most do).  also make sure that the Composite or S-Video on the TV's input 1 work from something else like a VCR, DVD player, ETC. rule out the TV and the cable first.
Posted on Apr 02, 2009
mattvierra
  • 74 Answers
SOURCE: Denon receiver AVR-3300: Unstable source selection
Very important you have run system set up menu it configures your receiver with inputs analog or digital,speaker size,input,room correction etc Different input modes can be selected for the different input sources.
The selected input modes for the separate input sources are stored in
the memory.
q AUTO (auto mode)
In this mode, the types of signals being input to the digital and
analog input jacks for the selected input source are detected and
the program in the AVR-3300’s surround decoder is selected
automatically upon playback. This mode can be selected for all
input sources other than PHONO, MD/TAPE and TUNER.
The presence or absence of digital signals is detected, the signals
input to the digital input jacks are identified and decoding and
playback are performed automatically in DTS, Dolby Digital or PCM
(2 channel stereo) format. If no digital signal is being input, the
analog input jacks are selected.
w PCM (exclusive PCM signal playback mode)
Decoding and playback are only performed when PCM signals are
being input.
e DTS (exclusive DTS signal playback mode)
Decoding and playback are only performed when DTS signals are
being input.
r ANALOG (exclusive analog audio signal playback mode)
The signals input to the analog input jacks are decoded and played.
t EXT. IN (external decoder input jack selection mode)
The signals being input to the external decoder input jacks are
played without passing through the surround circuitry Your remote is searching for inputs because you did not properly run system set up!!! Here is a link to your manual [PDF] AVR-3300/1 3.3E*
Posted on Jul 22, 2009
  • 1417 Answers
SOURCE: how do i connect phono with built in preamp to
A phono preamplifier (preamp) connects to a turntable to boost the audio signal from a record so it can be processed on newer audio-video receivers for playback. New AV receivers may not have a dedicated set of turntable jacks. Instead, AV receivers accept the line-level signal from CD players and amplifiers, which does not require equalization or a significant power boost. Turntables need extra amplification, which is why a preamp is needed to work with receivers that do not have a dedicated set of turntable jacks. Standard stereo cables are needed for the connection.
Instructions and what use need to fix it up.
  • 2 sets of stereo cables with a pair of 1/4-inch plugs on each end
  1. Connect the white and red plugs on each end of a stereo cable from the left and right audio output jacks on the turntable to the left and right audio input jacks on the back of the preamp.
  2. Unscrew the "GRND" ("Ground") knob on the back of the preamp, then wrap the end of the single black wire on the back of the turntable to the metal post and tighten the "GRND" knob to secure the wire. This prevents the low-frequency hum from the turntable cartridge from interfering with the music.
  3. Plug a second set of stereo cables from the left and right audio output jacks on the back of the preamp to a set of input jacks on the back of an AV receiver. Any pair of available jacks will work for the connection; just remember which set of jacks is connected to the preamp.
  4. Set the component selector control on the receiver to the set of jacks that connect to the preamp. For example, if the cable from the preamp is connected to the jacks labeled "Tape 1" or "Auxiliary," dial the selector knob on the receiver or press the receiver remote control button for "Tape 1" or "Auxiliary" to activate the connection.
Good luck and thanks for using fixya.
Posted on Jan 18, 2011
Denon AVR1603 RESET
Starzy, to reset on a Denon AVR-1603
  • power off the unit using the front panel Pwr switch
  • press and hold SPEAKER A and B buttons;
  • keep pressing on the speaker buttons, switch on the AVR
  • when the display is blinking release buttons Check the attached links,instruction and guides, Good luck
    "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.avsforum.com/forum/90-receivers-amps-processors/1386123-help-denon-avr-1603-shuts-down.html
Denon AVR 1603 Operating Instructions Manual Last Function Memory...
Jul 24, 2016 | Denon Audio Players & Recorders
Hookup a pre-amp and equalizer to a Denon AVR 982
Hi
you can choose any input on the Denon and select it from the front panel
setup the Equalizer and the preamp connections and plug it in the selected input on the Denon.
Thats it.
if u haveany Questions dont be a stranger.
good luck
Mar 16, 2016 | Denon Audio Players & Recorders
How can I connect a subwoofer to this device (denon pma-520) http://www.hifiengine.com/manual_library/denon/pma-520.shtml?destination=node%2F14208
The only safe way to do this us to connect the sub to one of the other speaker outputs using a "speaker selector" switch. For example, you would go out of the receivers left speaker output, into the selector switch then out of the selector switch into the sub and the left speaker. There really is no other way.
Jun 08, 2014 | Denon Pma-520 Integrated Stereo Amp...
Were does the LH mirror on a 2011 f-250 connect. Removed mirror but disconnect is located some were in door or body. need to know what needs to be removed to gain access
  1. Remove the front door trim panel.
  1. Position aside the front door watershield to gain access to the exterior rear view mirror control switch electrical connector.
4.Disconnect the exterior rear view mirror control switch electrical connector
as you see you have to remove the door panel to have access to the electrical connector in case that you dont know how to do it here are the instructions
NOTE: Left front door trim panel shown, right front door trim panel similar.
  1. Remove the sail panel.
    • If equipped, disconnect the electrical connector
  2. If equipped, lift up and remove the exterior rear view mirror control switch panel.
    • Disconnect the electrical connector.
  1. If equipped, lift up and remove the window control switch panel.
  1. If equipped, remove the window regulator handle.
    1. Position the window regulator handle cover aside.
    1. Remove the window regulator handle screw and regulator handle
5.Remove the door trim panel center screw cover
6.Remove the 2 door trim panel center screws
7.Remove the 2 door trim panel lower screws
  1. NOTICE: Do not pull directly outward on front door trim panel as damage will occur.
    • Lift upward to remove the front door trim panel.
  1. NOTICE: Insert the lower panel tabs first or they can break when installing the front door trim panel.
    To install, reverse the removal procedure
Feb 20, 2011 | 2011 Ford F-250 Super Duty
In cable / sat mode accidentally switched to analog in stereo. i have 5 surround sound and can not get any sound. how do i get out of analog and stereo - i have a denon avr 1911
Carefully examine the front panel indicators for status of switches you DON'T want active.
http://www.retrevo.com/support/Denon-AVR-1911-Receivers-manual/id/23695ci376/t/2/
Register and download it for free at retrevo.com
See Page 17 and consider how the digital audio is assigned (page 46).
Feb 13, 2011 | Denon AVR-1911 Receiver
HOW can i connect this ross model eq r15s to my avr687 denon rece
Treat each EQ (or any processor) as as Tape Deck and place it on its own Tape loop on the Denon. Tape deck(s) can attach to external processors because they always have tape loops to replace the one they use.
Rule of Thumb: OUT's go to IN's.
You can have as many processors as you want. I have five.
You can serialize processors if they would logically be used together or you could get a dbx-200 or dbx-400 Program Route Selector which provides connections and switching facilities for 3 processors and 3 tape decks but uses only one tape loop on the receiver.
Individual processors can be engaged or disabled, and the whole mess can be placed in the record OR the playback end of the chain - all via front panel switches. Very versatile.
Apr 21, 2010 | Audio Players & Recorders
Denon AVR-3300 component channel switch burnout?
hi there, i don't have a solution unfortuantely, but i may have the same problem. I have a denon 2802 av receiver, i bought it second hand and I can't seem to get the component video in / out working. Are you supposed to just plug it in and it works? Because I can't find any buttons or settings to select component in / out as my input / output sources?
Nov 12, 2009 | Denon AVR-3300 Receiver
Denon RC-978 remote... every button shuts receiver off
Drop the front panel of your receiver,there is ZONE 2 ON/OFF switch.
Good day!
solutiondoct
Sep 12, 2008 | Denon AVR-2807 Receiver
Denon 1508- no sound but smoke.
perhaps u might consider going to a(n) (unauthorised) repair centre. just check with folks around u or maybe audio forums within your area. authorised agent doesn't always mean the best. i suspect they may have used reconditioned components.
Aug 31, 2008 | Denon AVR-1508 Receiver
Denon AVR-1600 Receiver Logo
57 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
