Question about Samsung HCN553W 55" Rear Projection Television
HI, I am having Samsung 29' tv, TV screen has moved to left side, when i click on menu it displays that hotel mode, can u please help me in this manner. Thanks in advance, Ismail
  • 325 Answers
Turn the television into standby.
with the remote press the following.
INFO, MENU, MUTE then POWER this will bring up Samsung hidden menu where you will be able to disable the hotel mode option this will allow you to sort the screen out and other options
hope this helps
Little Dish Fitter
Posted on Sep 17, 2009
  • Mick Sep 17, 2009
    The following steps will help you..
    turn your samsung tv off so that it is in standby mode. ie red light on the front.
    using the samsung remote press the following.
    INFO, MENU, MUTE, POWER, (this must be pressed in this order within 3 seconds.
    when the tv turns back on you will see the hidden menu. just go to the hotel mode option and disable this.
    Hope this helps you out
    Cheers
    Little Dish Fitter
How to get Sanyo dp50741 out of hotel mode?!
This is for Panasonic but might help you
Getting out of the hotel mode is very easy. Just go get the Panasonic remote and open your tv. Go near the tv and hold down the AV/- button on the television itself. Then use the remote and press the AV button for 3 times. A hidden menu on the television screen will appear. Turn off the "Hotel Mode" from the menu and exit. Do not touch anything from the hidden menu except the hotel mode. Now you can use your tv in normal mode. The remote is required to access the hidden menu so be sure your remote is working and has working or full charged battery before doing the steps above.
Read more: My 50" sanyo plasma tv is stuck in hotel mode how do i get it out of hotel mode? - When i turn the tv on it says D01--32 and a blue lower case u under it :: Ask Me Fast at http://www.askmefast.com/My_50_sanyo_plasma_tv_is_stuck_in_hotel_mode_how_do_i_get_it_out_of_hotel_mode-qna4904417.html#q5129429
Nov 28, 2015 | Sanyo Televison & Video
Tip
ERROR CODE AND SERVICE MODE
Service tool modeHow to access
1. Select [SRV-TOOL] in Service Mode.
2. Press [OK] button on the remote control.
Display of SOS History
SOS History (Number of LED blinking) indication. From left side; Last SOS, before Last, three occurrence before, 2nd occurrence after shipment, 1st occurrence after shipment.
This indication except 2nd and 1st occurrence after shipment will be cleared by [Self-check indication and forced to factory shipment setting].POWER ON TIME/COUNT
Note : To display TIME/COUNT menu, highlight position, then press MUTE for (3sec).
Time : Cumulative power on time, indicated hour : minute by decimal
Count : Number of ON times by decimal
Note : This indication will not be cleared by either of the self-checks or any other command.Exit
1. Disconnect the AC cord from wall outlet.
Hotel mode
1. Purpose
Restrict a function for hotels.
2. Access command to the Hotel mode setup menu In order to display the Hotel mode setup menu, please enter the following command(within 2 second).
[TV] : Vol. [Down] + [REMOTE] : INPUT (3 times)
Then, the Hotel mode setup menu is displayed.
3. To exit the Hotel mode setup menu Disconnect AC power cord from wall outlet.
Troubleshooting Guide
Use the self-check function to test the unit.
1. Checking the IIC bus lines
2. Power LED Blinking timingCheck of the IIC bus linesHow to access
Self-check indication only:
Produce TV reception screen, and while pressing [VOLUME ( - )] button on the main unit, press [OK] button on the remote control for more than 3 seconds.
Self-check indication and forced to factory shipment setting:
Produce TV reception screen, and while pressing [VOLUME ( - )] button on the main unit, press [MENU] button on the remote control for more than 3 seconds.
Exit
Power LED Blinking timing chart
1. Subject
Information of LED Flashing timing chart.
2. Contents
When an abnormality has occurred the unit, the protection circuit operates and reset to the stand by mode. At this time, the defective block can be identified by the number of blinks of the Power LED on the front panel of the unit.
FOR MODE DETAILS CHECK THE FOLLOWING LINK
www.electro-medical.blogspot.com
google.com/+AjinGopakumar
USE SEARCH TAB TO FIND MODELS OR USE DROP DOWN MENU
on Jun 30, 2015 | Panasonic Tc-50ps14 Tv Power Supply Board...
I can't access my main menu for my Phillips TV
The TV might have set to Hotel mode. To get it out from this mode, you have to enter its service alignment mode [SAM]. Check this link to get more details about it. It is too much to type in here, al the procedure. http://electronicshelponline.blogspot.com/ Pull up previous posts there, either by its left side bar, or view it in Timeslide option.
Jul 03, 2013 | Televison & Video
How to off samsung cs21-m16mj crt tv hotel mode
when the hotel mode is on you will always get the display. see the on screen display is comming. if it does not appear it means there is a fault in the tv. if appears you can go to menu & find "hotel Mode" in picture submenu & put it off.
Sep 26, 2011 | Televison & Video
WHEN IM WATCHING TV, ICONS APEARING FROM THE LEFT OF SCREEN ,DISPAYING INFO ABOUT LED TV SERIES THEN ANOTHER ICON APPERARS ECO FREINDLY AND SLIMLINE TV. THEN IT DISAPPEARS AND AFTER A FEW VSECONDS IT...
I do not see a Samsung TV with the model UE40B7020. (What country are you in?) I do have documentation for the UE40C7000WW.
Is the TV in Shop Demo Mode? Press the Info button on the remote to see the mode. If it reads "Store Demo", try resetting it. Press the Volume button on the TV or the remote. While the Volume circle is displayed on the screen, press and hold the Menu button on the TV for about 7 seconds (the remote will not work for this). Home Mode should display on the TV screen.
Alternatively, you can set this from the TV menu system. Make sure that the current input is TV. Press Menu then select Setup (up/down arrows followed by Enter). Select the Plug and Play sub menu and follow the on-screen directions to reset the tv to the Home Mode.
The FAQ for the TV that I used as a reference is available at: http://www.samsung.com/us/support/owners/product/UE40C7000WW#
I hope this helps.
Jun 08, 2011 | Samsung UE40B7020 40 in. LED TV
I need the code that will tske my samsung 40" out off hotel mode
hello,
To switch off hotel ode on samsung, enter:
1. On standby press info-menu-mute-power or,
2. press mute-1-8-2
After service mode appear, Choose option block,
Fine Hotel mode, change to off.
If in option block you can't fine it, try open other block.
Good luck.
Apr 16, 2011 | Televison & Video
The brand name Samsung is in the middle of the screen. I wish to remove it and with no manual I do not know what to do. Also there are other messages fliping on and off the screen too.
Method 1
To remove your TV from Shop Mode or Store Demo Mode, follow these steps:
  1. Press the Volume + button on the side panel of your TV. If your TV does not have a side panel, press the Volume button on the front panel. The TV displays the volume bar.
  2. With the volume bar displayed on the screen immediately press and hold the MENU button on the side panel of your TV for about seven seconds. Again, if your TV does not have a side panel, press the MENU button on the front panel. If Dynamic or Dynamic Mode is displayed on the screen, your TV has been removed from Shop Mode or Store Demo Mode.
    Note: You may want to press the INFO button on your remote again to confirm you TV is no longer in Shop Mode or Store Demo Mode.
Method 2
  1. Press the Volume button on your remote. The TV displays the volume bar.
Method 3
  1. Change your TV to the "TV" source. The TV source is the coax (RF) source. It does not matter if you do not have anything connected to this source.
  2. Press the MENU button.
  3. Use the ??² or ??¼ button to select the "Setup" portion of the menu, and then press the ENTER button.
    Note: On many TVs the menu sections name is displayed on the left side of the menu and sideways.
  1. The "Plug & Play" option should be highlighted if it is not use the ??² or ??¼ arrow to select "Plug & Play" option, and then press ENTER.
  2. Note: If the "Plug & Play" option is grayed out and can't be selected this means that you are not on the TV (Coax (RF)) source. Please return to step 1.
  1. Follow the on screen instructions. When the options comes up select "Home" instead of "Shop".
  2. Finish going through the plug and play option and your TV will no longer be in Shop Mode or Store Demo.
Feb 01, 2011 | Samsung TXD1972 19" TV
I am trying to unlock a Samsung la32a450, I think it's hotel locked, i i know the code for the b and c series but that dosen't work on the 'a'
have your tv in standby mode then on the remote press info, menu, mute, power in that order then when your tv turns on you will be in the menu screen to unlock hotel mode
Dec 04, 2010 | Televison & Video
Reset Hotel mode
Hi, have you tried holding the TV menu and the remote menu buttons together, then selelcting menu again on remote.
Oct 02, 2010 | LG 37LG50 37 in. LCD HDTV
Akai TV - Stuck in Hotel Mode
M (menu) 7935 (regular menu appears), them press 4725 (menu service appears), then search HTLSRC (position 090), then set value 032 (this value disables Hotel Mode) - TV. Now Hotel Mode is deactivated. It is verified!
M 7935 4725, go to HTLSRC (090), fix 032 - press TV. Good luck!
Jul 28, 2009 | Akai Televison & Video
Samsung HCN553W 55" Rear Projection Television Logo
377 people viewed this question
Jerry Greenberg
Jerry Greenberg
