Question about IBM ThinkPad T40 2373 Notebook
USB still on despite Thinkpad going to standby
I am facing a peculiar problem.
I have a Thinkpad T40 which has been recently installed with a fresh copy of Win XP Pro. I have set the appropriate power properties on the laptop to go to standby when the lid is closed. This works fine. However, the cooling fan which is connected to the USB is still running even after the laptop goes to standby. This is true when the laptop is connected to AC power or when on battery.
I am experiencing this only after the recent XP pro install.
How can this be possible? How is the USB still getting the power to operate the cooling fan despite going on standby. Please assist.
I have a thinkpad t40 every i put a usb allways hang what should i do?
Two possible reasons why your PC always hangs after you connect the usb drive,
  • The usb drive contains viruses which are blocked by your PC's antivirus from entering the machine.Run a full scan of the usb drive with an updated anti-virus.
  • There are no installed drivers for the usb drive.Install the drives drivers.
Hope this helps.Thanks!
Please rate this answer.
Oct 29, 2011 | IBM ThinkPad T40 2373 Notebook
IBM ThinkPad T40: the problem is the following Modem HSP56 MR( Intel) doesnot work, Other devices:Nework Controller and unknown device doesn't work
Windows is missing the "device-drivers" for your network adapter and your modem.
On a different computer, access IBM's ThinkPad web-site, and download those device-drivers for your T40. Copy the device-drivers to either a CD-writable or to a USB memory-stick.
Move the media to your T40, and install from that removable media.
May 10, 2011 | IBM ThinkPad T40 2373 Notebook
My IBM thinkpad turns off when i insert my usb internet connection into the usb slot and then wont turn on for a day or 2. What could this be?
It sounds like some sort of power drain or short on the motherboard. I recently made a repair job on a T41,casing on an IBM thinkpad T40 AND T41`S are very week.
My advice to you would be reinstall windows and see if it does it again,If it doesn`t then you will know for sure that it had something to do with windows.IF it still does after a clean installation of windows then its clearly a hardware fault.
*Hardware fault could be you`re power supply not giving enough juice(unlikely) *Motherboard faulty/Or Shorting somewere.If thats the case then a refurbished motherboard would do the trick.
Oct 18, 2010 | IBM ThinkPad T40 2373 Notebook
My lptop IBM ThinkPad T40,when I boot it boots very slowly,hepl how to increase booting speed
Booting slow could be Ram or Virus..Do u have 1gig or more ram..extra ram could be helpfull..fresh install will certainly help...don't forget to take back-up before u attampt any thing...hope that's some help..good luck cheers
Dec 22, 2009 | IBM ThinkPad T40 2373 Notebook
I have Windows 7 installed on a IBM ThinkPad T40. I installed the OS recently but i'm not able to find the correct wireless driver for it(built in one i did not install any additional drivers). Can someone...
yes you going to need everest (http://majorgeeks.com/download4181.html ) and identifie the wireless card next tipe the wireless card number and modell and drivers for windows7 on google and will find it for you thanks
Oct 11, 2009 | IBM ThinkPad T40 2373 Notebook
Wharfedale MP3 player won't install to IBM Thinkpad
GO INTO CONTROL PANAL AND GO TO ADD NEW HARDWARE AND LET WIZARD DO IT JOB
Feb 12, 2009 | IBM ThinkPad T40 2373 Notebook
T40 manual
Hi friend rascie_1959
No need to buy any manual
here is the link for you
T40 IBM Thinkpad manual
http://www-307.ibm.com/pc/support/site.wss/product.do?template=/product.do?template=%2Fproductpage%2Flandingpages%2FproductPageLandingPage.vm&sitestyle=lenovo&brandind=10&familyind=117057&machineind=0&modelind=0&partnumberind=0&subcategoryind=0&doctypeind=8&doccategoryind=0&operatingsystemind=49979&validate=true
Jun 18, 2008 | IBM ThinkPad T40 2373 Notebook
IMB ThinkPad T40 wireless connection...
You need to go through the eternet port or even the usb port to access the internet..When online you can vist the manufactorors website and get all the drivers needed for the wireless adaptor...
Jan 03, 2008 | IBM ThinkPad T40 2373 Notebook
ThinkPad T40
If you can make the problem come and go by slightly twisting or flexing the bottom (keyboard) section of the case, you may have a loose internal connector. If the laptop has been dropped recently, more probably you have a cracked land pattern on the motherboard.
Oct 17, 2007 | IBM ThinkPad T40 2373 Notebook
ThinkPad T40 2374 no longer recognizes dvd's
go to www.driverguide.com to get your driver they have an extensive database of drivers that you will need and registration is free
Oct 01, 2007 | IBM ThinkPad T40 2373 Notebook
IBM ThinkPad T40 2373 Notebook Logo
111 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
