Question about Bosch Logixx WFT 2806 Front Load Washer/Dryer
Bosch WFT 28 All in one washing machine does not heat water or tumble dry my clothes dry, can anyone help please. thank you.
  • 1587 Answers
SOURCE: Bosch washing machine WFT 8010
Some dryers have a "fluff" or "no heat" setting that spins the dryer with the heaters turned off. Check to make sure your cat didn't step on this button : ).
The most common failure modes include the main temperature regulating thermostat, overheat thermostat or thermal fuse, and heater elements. If you have a blown thermal fuse, check to make sure you don't have a lint buildup in the vent ductwork, especially right at the blower outlet. I've also seen problems with broken heater wiring and burned-out contacts in the heater control selector switch. The bottom line is that if gets to this point, you'll need to find the wiring diagram hidden inside the control panel, get an ohmmeter or continuity tester and start tracing the heater wiring.
Posted on Nov 18, 2010
barkencoa
  • 3463 Answers
SOURCE: Bosch Classixx WFL 2462 Front Load Washer
Remove plastic panel at front bottom of washer, there you will see the filter, unscrew it anti clockwise to remove and clean, replace and tighten up clockwise.
Plz rate my solution.
Thanks.
Posted on Jan 17, 2009
  • 250 Answers
SOURCE: Bosch maxx classic washing machine doesn't clean clothes
There are a lot of things to consider when trying to solve this problem. Obviously a front loader washes differently than a top loader. Top loaders tend to using a washing motion that is good for stains but wear out your clothes fast. Front loaders typically use less water and wash more gently, but in some ways still do better than top loaders. Anyway, think about any other variables that go into the laundry equation. Consider the distance the machine is from your water heater. This machine will use MUCH less water to fill than your old one, and, you know how when you turn a faucet on hot it takes a minute for the hot water to actually get there? It's the same way with your machine. If there's a sink next your washer, you should always turn on the hot water on the faucet until it gets hot right before you start the machine. The same goes for dishwashers. If there's not a sink close you can easily turn up the temperature for all hot water on your water heater, although that will use more energy.
Consider what detergent you're using. If you're using high efficiency detergent (like Tide he) maybe you should switch to your old brand. If you're using your old brand of detergent, try getting a high efficiency detergent.
Posted on Sep 20, 2009
barkencoa
  • 3463 Answers
SOURCE: my Bosch classic 1200 express washing machine wont drain or spin
Possibly a blocked filter or pump.
Ths filter should be at the bottom right front of washer, sometimes behind a removeable cover at the bottom of washer.
To clean it, unscrew anti-clockwise, remove and clean.
Posted on Dec 09, 2009
SOURCE: not finishing cycle & wont heat water up!
to solve this disaster you must.......
...... GET A NEW ONE AND STOP BEING SO CHEAP hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha
Posted on Feb 04, 2010
Testimonial: "yeah cheers mate massive help that was grow up!"
Time work problem
If it is relatively new, then my advice to you, is to contact the service agents, and get it looked at under guarantee.
Please rate my solution.
Thanks.
Sep 17, 2009 | Bosch Logixx WFT 2806 Front Load...
WFD2460 Bosch washing machine
WFD2460 Bosch washing machine This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 02, 2009 | Bosch Logixx WFT 2806 Front Load...
Clothes still wet aftre drying cycle over
It sounds as if the wash cycle isn't terminated by pumping the rinse water out and spinning to rid the clothing of most of the water.
Most dryers sense moisture but I think they all will have a maximum run-time to prevent possible fires if the programmer fails to shut them down at the end of the drying cycle.
I would watch the machine and when it started the drying cycle, I would shut it off and check for surplus water that hadn't been pumped out as it should have been.
Feb 03, 2009 | Bosch Logixx WFT 2806 Front Load...
Bosch Logixx vented dryer not working correctly
I had the same problem.
I took of the cover on the back and found the heating element had blown. I just replaced it for a fraction of the cost of a new drier, just unscrewed it and conected the two wires easily.
Jan 25, 2009 | Bosch Logixx WFT 2806 Front Load...
Bosch WET 2820 dryer pumps in water
most likely a electrical fault have programmer checked
Jan 11, 2009 | Bosch Logixx WFT 2806 Front Load...
Bosch WFD 2460 Washig Machine
Hi, It sounds like you have the two water pipes fitting on the wrong connectors on the back of the machine.
IE: The hot water pipe (RED connector) on the cold water inlet on the back of the machine (BLUE connector)
Is should be red to red and blue to blue.
Jan 03, 2008 | Bosch Logixx WFT 2806 Front Load...
Tumble dryer not working
I managed to solve the problem the following way: I noticed that if you unplug the Sensor-NTC(part nimber 154431 https://www.bosch-eshop.com/eshop(bD1lbiZjPTAwOQ==)/bosch/gb/prodp.htm?prod=WET2820GB%2f13 ) that controls temperature of air in the air channel, the drying cycle runs as you describe above. So this circute was checked up to the power module. Contacts of the Sensors plug were tightened; I think this solved the problem; resistance of the sensor checked. It must be 4.8K at 25 degree C. and decrease when temperature increases. I dipped the sensor in a glass with hot water.
Oct 25, 2007 | Bosch WET 2820 Front Load Washer / Dryer
Machine is locked
to open your door make sure all the water is out of your drum if not get the outlet hose and place on the floor into a bucket if water comes out than your pump is either blocked/faulty
Aug 12, 2007 | Bosch Logixx WFT 2806 Front Load...
WFT 2800INSTRUCTIONS
http://www.bshappliancecare.com/Bosch/ click "instruction manual download" type WFT in the search box, and you are taken to the downloads page - sorry i couldn't link to it directly. Hope this helps :)
Feb 09, 2007 | Bosch Logixx WFT 2806 Front Load...
Washer dryer
Here is the link for a manual for your washer/dryer if you need it; https://portal.bsh-partner.com/portal(bD1kZSZjPTAwOQ==)/PORTALFRAME.HTM sounds like the heating element has failed, or just possibly the thermostat for the hot air. follow this link for a list of spares if you want to try it yourself, or for bosch repair centre details if not. http://www.bshappliancecare.com/Bosch/boschspares.html ask if you want to do it yourself for any guidance you need. Hope this helps :)
Sep 29, 2006 | Bosch Logixx WFT 2806 Front Load...
Bosch Logixx WFT 2806 Front Load Washer/Dryer Logo
50 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
