Question about Jandy Laars LX Pool Heater / 400,000 BTU / Natural Gas
My Heater is leaking water from underneath.
I have a Jandy Laars LX pool Heater that is 5 years old. The heater is leaking and it looks like a heater core leak as opposed to a gasket. I works fine and is only lightly used for occasional spa use. Can the core be replaced as opposed to spending thousands of dallars on a new one?
There are different heat exchangers available. Go with a Cupro Nickel if you are using a salt chlorine generator or if you have a tendency to over acid at times. Standard copper heat exchangers are less durable.
Posted on Jan 10, 2012
  • 22 Answers
Yes you can replace the core but you should check all the other components to be sure the chlorine hasn,t destroyed them.
Posted on Feb 21, 2009
What does the pressure control switch do on a Jandy lx heater?
it shows that the filter pump is working and that you have water flow through the heater
Jun 01, 2014 | Jandy Laars LX Pool Heater / 400,000 BTU /...
How do u remove hi limit switch from a Jandy LX 400N-L heater model#LX400N-L
high limits are located at header where pipes go in underneath
if those are ok check fusible link maybe 2 one at bottom one at top under top cover
Aug 15, 2013 | Jandy Laars LX Pool Heater / 400,000 BTU /...
So we have the jandy laars lx.... we have had it for 3 years no problems we use it with pool and spa and its gas........ the buttons work you can choose pool or spa just fine but when you choose one... the...
This heater wont start if the pressure switch is bad or clogged. Remove the pressure switch and clean it out really well, or just purchase a new one. It should only be $30-$50 depending on where you go to get it
May 03, 2011 | Jandy Laars LX Pool Heater / 400,000 BTU /...
Noticed water leaking a lot from bottom of unit. Looked like a pretty good leak. Unit is 9 years old. Leaks when Pump is running
More than likely the heat exchanger. Has the pH and Total Alkalinity been low? Check the Pressure/Temp relief valve, thermostat probe, high limit switches, etc. first though...
Jun 12, 2010 | Jandy Laars LX Pool Heater / 400,000 BTU /...
My laars lx pool heater is blinking LOW PRESSURE. How do I fix?
The heater needs good water flow or it will overheat. You probally have a full basket in your pump or your filter is dirty.
Jan 20, 2010 | Jandy Laars LX Pool Heater / 400,000 BTU /...
How do you replace an air flow switch in a Jandy LX pool heater?
order the flow switch open the door take off hoses take screws off reverse with new air swtch just dont send the old one
Aug 16, 2009 | Jandy Laars LX Pool Heater / 400,000 BTU /...
Pool heater will light then turns off
check gas pressure you should be getting about 10" water coloum
May 31, 2009 | Jandy Laars LX Pool Heater / 400,000 BTU /...
Jandy Laars LX Pool Heater / 400,000 BTU / Natural Gas Logo
477 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Bill Jordan
Craig Butler
Craig Butler
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
