Question about Dell Latitude C400 Notebook
I took my Dell laptop to school and hooked up to the internet there. Now at home it will not pick up to my wireless internet and I cannot get online.
    President:
  • 2,653 Answers
Check your wireless network connections. I believe most Dell's use a special utility. Look for anything wireless related on the bottom right hand of your lcd. Can you at least see the wireless networks? If not you might want to double-check to see if you accidently switched the wireless power switch off. It's usually located somewhere around the sides or the front of the laptop.
Posted on Feb 21, 2009
Laptop wont connect to Di-614+
Since the Dell connects somewhere else, you know its wireless stuff is working. You may have signal issues at home, either low strength or interference. Try repositioning the router. Change its channel through the router setup page to see if that helps. Also be sure you have your security settings right in the laptop. This should get you going.
Feb 01, 2010 | Computers & Internet
My Acer laptop wireless not working. It was
first network setup wizard then u try the internet through wireless
Nov 16, 2009 | Acer Aspire 5500 5570-2609 Laptop
My Dell Inspiron 1525 works well finding unsecured
I don't know if you are using the standard Windows wireless LAN management, or the special DELL application for that. Anyway, try looking for a profile of that particular network in WLAN management (either Manage Wireless Networks in Windows networking, or something to that effect in in that DELL WLAN profile management) and deleting that profile, making it possible to search for it again "for the first time", so to say.
Nov 04, 2009 | Dell Inspiron 1525 Laptop Jet Black
ZyXeL P320W Won't connect to internet
check weather urwireless zero configuration is disable go to the my computer right in that manage in the manage go to the services in that go to the services in that one service is there in down wireless zero configuration just start it if already start just go for the restart
Mar 28, 2009 | Zyxel Prestige 320W Wireless Firewall...
Adding laptop to home system through Belkin59G .
Good Day!
I believe you are trying to connect wirelessly using your laptop to your wireless router(Belkin 59G). Try to hook it up first on your computer and check if you can go online.
If yes, then that's the time you go to the router's set up page and check the wireless security of the router so that you can connect wirelessly.
If not, then you have to reconfigure the router and the modem. If your internet service provider is cable you can just turn off the router then the modem and waitfor 5 seconds. Turn on the modem, wait for the lights to turn on then the router. After that, check if the computer will be able to go online when connected directly to the router.
Feb 10, 2009 | Acer Computers & Internet
I am a teacher at an elementary school and I am trying to connect a Dell Wireless 1450 Wireless USB adaptor to a brand new Dell computer. We have wireless internet at our school. I cannot get the thing to...
hi..
so you are not able to see the networks at all,1st make sure that we are detecting the wireless network and that the drivers are installed in the computer
follow these steps..
click on start,control panel,network and internet connection and then network connection.
2)under network connection you will see a conneciton that says wireless network connection.
3)right click and click on view wireless networks,once you are in this box if it says windows cannot configure then perform step number 5 and if you can see the network perform steps no 4.
4)you will probably see the network of you school,click on the netwokr name and you will see a tab that says connect,click on connect and if the network in your school is secured then it will tell you to put in the password which you can get by speaking with the network administrator..once connected it will tell you that you are connected and then try going online..
5)if no networks are detected and says windows cannot configure,click on start,all progams,dell wireless and then click on dell wireless wlan card utility,
6)In this card utility you will see a that says general and under that tab you will see a box which will shows you the available networks then click on the network and then either you will have a connected button or cofigure button now depending upon the network it will either tell you to put the password or the network key once you do that the wireless should get connected and you should be able to go online now...
hope this steps will resolve the issue...Best of luck...
let me know incase if you see a different screen..
vedhick
Jan 14, 2009 | Dell (T2349) Wireless Adapter
How to get online
You need some kind of wireless internet card that can pick up signal from anywhere, unless there is a wireless internet connection nearby that you can pick up.
Jan 08, 2009 | Dell Latitude D505 Notebook
Inspiron 6000 has trouble picking up wireless signal
Some wireless cards are better than others at picking up weaker signals.
The problem with any wireless transmissions is that radio signals cannot pass through metallic surfaces.
You should position your wireless router away from metallic surfaces/walls and position your laptop so it can receive the radio signals without it passing through any metallic walls. If possible place the wireless router higher than at desk level.
Dec 26, 2008 | Dell Inspiron 6000 Notebook
Laptop won't detect wireless connection (but does detect others)
Dearest crystal 7, you prombally need to reset your windows
wireless. go to add and remove and remove the wireless
drivers the reboot your computer and the reinstall your wireless driver ,then go to the control panel go to internet options then to connetions then scrow down to lan settings the put a check in atuomatically detect settings the apply then ok . the reboot your computer then set up your wireless for connections for your house and it should work ...... lala linda
Jun 20, 2008 | Computers & Internet
Dell Latitude C400 Notebook Logo
94 people viewed this question
Alun Cox
