Question about Compaq Presario Notebook
Something is wrong with the color on my laptop
  • My reply is May 11, 2010
    Can you be more specific?
In spite of the fact that I properly downloaded and installed my ION Film 2 SD Plus Slide and Film Scanner into my Toshiba Laptop computer, I cannot scan anything into it. I repeated the downloading a
i am surprised that it is not a stand alone scanner. for almost the same price i have a wolverine which basically works on mains power, or powered from laptop. it scans and stores the images in the unit. those can be later transferred to the laptop while connected via usb. one question, does the scanner lcd show the scanned image? if not may be something is wrong with the unit itself.
Nov 25, 2014 | ION Audio Film 2 SD Plus Slide and...
Color fading from left to right
I'm sorry to hear that you're having this issue with your TV. It may be an inverter board, or something internal having to do with the backlighting of the unit. I would recommend having the unit inspected by a technician.
Nov 06, 2013 | Philips Televison & Video
Amilo li 3910
Just insert the cd of an OS and see if it displays something.....
If it becomes blank again then I think your PC's display has gone..
Jun 09, 2013 | Computers & Internet
MacbookAir
This is definitely a hardware problem and not a virus. Flashing red, green, and blue is a sure sign that there is something wrong with the graphics chip, as those are the colors each pixel is able to be. The graphics card is telling the screen to display those colors instead of splitting up each signal for each pixel. If you take it to an Apple store, they will be able to save all your data and simply fix your hardware.
Jun 02, 2013 | Computers & Internet
My screen is now displayed upside down, how do I fix, i pressed something and it turned, help , it is a e machines laptop
My Laptop HP Pavillion TX2500 incorrect color display during bios and startup but when the laptop is hot it displays the correct colors.But if cold displays incorrect colors. what can I do?
Jul 18, 2011 | Computers & Internet
How do I hook up my lap top to another monitor. pressing FN and F4 doesn't seem to work or I'm doing something wrong.
Most laptops have an auxilliary video output, usually a VGA port (usually the color is blue with 15 tiny holes) on the side or an HDMI port. You can connect a monitor through these ports, and the display that should show on the laptop's lcd will be also displayed on the monitor.
Apr 04, 2011 | Computers & Internet
Samsung Syncmaster913v Monitor. The screen is totally black, but when I remove lead from computer it shows "Check Signal Cable" in colour. Also when I press Menu, in top left hand corner...
If the color still works, and it works on other computers, there is something wrong with the computer in question. But this is not the case, so logically, something is wrong with the monitor. Check the cable for broken pins.
Feb 11, 2011 | Samsung SyncMaster 913V 19" LCD Monitor
Screen and volume issues
Sounds like you lost your drivers.
Try (re)installing VIDEO and AUDIO drivers.
Did something (what) happen before these problems appeare ?
Did you reinstall or install Windows ?
Regards.
Mar 28, 2009 | Gateway M350 Notebook
Toshiba satellite m105-s3004
Possibly the lcd cable is not completely connected, driver could need to be re-installed, but more likely, the video is going out. That's very common in these Toshibas.
Sorry, wish I had it here, I could tell you in 30 minutes.
Good luck
Dec 03, 2007 | Toshiba Satellite A10-S100 Notebook
Compaq Presario Notebook Logo
60 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
