Question about Lexmark X2500 All-In-One Printer
I can't delete a document that was in microsoft word, it says deleting but it won't delete. Consequently, I can't print anything.
    Sniper:
  • 68 Answers
1.net stop spooler
2. Go to C:\Windows\System32\spool\PRINTERS and delete all the files in it
3. net start spooler
then
Try this
Go into spooler and delete all of the files, then uninstall the printer from the printer folder and delete the driver from device manager. --> restart the computer and then reinstall the printer along the driver.
this worked for me on a HP printer....Hope this helps.
Posted on Jun 26, 2009
I have a document stuck in the print queue, which won't cancel or restart, help!
Turn off printer for 2 minutes @ least, turn back on, or delete printer and re-install printer. Go to HPsupport website enter your printer model info update drivers.
Jan 28, 2012 | HP PSC 1510 All-In-One InkJet Printer
Dell printer will not complete task. If printer is uninstalled then reinstalled it will print one time but doesn't complete the task on the "printing screen". I go to the printer window...
Hi Bill,
Have you tried the printers on another PC?Please do.
  • Whats the Operating System on your PC?Do the printer drivers correspond with that Operating System?If not,download the corresponding drivers from this dell support site. This you select under compatibility.
  • After uninstalling the printer,disconnect fully and unplug from power.Reboot your PC before installing the printer again.
Hope this helps.Thanks!
Nov 01, 2011 | Dell V305w All-In-One R840635AU InkJet...
I deleted my Microsoft Office Activation Wizard
try this :
1. Quit all running programs.
2. Download and install the Windows Installer Cleanup Utility.
http://download.microsoft.com/download/E/9/D/E9D80355-7AB4-45B8-80E8-983A48D5E1BD/msicuu2.exe
3. After you have installed the Windows Installer CleanUp Utility, click
Start>All Programs>Windows Install Clean Up.
4. Highlight Microsoft Office 2007 entry in the list and then click
Remove. Click OK and wait for the process to end. If any other stand alone
Office applications (such as Visio and Project) appear on the list, please
also remove them. Then, click Exit to close the Windows Installer Cleanup
utility.
5. Click Start>Run, type "regedit" (without the quotation marks) in the
Open box and press Enter.
6. Locate the registry keys below and click Delete from the Edit menu.
Click OK on the following warning dialog box.
Note: Please go to File>Export and backup all the registry first.
HKEY_CURRENT_USER\Software\Microsoft\Office
HKEY_LOCAL_MACHINE\Software\Microsoft\Office
Quit Registry Editor.
7. Delete or rename the following folders or files if they exist:
C:\Program Files\Microsoft Office
C:\Program Files\Common Files\Microsoft Shared\OFFICE12
C:\Documents and Settings\<UserName>\Application Data\Microsoft\Excel
Data\Microsoft\Office
Data\Microsoft\Outlook
Data\Microsoft\Publisher
Data\Microsoft\Templates\Normal.dot
C:\Documents and Settings\<UserName>\Application Data\Microsoft\Word
C:\Documents and Settings\All Users\Application Data\Microsoft\Office
C:\Program Files\OfficeUpdate12
8. Click Start>Run, type "%Temp%" (without the quotation marks) in the
Open box and press Enter. Delete all the files and folders within it. If
there are some files which cannot be deleted, just leave them alone and
this will not affect the result.
9. Empty the Recycle Bin.
10. To remove Mapi, search for and rename the following folders/files if
they exist:
C:\Windows\system32\mapi32.dll
C:\Windows\system32\mapisvc.inf
C:\Program Files\Common Files\System\Msmapi
C:\Program Files\Common Files\System\Mapi
11. Restart your computer and install Office 2007 again.
May 12, 2011 | Computers & Internet
I have an HP printer. There is a full page photo that will not print. When I try to cancel the job is states deleting but does not delete. It deletes other added print jobs but not that one which is...
You have to clear out all documents one by one in the print que before you can delete the one causing the trouble. On the bottom right side of your pc screen, find the picture of the printer and right click with your mouse on it. Open your print que and right click on each document and choose "delete" until therer are none left in the print que. If this does not clear that last document, then unplug your usb cord that connects the printer to your pc and wait a few moments, and then plug it back in. This should clear it out.
Sep 08, 2010 | HP Officejet J4680 InkJet Printer
There has been a pending document in the que. I tried to delete the document but now it states deleting next to the document in the que. Can not print anything.
Open the Print Que and see if it will let you pause the print job. Then close the que and turn the printer off. Open the print que again and see if it will let you delete it. For some reason every now and again a que will hang. This process should reset the que. It will dump everything in printer memory and should release the document to delete the job. In any event pausing the job should release the printer to print other jobs.
Sep 05, 2010 | Office Equipment & Supplies
I can't delete a print job in the queue . I right clicked and hit cancel. It said it is deleting it but that has been over an hour without removing it from the queue. Now I can't print anything while it is...
hi this is kamal...
go to start option there is print and faxes option pls click on that a window would appear and it will show your printer name, double click on that there would be ur pending document and delete on that and restart your system and 100% if would be deleted...
have fun..
Oct 07, 2009 | HP Officejet Pro L7680 All-In-One Printer
Can't delete document from printer queue. Can't print anything.
I've had this problem several times, and the only solution is to restart your system. Once rebooted, the printer will continue printing your other documents
Jun 07, 2009 | Lexmark JetPrinter X1185 All-In-One InkJet
PAGES WON'T PRINT, [TRIED TO PRINT BOTH SIDES BUT NOT SET UP FOR IT], THEN TRIED DELETING DOCUMENT, NOT WORKING, STUCK ON DELETING NOW AND WONT DO ANYTHING NO MATTER WHAT I DO. TRIED PRINTING OTHER PAGES -...
you can't print another document until there's a document on queue on the printer...you need to delete it first..
i experience it before I just delete the printer icon on the printer and faxes area and unplug the printer and plug it again ..wait a such time when a wizard appears on your screen just follow it..to find your printer driver..and to start a new session with the printer..
i hope it help..
and don't forget to rate...^_^
May 18, 2009 | HP Photosmart C6180 All-In-One InkJet...
Can not delete document in print q - nothing else will print
Open task manager,(Ctrl +Alt +delete) and end task on print spooler,delete the file.print spooler will restart automatically.
This works best if you have the que window open first.
Please rate this fixya
Jan 25, 2009 | Lexmark X3550 All-In-One Printer
Printing
Hi Hot,
It would be a BIG help if we knew the brand, model, and any little ole' bit of info you might feel like sharing. The commands and prompts that would be helpful for one item can totally screw up another.
Apr 21, 2008 | Office Equipment & Supplies
Lexmark X2500 All-In-One Printer Logo
91 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
