Question about LG RC-197 DVD Recorder/VCR
LG RC-288 disc problem
I have tried all types of DVD discs, but each time it says "no disc" inserted can you help
    Master:
  • 416 Answers
You need to use CD/DVD lens clening disk. If wont help gently clean the lens with Q-tip and 40% vodka or 50-70% rubbing alcohol
Good Luck
Posted on Feb 21, 2009
  • Grigory Zyryanov Feb 21, 2009
    Also make sure that disk is not upside down
Hyundai 320-A dvd player codes
Hyundai DVD-320A / DVD-360A / DVR-510C
  1. Method 1:
  2. Turn on the player (without a disc inserted)
  3. Press 7, 7, 0
  1. Method 2:
  3. Press 7, 7, PLAY
  4. Select region (0 = multi-region)
  5. Press SETUP
  1. Method 3:
  2. Open the disc tray
  3. Press 3, 8, 0, 0
  4. Select RC (0=codefree)
  5. Press SETUP
  6. Close the disc tray
Apr 20, 2016 | Hyundai Televison & Video
LG GSA-2166D doesn't recognize a dvd+r disc
I would suggest getting a can of air and blowing it out real well. May take a couple of tries to get it clean. When these types of units set unused for a while, the various sensors get dirty. Sometimes the problem can be cleared up by simply inserting and ejecting the media 8 or 10 times. Let it run up to speed each time.
R-
Nov 07, 2007 | LG GSA-2166D DVD RW Dual Layer Burner
Wat should i do when is displays no disc
Hello
If your DVD player shows no disc, even a disc is inserted, try to clean its laser head assembly, by inserting a cleaning disc in it and play atleast three times. Take it ejected each time before you play it. If it does not helps, open the top cover of your DVD player, insert a disc, and notice if the disc spins or not. If disc spins, and not reads, the laser picup unit of your DVD player is faulty, and should be replaced with same type and number. If its stripe wire connected between pickup unit and main board is detachable, try repalcing the strip wire first. In some occations, bad strip wire will show this type of problem.
If disc does not spins, the sled motor [the motor that used to spin the disc at high speed], is damaged and shoud replace it. OK.
Apr 07, 2011 | GE DGE100N DVD Player
How do I make this model region free?
I've found this on a site. Please post back with results. "Desired RC" is region code. '0' is region free.
  1. Power on (with no disc inserted)
  2. Press PAUSE
  3. Press 3, 1, 4, 1, 5, 9
  4. Enter the desired RC
  5. Press PAUSE
  6. Turn the player off and wait a few seconds
  1. VCD playback
  2. Press PAUSE, 1, 4, 7, 2
  3. Press UP 6 times, '07 00' should appear on the display
  4. Press Program 6, Program 5 ('07 FE' should be displayed)
  5. Press ENTER
  6. Press RETURN
  7. Power off and on again
Apr 15, 2009 | Televison & Video
Samsung dvd-v5600 is set on region 4
This code is for DVD-5500 and DVD-6500. It may work for DVD-5600 as well.
  1. Turn on the player (without a disc inserted)
  2. Press and hold PLAY and FW (or STOP)
  3. "No Disc" is displayed
  4. Release the keys
  5. Press SUBTITLE, REPEAT (or just SUBTITLE or just REPEAT or MENU)
  6. Enter the corresponding combination for your current RC (see top of the page)
  7. Current RC should be displayed
  8. Press the button for the desired RC (9=codefree)
  9. Open the disc tray
  10. Turn the player off
Apr 13, 2009 | Televison & Video
Region code for Samsung DVD-R100a
This is one for DVD-R100 (not R100A). Tell me if it works.
  4. Release the keys
This is another I found.
  1. Power on your player with no disc in the tray
  2. Press REPEAT for 5 seconds
  3. Enter the corresponding combination for your current RC (see top of the page)
  4. Current RC should be displayed
  5. Press the button for the desired RC (9=multi-region)
  6. (Press OPEN)
  7. Power off your player
Apr 12, 2009 | Samsung DVD-909 DVD Player
No disc present
Try running a cleaner disc in the unit if that doesnt work try the following.
Starting at my computer... Right click on my computer icon.
Go to properties.
Then Hardware tab then go device manager. Right click on cdrom in device list. Select uninstall then reboot the computer. If this doesn't help replacing the unit will be necessary.
Jan 19, 2009 | LG GCC 4480B CD-RW/DVD-ROM Burner
How to unlock LG dvd/vcr model no/ v782w
try that:
  2. Press PAUSE
  5. Press PAUSE
  1. VCD playback
  5. Press ENTER
  6. Press RETURN
Dec 28, 2008 | LG V181 DVD Player/VCR
I am looking for the region unlock code for a LG DVD model DV4741P. Cna you help?
It uses the same unlock code as the LG 4721P and a number of other LG DVD players.
  2. Press PAUSE
  5. Press PAUSE
It took me a couple of times to get it right because if you take too long to press the correct buttons it does not work. I chose region code 0 so it now plays all regions.
Sep 27, 2008 | Televison & Video
Samsung dvd-r155 unlock region code
Region codes for Samsung:
RC 1: 2, 9, 3, 3, 4
RC 2: 3, 8, 7, 6, 7 (or 5, 7, 5, 3, 8)
RC 3: 5, 6, 7, 3, 2
RC 4: 7, 6, 8, 8, 4
RC 5: 5, 3, 8, 1, 4
RC 6: 2, 4, 4, 6, 2
1.Turn on R155 without disc inserted
2. Press and hold Play and Stop for 5 seconds then release
3. Press menu
4. enter code for current region as above i.e if you have a region 4 type: 7, 6, 8, 8, 4
5. The region is displayed in the top right.
6. You have about 5 seconds to enter the new region (1,2,3,4,5,6 or 9 for multiregional)
Works just fine on my region 4 R155. Hope this helps.
Aug 03, 2008 | Televison & Video
LG RC-197 DVD Recorder/VCR Logo
974 people viewed this question
Computer Repairing
Computer Repairing
