Question about Maytag PYE2300AY Electric Dryer
Maytag dryer not starting
Maytag dryer. About 4 years old. Sparingly used.
It is not starting anymore although there is power to dryer. Similar problem in very first year under warranty stated that sryer may get overheated and shut down. There is something to reset in bak.
Any clue why overheating and how to restart?
  • liquid_dwayn Mar 12, 2009
    Dishwasher fills but won't start. After the fill cycle is complete I can hear what sounds like a 2 second ground hum. This repeats 4-5 times before the dishwasher simply shuts down. I can cancel the cycle and it will drain fine.
  • Maytag Master
  • 3,361 Answers
You must replace the hi limit thermostat and the thermal fuse.
They come as a set and must both be replaced.
They are located on the heating element.
Posted on Feb 21, 2009
Maytag MED5700TQ Electric Dryer lost all power
Hopefully you still have your manual-if not dwn load this one and go to page 23
Download 20W10150608A.pdf initiated. If download did not start, click here to try again.
Dec 29, 2012 | Maytag MED5700TQ Electric Dryer
My Maytag Centennial elec dryer won't dry well
could it be the thermasat are all the wires connected
Jan 01, 2012 | Maytag Dryers
The dryer wont start and yes, it is getting power. The dryer is not quite 2 years old and doesn't get heavy use. There are 2 of us with sometimes 4, but not often. Not a happy camper at this point.
There has been a lot of problems with the door latch (4027EL1001A) and switch (6601EL3001A) on LG dryers. Almost all of the calls we respond to with a - Won't Start has been these items. Although they are inexpensive to replace, they seem to be designed to fail often! And client take it out on the technicians instead of the manufacturer!
Jul 01, 2011 | LG DLE2516 Electric Dryer
Maytag my dryer just makes a humming noise without spinning. then i got it to start spinning again. this is a new problem never had it before although the dryer is 15 years old
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Dec 23, 2010 | Maytag PYE2300AY Electric Dryer
Old maytag gas dryer. Does not heat anymore, gas
Maytag dryer series 05. How do I light the pilot?
Apr 04, 2010 | Maytag Dryers
My 5 year old Whirlpool dryer just didn't start one day.Instead of dealing with repair,we got a used 4 year old Maytag dryer.It dried the first load,then when I pushed the start button it made a weird...
It is the motor winding shorted out which caused the smell. If you still have your old dryer the safty thermal located on the exhaust housing is blown. White plastic with 2 wires going to it. Very inexpensive repair. Hope this helps.
Feb 13, 2010 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
My Maytag Atlantis MDG6400AWW will not heat up. The drum spins but the clothes don't dry!
my dryer timer is not turning off and it does not get hot,I check glow coil.its working but it does not fire up.I smell gas some time
Apr 16, 2009 | Maytag Atlantis MDG6400AW Gas Dryer
Maytag Quiet Series 200 Electric Dryer
I also had a similar problem with my maytag dryer which is 3 1/2 years old. It was the idler lever assembly with pulley. The part number is 11222607JG and the cost is about $20.00. Hope this helps.
Apr 04, 2009 | Maytag Dryers
Maytag Atlantis MDG8400AWW Dryer Runs Cool
I had a similar problem years back. It was the ignitor. The ignitor is a ceramic like piece that heats up (glows red) that ignites the gas. Typically when that goes, you will see some white residue build up where it cracked, thus breaking the electrical connection. This thing works like a heating element on an electric stove, but rougher looking.
The part was about $30 at my local parts store. I bought an extra one just in case so I have it on hand. I installed it with common tools.
You can check it to see if you lost connection by using a volt meter.
Good luck.
Dec 29, 2008 | Maytag Atlantis MDG7400AW Gas Dryer
Maytag DE 412
Does sound like the timer, although the clock is moving, the contact for the heater element is burned out inside the timer, you probably have used this timed dry for your normal day to day use and worn out the contact, new timer required.
May 25, 2008 | Maytag PYE2300AY Electric Dryer
Maytag PYE2300AY Electric Dryer Logo
308 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
