Computers & Internet Logo
A
Anonymous Posted on Mar 05, 2013
Need a Gateway GT5668E motherboard MCP61PM-GM cable hookups diagram
Need wiring diagram for motherboard MCP61PM-GM
5 Related Answers
Anonymous
  • Posted on Oct 11, 2008
SOURCE: need wiring diagram for emachines t2200 motherboard
i need wiring diagram for my emachine t2042! I can't figure out where the red/white, green/white and black/white wires go!
I already know where the power supply wires go, everybody does- they're all the same!
Joed911
JDTec
  • 4338 Answers
  • Posted on Nov 29, 2008
SOURCE: Need sequence for HDD LED, POWER LED, and POWER SW
The front panel header is on right the corner of the motherboard
if yu hhave the desktop laying down and the front bezel to you right and the back of the unit to your left. Here is a pictur which will give you reference on how to make the connections.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Anonymous
  • 2992 Answers
  • Posted on Dec 10, 2008
SOURCE: Have ECS MB # MCP61PM-GM.
That looks like it was made for Gateway. Here's a link to Gateway's site for the motherboard:
http://support.gateway.com/s/MOTHERBD/Shared/4006254R/4006254Rnv.shtml
Hope this gets you going.
Anonymous
  • 6 Answers
  • Posted on Jan 06, 2009
SOURCE: Motherboard wiring
cba3c97.jpgthis is the diagram for 103390 Intel (Augsburg) 915G
Anonymous
  • 1913 Answers
SOURCE: Replacing Motherboard
http://www.asisupport.com/ts_intel_955x_945_chipsets.htm
u can get from here.
Configuring a emachine motherboard
Hello here is the homepage:
http://support.gateway.com/support/drivers/search.asp?st=pn&param=4006254R
Manual or tech guide is not to be found at the gateway site.
I don`t know why
I found a manual here:
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=1139&MenuID=19&LanID=0
Just select your windows system, and download the manual.
You will need adobe reader. to read the content.
This manual should be the same as your mainboard, but here could be a difference in the drivers.
This manual should show you how to connect the cables.
Hope this will help you
Need technical manual for Gateway ECS MCP61PM-GM VER 2.2 Motherboard Socket AM2 mATX
I don`t know why
The manual should show you how to connect the cables.
I need a wire diagram for a Gateway Mother board MCP61PM-GM
Carole,
The front of the computer is the Front Panel.
The area of contact pins on the motherboard, that the main wires from the Front Panel go to, is the Front Panel header.
Would this be what you require, or more extensive?
From a fellow FixYa expert,
http://www.fixya.com/support/t614458-hp_mcp61pm_hm_motherboard_diagram
I know it states MCP61PM-HM
The 10-pin ( actually) Front Panel header, is the same across the board, for ECS motherboards.
For additional questions please post in a Comment.
Regards,
joecoolvette
http://www.playtool.com/pages/psuconnectors/connectors.html
Where do I get a motherboard for my gt5674
The issue is that like most manufactures Gateway "brands" their motherboards. You can find an ESC MCP61PM-GM motherboard many places, but if it is not branded you recovery software, or currently built hard drive will not work. With that said, there is a place that sells used/remanufactured "branded" motherboards.
http://www.algogo.com/store/products/Gateway-ECS-MCP61PM%252dGM-4006254R-AM2-mATX-DDR2-Motherboard.html?setCurrencyId=1
Here is a link to yours.
Hope this is helpful
I need a wiring diagram for a GM5664
Gateway Support > Gateway GM5664 Desktop PC > Downloads and Support Documents,
http://support.gateway.com/us/en/product/default.aspx?tab=1&modelId=2734
Click on the Support Documents tab
(Drivers, BIOS, Applications, Patches, Support Documents, etc)
Click on the blue - 1015004R - Support Documents
Click on Product Views in the list.
Click on Inside View
Go back to the main page
Click on Components
Go to the heading - Motherboards
4006254R - ECS MCP61PM-GM
(AM2 processor socket, MicroATX form factor motherboard)
Gateway Support is of no further help to us. Product Views for the motherboard does not work.
ECS motherboards use a 10-pin Front Panel header, if memory serves.
One pin is not used. (Not there. Number 10 pin)
http://www.ebay.com/itm/GATEWAY-GM5664-MCP61PM-GM-MOTHERBOARD-4GB-Ram-AMD-Athlon-II-Dual-Core-3-0GHz-/360423046239?pt=Motherboards&hash=item53eae33c5f
On the above link scroll the page down, until you come to the enlarged photo of the motherboard, with - Click an Image to Enlarge - under it.
Click on the photo view all the way to the right, on the top photos.
The view shows the 4 orange SATA headers on the motherboard.
(The whitish 24-pin ATX main power cable connector, is shown at the front, with the blue IDE 40-pin header behind it)
To the left of the orange SATA headers (4) is the Front Panel header.
Black rectangular connector with 2 rows of pins.
One row has 4 pins, the other row has 5 pins.
[ The plastic front of your computer is the Front Panel.
The area of pins on the motherboard, that the wires from the Front Panel go to, is the Front Panel header ]
Finding where number 1 pin is, is the problem.
Next to the number 1 pin, and silk-screened on the motherboard, is the number 1.
Looking at the rectangular connector (Front Panel header) you will note one pin is missing. This is where number 10 pin would be.
On the opposite side, and opposite end, is number 1 pin.
The pins are numbered Odd, 1, 3, 5, 7, and 9, on the same side.
(Or row)
The pins are numbered Even, 2, 4, 6, and 8, on the other side.
(Or row)
A) Pins 1 and 3 are for the HarDDrive activity LED light.
(HDD LED light)
Pin 1 is for the Positive ( + ) wire.
If the Harddrive activity LED light is dim when operating, switch the wires around.
B) Pins 5 and 7 are for a Reset switch, IF a Reset switch is used.
C) Pin 9 is Not Connected. N/C. Reserved for the factory
D) Pins 2 and 4 are for the Power On LED light
Pin 2 is for the Positive ( + ) wire.
If the Power On LED light is dim when the computer is on, switch the wires around.
E) Pins 6 and 8 are for the Power On switch. (Located inside the plastic Power On button assembly. It is an ATX power on switch)
As for the orange SATA headers on the motherboard. The SATA harddrive should plug into the lowest number of SATA header.
It may be labled SATA 0, or SATA 1.
The beauty of SATA however, is that you can plug the harddrive into anyone of those SATA headers. BIOS will find the device. (Harddrive)
If you need guidance in connecting any other cables, such as power cables, or optical drives, etc, post back in a Comment.
Regards,
joecoolvette
Can this motherboard handle an am2+ socket? MCP61PM-GM
YES, AM2 processors will work on AM2+ motherboards and AM2+ processors will work on AM2 motherboards. However, the operation of AM2+ processors on AM2 motherboards will be limited to the specifications of Socket AM2 (1 GHz HyperTransport 2.0, and one power plane for both cores and the IMC). This is taken from wikipedia
Have ECS MB # MCP61PM-GM. Really need a manual for the motherboard. Anything available. Been all over looking. Rev. DAKeller
Top Gateway Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
