Question about Toshiba 57LX177 Television
Toshiba 57LX177: Right side of screen darker than left
Toshiba 57LX177: Right side of screen darker than left, occasionally displays horizontal lines and pixelation on right. Is this related to inverter board?
I am not sure...but I have the identical problem. I believe the vertical lines are caused by the inverter board and the darkness is caused by the one of the back lights that needs to be replaced. I am tearing my unit apart now and will find out.
Posted on Aug 09, 2010
I have a Toshiba 55L6200U that recently started showing horizontal lines that are darker on the right half of the screen and lighter on the left side. These are visible with any input or on TV and also...
Back - light problem. [CCFL lamps inside it]. Check and replace damaged CCFL lamps. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Aug 29, 2015 | Toshiba Televison & Video
Panasonic 37 inch lcd tv
Check its back light CCFL lam of that side, which look darker. Replace it.
Jul 15, 2012 | Panasonic Viera TC-37LZ85 LCD TV
Dark line down the middle of my flat screen tv
Most LCD and PLASMA sets use two boards (some combine them into one board) that drive the Display Panel (the entire front screen unit) so I would suspect one of yours is bad.
The other unpleasant possible cause is where the left board is connected to the Display Panel (entire front screen unit) you have a problem inside that Display Panel and that is fatal as there is no way to get INSIDE the panel---it can cause both lines and a dark picture on one side of the screen.
May 25, 2012 | Sylvania Televison & Video
Hi, Expert: I have a 52" Sony LCD TV (
Hello
If I send you its schematic diagram and give you instructions, can you follow me?
Oct 18, 2011 | Televison & Video
Fine color vertical lines in right and left side of screen
One of two things could be wrong.. One is the digital board and or connector. the second is that the LCD display is going bad..
Jan 28, 2009 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
How to fix horisontal lines on display ( see the picture)? They stronger when system is restarted and then fading but never disappearing. They always stay the same.
horizontal lines can be caused by either a faulty grapchics card or a faulty monitor. try adjusting the screen refresh rate. if you are using a windows xp system goto
start>control panel>display>settings>advanced>monitor
then adjust the screen refresh rate and see if the horizontal lines disappear. if not, then you probably have a faulty graphics card or monitor.
Jan 27, 2008 | XFX GeForce FX 5200, Graphic Card
Grey line horizontally across screen
yOU ARE HAVING A PROBLEM IN HORIZONTAL CIRCUIT OR IN YOUR POWER SUPPLY kindlyu take your T.V tO A QUALIFIED TECH to repair it.ypur problem could be a faulty capacitor ,flyback or horizontal output transistor.
Feb 16, 2007 | Sony WEGA KLV-26HG2 26 in. HD-Ready LCD...
Toshiba 57LX177 Television Logo
290 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
