Question about Keurig B50 Coffee Maker
Menu cycles through the options non-stop
When the unit is turned on, it behaves normally until it gets to the point where it is ready to brew. At this point (After the Kcup has been loaded) the menu begins to cycle through all the options (clock, auto start, etc.) and finally back to the "ready to brew" screen. But only for a quick flash, then through the menu options again.
If I time it just right, i can get it to brew by pressing the cup button when it gets to the main screen, but it really is a pain.
It doesn't appear that a button is stuck, but I think it is behaving as if the menu button is always being pushed.
Any ideas?
    Problem Solver:
  • 25 Answers
Have you tried unplugging the unit? Sometimes the machine will get caught in a repetitive "cycle" and needs to be re-set. If this does't work, let me know
Posted on May 14, 2009
  • poclitar
    poclitar Feb 08, 2013
    tried thta and it doesnt work, have any other suggestions?
It goes through all the cycles but no hot water comes out. Unit is two months old.
Have you tried brewing with no k-cup in the unit? If water comes out then the needle that punctures the bottom of the kcup needs to be cleared out. I use a paper clip and put it into the kcup holder where the puncture needle is. I move it up and down the hole until cleared out.
Jul 19, 2014 | Keurig Elite B40 Coffee Maker
Helpline
Sounds like a cleaning problem. Mix 1/2 vinegar and 1/2 water pout into machine and brew,WITHOUT K CUP! Do 5-6 x's and then brew plain water to rinse vinegar out. Do this several times. Should be ready to go.
Mar 31, 2014 | Keurig Coffee Makers & Espresso Machines
Why are all lights flashing on my keurig kcup maker
lights are flashing because you need to decide how big of a 'cup' you want to brew. When you push one of the flshing brew buttons, the unit will brew and the lights will then stay on steady until you reopen and add a new K-cup.
Apr 15, 2013 | Keurig Platinum B70 Coffee Maker
Lg dryer dle7177 cutting off during cycle
I had a tumble dryer that stopped working and after much investigation it turned out to be an internal thermostatic switch and lots of fluff around the internal filters. ( Mine had 2 of them 1 would cut the heat and kick back in when the temperature dropped and the other one would completely cut all power rendering the drier non usable until cicuit breaker thermostat was replaced. The reason they cut out is to prevent overheating and possible fire. When the thermostat gets to certain temperature it breaks the circuit. Apparently you shouldn't stop the drier until it has completely cooled down as there will be too much heat which could cause a fire, which is why most drier cycles have 10 minutes of cool/ non heated air at the end. So in conclusion I would take all the filters out and give them a good clean and try to avoid opening the door while there is still a lot of heat in the drier. I'm not sure if this will help but its a starting point.
Feb 03, 2013 | Dryers
Saeco Vienna - I turned on the coffee machine and instead of the usual whirling of the parts getting into place, it sounds like it is struggling to get into place. I looked inside and the bar is down where...
Hi Its hard to say with what you have said, but if the brew unit was cycling slowly, it may be the board. Close the door and make sure that everything is in but the brew unit. Turn the machine on and see if it cycles the gear in back to the starting point. It may take a few minutes to cycle if its the board. If it returns its the board. I have some boards.
Jun 13, 2011 | Saeco Vienna Espresso Machine
Only brews half a cup on the largest cup setting?
1.Power off machine.
2.Using a metal paperclip, insert it into left side of top needle. It must insert at least 1" deep.Insert it into slot on right side and again from back of needle.
3.Remove KCup cradle.Separate bottom from top.In the top section, insert the paperclip up into bottom needle from the bottom upwards.It will not go all the way thru and this is normal.
4.Reassemble KCup cradle and reinsert it back into coffee maker.
5.Power on machine.
6.Brew a cup of water only.There may be coffee grounds in the water and these should eventually clear during the remaining steps.NOTE: A large cup brew cycle should output a full 8 ounces (235cc).Less means there is still a blockage
7.Empty reservoir and fill with undiluted distilled white vinegar.Repeatedly run brewing cycle until Add Water light comes on.
8.Make sure Auto-OFF is NOT set and let last cycle of vinegar remain inside machine for 4 hours.
9.Refill reservoir with fresh water and repeatedly run brewing cycle until the water is clear and odorless.
10.Set Auto-OFF, if preferred.
Mar 26, 2011 | Keurig Special Edition B60 Coffee Maker
Won't brew only drop at a time wiuth coffee grounds ]
5.Power on machine.
Mar 26, 2011 | Keurig Platinum B70 Coffee Maker
Motor stuck in brew postion wont reset even with the brew group out
Hi
Leave the brew unit out but put everything else back in and then turn the machine on. the brew drive should reset to where it should be so you can put the brew unit back in, but make sure that the brew unit is ready to install.
You must make sure that the brew unit is ready to reinsert into the machine. To return the brew group to the centered position, you first need to drop the funnel. To do this, look on the opposite side of the brew group from the handle. At the top you will see an object that looks like a sharks fin. If you follow this piece down you will see 2 horizontal bars on the brew group body. Push your finger between these 2 bars and the funnel will drop. If you have you key you can insert it in the front of the brew unit. There is a round hold in the center below the "Push", and twist it clockwise until it stops and the 2 marks are lined up. If you don't have your key you can do this. Push the puck slide on the left side down and to the center. If you look down through the funnel you should see a piston. This should be centered in the funnel. If not, locate the slide on the left side of the brew unit, (it should be hanging down, a flat rectangular piece attached to the cylinder) and push the slide to the right until it does. Press the "Push" lever until you hear a click and you are now ready to reinsert the brew group in to the machine.
Dec 31, 2010 | Saeco Incanto Classic Espresso Machine
Keurig B-60 will NOT draw up water from reservoir (or even when using vinegar). How do I access the water line to see if it is clogged? The unit has been in storage for about 7 months.
1. Power off machine.
2. Using a metal paperclip, insert it into left side of top needle. It must insert at least 1" deep. Insert it into slot on right side and again from back of needle.
3. Remove KCup cradle. Separate bottom from top. In the top section, insert the paperclip up into bottom needle from the bottom upwards. It will not go all the way thru and this is normal.
4. Reassemble KCup cradle and reinsert it back into coffee maker.
5. Power on machine.
6. Brew a cup of water only. There may be coffee grounds in the water and these should eventually clear during the remaining steps. NOTE: A large cup brew cycle should output a full 8 ounces (235cc). Less means there is still a blockage
7. Empty reservoir and fill with undiluted distilled white vinegar. Repeatedly run brewing cycle until Add Water light comes on.
8. Make sure Auto-OFF is NOT set and let last cycle of vinegar remain inside machine for 4 hours.
9. Refill reservoir with fresh water and repeatedly run brewing cycle until the water is clear and odorless.
10. Set Auto-OFF, if preferred.
Nov 20, 2010 | Keurig B60 Coffee Maker
Keurig B50 Coffee Maker Logo
424 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
Lisa
Lisa
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
