Question about Epic View 550 Treadmill
The Incline is stuck at an angle
My wife use the epic view 550 treadmill and she stop the treadmill at an incline of 4 OR 5. Now the incline is stuck at an angle and will not change or go back to zero.
  • Anonymous Mar 15, 2014
    i need to order a belt to my epic view 550 treadmill EPTL09706 i cant find this part on amazon any suggestions?
    President:
  • 1,902 Answers
Check the motor and the gears that run the unit up and down. If is located on the front of the unit under the face plate. make sure everything is power everything. Also check the gears to make sure they did not break and check the tracks to make sure it did not fall off the track causing it to stay up
Posted on Feb 21, 2009
Everything works except the Treadmill motor ? Incline works OK, belt doesn't turn at at all. Model EPIC View 550
1) You have problem with LUBE deck belt, this happen because the lack of maintenance, you must lube EVERY week, use 100% silicone lube. Maybe you have WORN deck belt,
2) LUBE the rollers bearing too, use wd-40
3) Test the drive belt motor, see for break, or worn, and replace or tension by 1/4"
4) Test the input voltage motor, if there are the motor need repair. see my personal TIPS for help and troubleshooting.
5) Test the output voltage board, for input voltage motor, if there are NOT the board controllers is faulty. God bless you. see the block diagram attached.
Nov 25, 2012 | Epic View 550 Treadmill
I have an Epic t60. The incline stopped working. I was in the midst of going from flat incline to full and then back down again when it stopped. The incline numbers now register on the display, but it...
Try to recalibrate the incline. Start the machine running, press the incline up button, then pull the safety key off. Release the incline up button and replace the safety key. The treadmill should go to maximum incline then minimum. after calibration is completed, retry the treadmill operation.
Jan 11, 2011 | Epic Overstock T60 Treadmill Treadmills
Incline is stuck, motor still runs?
First try to calibrate the incline as described in your owners manual.
Start the machine. Press the incline up button. While pressing the button, remove the safety key.
Release the inline up button and reinsert the safety key. The machine should run the full cycle, up to maximum elevation, then back down.
If the motor moves and then resets, you may have an incline motor sensor defect. You will need to order a new incline motor. The sensor is not available separately..
Dec 15, 2010 | Epic View 550 Treadmill
I have a new epic 550 and the treadmill will not latch up, in fact I called and got a new latch lock installed it and this one doesn't latch up either. any idea
Did you make sure the incline is completely down? I had a similar problem and then realized the incline was on 2. I recalibrated and then it latched fine.
Dec 13, 2010 | Epic View 550 Treadmill
I put it "up" for storage and now I can't get it down to use... Epic View 550
push it forward before trying to pull knob and make sure the incline is at the lowest level.
Aug 10, 2010 | Epic View 550 Treadmill
Epic treadmill t60 is stuck in max incline how do
Usually when stuck at the max up position it indicates that you may need a new incline motor. It is not the sensor. I have been repairing treadmills for 15 years and incline sensors seldom if ever go bad. If can isolate the incline motor using a 110 volt power cord, this may un-jam the motor and get it back down to 0%.
I use www.treadmillpartszone.com for parts.
Jul 25, 2010 | Icon Epic T60 Treadmill
When folding the treadmill, I cannot get it to stay up.
First foremost is the unit incline to zero degree if not power up the unit hit the start and use the quick incline zero button. Now if that does not resolve the problem check your latching assembly especially the knob and see if it locks in place or if the knob feels sticky then a little bit of 3 in 1 machine oil will do the job.
Apr 09, 2010 | Epic View 550 Treadmill
We are putting the Epic 550 together and got to the part about the storage lock. When we try to lift the treadmill into a verticle position, it won't go up far enough. It only goes up about half way. Why?
check and see if you incline is down to zero if not this problem occurs or the or plug it in and if the incline reset itself then it should be o k if not you may have to do a calibration on it
Mar 01, 2010 | Epic View 550 Treadmill
Incline wont work
Check here for the user manual:
http://manualfox.com/link/reebok.htm
And maybe send them a manual request?
Mar 23, 2009 | Epic View 550 Treadmill
Epic View 550 Treadmill Logo
1,009 people viewed this question
Top Epic Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Electro Med Services...
Are you an Epic Exercise and Fitnes Expert? Answer questions, earn points and help others
