Question about Yamaha RX-V661 Receiver
Receiver is shutting down.....
I have a Yamaha V663 connected to Cambridge Soundworks M60 in the front (left and right) with a Cambridge Soundworks Center (MC 400). The rears are Cambridge Soundworks Ensemble III and the Sub is a Klipsch Synergy 12". At various times during a movie, the receiver will cut out and I will get an error message CK SP WIRE. I have checked the connections and there are no wires touching. At the input I am using banana clips and at the speakers I just have the wire tightened down traditionally. I have even replaced the speaker wire and currently am using Monster XP NW Compact Precision Strandad High Resolution. I have also tried the auto set up functionality but I cannot get past the test of the front left speaker as I get an error message E-1: NO FRONT SP. So, I have changed the speaker out replacing the left with the right to see if this was a speaker issue. The movies I have been having trouble with are Blu Ray being played with a PS 3 connected via HDMI. Not sure if that matters at all. I have also checked to make sure the speaker impedance is set to 8 ohms as this is the what is printed on the back of the speakers. I believe I have tried just about everything in the manual and still cannot seem to overcome this issue.
  • jshweissman Feb 21, 2009
    Thank you...I have checked the wire and replaced it to just about every speaker. I had initially thought that some of the wire was not heavy enough, so I used a ticker gauge. The problem continues....
  • 15,935 Answers
I would venture to say that perhaps your speakers are "self-protecting" by opening their respective relays. Possibly because of a previous heavy load and the reciever is seeing this as an open circuit, thus CHK SPK WIRE error.
Replacing the relay is your fix.
Standard procedure to any tech - and under $50 fix.
However, that error is usually a ground loop sensor, and is indicative of a grounded speaker wire. Either a fine strand touching the chassis at the back of the unit, or a blown speaker coil.
Use an Ohm meter and check the resistence and continuity to be sure. And triple check ALL speaker wires (especially at the rear of the reciever).. I would also suggest disconnectin ALL speakers and re-trying the left WITHOUT the banana plugs. Just use raw speaker wire.
If after these tests, you still have no output on the left front - a professional repair will be required.
Thanks for using FixYa - a FixYa rating is appreciated!!
Posted on Feb 21, 2009
  • 564 Answers
1. Make sure all of your HDMI connections are secure.
2. What remote do you use? Try watching a movie and put
the remote in another room. Sometimes remotes can emit erroneous commands if they are malfunctioning or if the batteries are low.
3. Cover up the sensor on the receiver while you are
watching a movie. See if it still shuts off. I have seen
other devices like “Alarm sensors” actually turn components  on or off.
4. Make sure the power strip is not malfunctioning.
Try plugging it directly into the wall to find out if that is problem. Buy a new power strip if it is.
5. Make sure the “advanced dynamic range
 compression” is turned off. It can increase  or decrease the volume level.
Reply back and I can give you more information/instruction.
Hope this Helps, Please Rate My Response! Thanks!
PREM
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
The Yamaha displays such an error message not only because the speakers wires may be touching but because the coil/windings of the speaker themselves may be rubbing against the magnet reducing their specified impedance of 8 ohms further down.
There is a way to test which of the speaker is erring:
  • connect an analog continuity tester (VOM) set to XI to the speaker wires. Measure the resistance which should be 8 ohms as you described. Move the cone, push the speaker playing the travel while noting the meter. If the meter changes even just a bit, the coil is grounding to the magnet at certain distance/times;
  • replace the speakers one at a time by a spare known good speaker;
  • wire a 4.7 ohm 5 watt ceramic resistor in series with the speaker wire, one at a time. The idea is to increase the resistance above 8 ohms. Test again until erring speaker is determined.
Good luck and thank you for using FixYa.
    President:
  • 2,110 Answers
Check the speaker wire that must be broken in between...
I need circuit diagram for Cambridge Soundwork Slim 500 model. Where I can find it?
    Cambridge Soundworks circuit diagram cambridge audio a1 ...
    www.fixya.com > ... > Tags > circuit diagram cambridge audio a1 mk3
    Ask your Cambridge Soundworks circuit diagram cambridge audio a1 mk3 questions. Get free help, advice & support from top Cambridge Soundworks experts. images for circuit diagram for Cambridge Soundwork
Jan 05, 2016 | Audio Players & Recorders
Control module
The connections on the control module all depends on what outputs are available on the receiver or whatever audio component you have.
Probably the most straight forward hook up is to connect the receiver's speaker (R &L) outputs to the speaker Inputs of the module, however you may have potential outputs on your receiver that could used. What I suggest is for you to provide the information on the receiver with make and exact model number so the receiver outputs can be matched to the model. http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000030686.pdf
The link is for a system module manual, and it describes all the possible hook ups based on the outputs of the receiver. If you can provide the additional information on the receiver, I will try to asssit you further.
Jun 02, 2014 | Cambridge Soundworks ton Theater MC300...
Subwoofer
Without being able to access the receiver in person, the best advice I can give you is to sit down with your user manual and follow the instructions. You'll find, starting on page 85, the necessary settings for hooking up a subwoofer to the receiver. If you don't have the manual, you can obtain a pdf file at Yamaha.com: http://www.yamaha.com/yamahavgn/Documents/YEC/AV_Receivers/Manual/RX-V663_U-1.pdf
May 16, 2010 | Yamaha RX-V663 Receiver
Sound no picture, picture;no sound
a panasonic tv will shut down after a short time with no video input. it sounds like the setup menu in the receiver has defaulted and needs to be setup again to coordinate the audio and video signals. ive seen many yamaha menus default. dont let geeks in your house.
Nov 03, 2009 | Yamaha RX-V663 Receiver
First, I have to compliment you on a thorough and comprehensive problem description and an apparent sense of how to troubleshoot. We're halfway there already.
Your Blu-Ray / PS 3 statement is intriguing but with the E-1 code that absolves it as the problem.
You have two opposing symptoms: the live failure says you have a short while the test mode implies an open circuit. We have to isolate everything and see if it moves to another channel.
Let's run with the "E-1: NO FRONT SP" error. I think it's trying to tell us we have an intermittent sensation of an open wire in one of the Front speaker channels. * Unfortunately, the manual doesn't break out Left and Right (but I'm sure the receiver knows) to help us isolate. You say it doesn't get past the Left test. I need you to decide by listening to the Left Front Speaker setup routine if it's really working or not, and if it seems to be working, maybe the receiver is really failing at the point it advances to the Right Speaker, assuming Right follows left in the sequence.
Verify for me: You swapped the two front speakers Left to Right and replaced both speaker wires with NEW wires and had no improvement.
I'm wary of a failcode that doesn't identify which of a pair is failing, so I 'd like to see ALL NEW speaker hardware and connections in place to avoid the pitfall of swapping the L & R with each other and having one of them be the problem without changing the symptom.
We can accomplish this easily: Try temporarily running the rear speakers as the Fronts just to see if the test can pass. If so, test the Fronts as if they're the Rears speakers. You should be able to just swing the receiver-ends of the cables among the speaker posts.
Something should change or else the problem is internal to the receiver. Good luck.
Apr 28, 2009 | Yamaha RX-V663 Receiver
No sound out of right main when watching DVR/TV or VHS
When watching TV or VHS the sound should be stereo and therefor come out of the the 2 front speakers. I suspect you now have sound out of the left front and the center speaker which indicates you connected the center speaker to the right front speakerterminal and the right front to the center terminal.
Just check if all speakers are connected to the correspondent speakerterminal.
If this is correct and the problem persists, try to connect another speaker to the right front terminal to see of the terminal or speaker is not working properly. If another speaker does work on the same connection, your right speaker might be damaged which might not be heard when listening to 5.1 because of the surround sound.
Mar 15, 2009 | Yamaha RX-V663 Receiver
Tv sound only from right side
If you have the wires connected properly for stereo sound, go into the setup for the TV and set it for stereo speakers.
Feb 05, 2009 | Cambridge Soundworks TVWorks 250 Speaker
Fluctuation in sound output on Cambridge Soundworks 5.1 speakers
Hi Paulus
A lot brand of speakers, like Sound Blasters, Logitech, Cambridge, has this (strange) kind of volume problem, sometimes, is the resistor, in the volume control, sometimes in the modulator for the board on the sound speakers, Subwofer.
I use a general tip is let the volume in one setting and don't move in the intermediate low volume say....9 .
from other thing, be change the speakers.
Nov 25, 2007 | Cambridge Soundworks Movie Works 108...
Yamaha RX-V661 Receiver Logo
268 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
