Looking for size of washer 3.2 3.5 ect model #lnc6762b71 admiral
  • 15,935 Answers
3.2cu ft.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 14, 2010
Admiral model lnc6762b71 tub dosen't center itself
Check balance springs at the bottom of the tub/drum. To gain access and remove front panel insert a knife or thin blade approx. 4" in the from each side in between the front seam on the front panel, this will release the lid clips, lift and hinge back the lid panel, remove the two screws securing the front panel and remove, there are 6-8 springs at the bottom, check all are intact.
Also check drum is rotating at full speed, if not check and replace drive belt below the machine, tilt machine back to gain access, flip belt off the pulleys and replace same way.
Nov 30, 2013 | Admiral Washing Machines
I am trying to figure out the size of my refrigerator in cubic feet.can you tell me its size? its an admiral top freezer model number NT17B6ST
I cannot find much on the model number - but from the look of it - 17 cubic feet
NT17B6ST
My best guess :-)
May 27, 2011 | Admiral Refrigerators
How do i take apart capcity plus admiral LNC6762B71. Will agitate, but not spin and theres a burnt smell.
I went to another website that was free and found a simular question that pointed me in the right direction....it was the ball bearings in the water pump that went bad.
Nov 20, 2009 | Washing Machines
The washer filledup over the limet and inondated
The pressure switch is located on control board. A tube connects from the switch to the bottom of the tub. To answer your question, it's right behind the wash size selector. There are many sites online to buy. If you give me your model # I can help you find one. I did try the model # you listed and said it didn't exist.
Feb 28, 2009 | Admiral AW22 Top Load Washer
Admiral Top Load Washer Model LNC6762B71 overflowed
Remove the control console cover. Find the water level switch.
It has a small tube attached to it.
Remove the tube and blow air through it. It is probably stopped up. Reattach it to the water level switch.
Look over the length of the tube and may sure it is not pinched.
Set the washer to spin and run spin for about 1 minute.
Then run water on a lower level and see if it shuts off.
If not replace the water level switch.
Washer belt is loose, & seem to slip at start of spin cycle.
there are several drive belts for this model... check here to see if the one you are fitting is the correct one... also,is the tensioner siezed? causing the tension to be too slack therefore allowing the belt to shred at speed?
check here .. http://www.partselect.com/AppliancePartList.aspx?Brand=Admiral&Appliance=Washer&ModelNum=&Type=Belt&MinSize=U&MaxSize=U&Electrical=U&Metal=U&Plastic=U&OneColor=U&PageSize=15&FirstPart=1
Dec 03, 2008 | Admiral AAV7000A
My Admiral waher model # LNC6762B71 will not spin or drain
with the belt off the pump pulley should turn freeley if it does then with the belt off and in the spin position start the washer with the lid down the motor should run
it it does then you have a transmission problem
if the motor does not run then there is a electrial componet problem
May 17, 2008 | Admiral AW22 Top Load Washer
Admiral Washer Model#LNC6762B71
if water leaks in the tub your water valve need to replace. and thelower bearing. i can let you know how much the parts are.and valve is not hard to replace but bearing is
Feb 18, 2008 | Kenmore 23822 Top Load Washer
Does not spin
the machine will agitate and pumpout the water but it will not spin
Aug 05, 2007 | Kenmore 23822 Top Load Washer
Washing Machines Logo
102 people viewed this question
Top Washing Machines Experts
