Question about Arris Wireless G Broadband Router (wr850g)
Can't access WR80G. Sniffers detect it ESSID, signal, etc. Leds green. bt doesn't comunicate.
Can't access WR80G. Sniffers detect it ESSID, signal, etc. Leds green. But doesn't comunicate. I could save ethercap or etherreal captions and send them attached. I had reflashed it some times. I had recovery from broken state by reflashing it first whith 4.03 firmware, later with 6.14 and whit freifunk in the last instance. It had bricked before, after my trying to recover deffault settings. But now, I select dhcp in wan config. (freifunk) since I did think to use it like a second node in a two moto's net. I aplied changes without change the lan addres previously. I think that could have been an error. I have reseted it some times since then.
  • 6 more comments
  • Anonymous Aug 02, 2007
    Thanks you both for trying, only a few hours after my asking.
    I know manuals. I had handled default IP addresses. My PC has actually 192.168.10.2 and is conected to another identical router managing several pc's routing.
    I suspect my speech is not clear enough as I'm not english speaker but reader.
    If it's not an abuse I could upload files from etherreal sniffing when pc is cable conected to the unaccesible router. If you or anymore can analyse.
    Any activities are detected between the own router's MAC addresses but the PC eth adapter MAC is absent all over those captions.
    When attempting a dhcp conections to router, the result is limited or null conectivity and a 169.x.x.x ip address.
  • Anonymous Aug 03, 2007
    I'm Sorry. I don't understand this ranking sistem, but no one is best solution since no one solve my trouble. It is more complicated than IP-ing...
    How is aug 3 to you and aug 2 for me? (gmt-5)
    I can't ping but leds are correctly green ligthing as I cable connect wan or 1-4 lan ports.
    I don't know to use ethereal or ethercap, but I command etereal to snif eth0 (from hax puppy), and it catch and can show captions.
  • Anonymous Aug 04, 2007
    No. I don't know how to ping mi pc card from my own pc.
    It's posssible?
    what could thatt be usable to?
    Router doesn't respond ping.
    But snifer software can detect some traffic. Reports show the respective router's MAC's.
    Smooth_Gecko,Do you know how to understand that reports. They can be shown in plain text.. Thanks you
    P.S. My ethernet card isn't gone.
    I used it to sniff whith etereal connecting pc-router by cable ports 1,2,3,4 and wan port. O.K.?
  • Anonymous Aug 07, 2007
    Nothing have hapened. both Genius2k4 and Smooth_Gecko solutions asumes I can communicate with router using an IP address.
    I suspect its possible sending a firmware to MAC address, using fttp or another protocol.
    Router is not responding pings.
  • Anonymous Sep 05, 2007
    I did ping -t 192.168.1.1 in a dos window for many hours without sucess. Suddenly it begin to respond. I had reflashed by using another DOS window, while it was responding, as I had learn previously, and Voila! it is working now.
    Thank you guys for your helping me.
    Scholar:
  • 125 Answers
Try setting your PC to DHCP in your network connection settings, plug in ethernet cable & reboot it.
Posted on Aug 02, 2007
  • 3 more comments
    The authentification is where I would look next. I chased a limited or no connectivity problem for a while the other day, and it turned out to be in there.
    Can you ping the ethernet card and the router?
    Can you ping the card in the PC, from the PC?
    I am getting the feeling your ethernet card is gone.
    You should be able to ping your card and the router as long as you have a cable plugged in.
    Quote "My PC has actually 192.168.10.2"
    From "run" on the main menu, just type "cmd" to get a console.
    Type "ping 192.168.10.2"
    and hit enter.
    Then try pinging your routers IP address.
    Until you can ping the router reliably, nothing will work.
    Sorry, I didn't read properly.
    Have you done what Genius2k4 suggested?
    What happened?
    Pleasure
  • 27 Answers
If you have set it to dhcp on wan only then your local pcs will not be issued an IP address unless dhcp over lan is enable you could try setting a static ip on your local pc but it has to be in the same range as your router, your routers default IP address is 192.168.10.1 so set your pcs ip to 192.168.10.12 and of course try talking to your router via the ethernet cable not just wireless. Link to Manual.... www.motorola.com/mdirect/manuals/WR850G_User_Manual_E.pdf
Posted on Aug 01, 2007
SOURCE:
How do i locate audio and video spy devices someone has planted in my home?
There are little receivers you can purchase that are wide banded an as you walk around the house holding the the receiver near objects it will buzz. Telling you a radio signal is in that area. You can make one very cheaply. If you search ebay, youtube you will find devices people have used. Some are called sniffers, locators, etc.
Jan 28, 2015 | Audio Players & Recorders
Rear turn signals
Often LEDs have difference electrical tolerances and are not compatible with other systems without special adapters to balance conductivity etc.
Jun 22, 2014 | 2003 Harley Davidson FXST Softail Standard
Flashing lights in the front of ibisurfer
vid shows nothing leds are to tell u something not just diagnostic ie most pcs / laptops have a light that flashes a lot telling u when its comunicating with the hard disc drive thats perfectly fine does the system run ? whats happening ? is it just the led worrying you with no obvious symptums we need info to help whats wrong what is it
ie make acer
model aspire 1283
seriels etc every bit of writeing on it
that tells us what were dealing with
then we need the most informitive description of the problem ie
system boots to bios but when you try to load windows it says (xxxxxx) there is a led on the front that used to show green but now just stays red
that tells us a heck of a lot more then you would think
once we know exactly what were fixing and exactly what its doing that it shouldnt be doing then we can help
Oct 28, 2012 | Computers & Internet
When I plug in the router, it doesn't do the checks all 3 LEDs are on. I also can't access the router settings nor the network i set up using the router
Without knowing the brand and model, I would say this router is defective. If the LEDS are not cycling through and remaining solid lit, this is a good indicator of a major problem. Try pressing and holding in the reset button (usually located on the back or bottom) for at least 30 secs. Some routers require disconnecting from power, holding in the same button and then restoring power and then releasing the button once the LEDS cycle. If the resaults are the same and the LEDS "freeze", then the router is likely defective and not repairable.
Aug 04, 2011 | Computers & Internet
I cannot pair my nokia e63 with genius bt-03i. seems the phone can't sense the signal from the headset or either the headset is not transmitting bluetooth signal
Make sure the blue-tooth headset is charged
Make sure the phone is set to automatically detect new blue-tooth device.
On the headset, press the power key for five seconds until the RED light blinks quickly.
Phone should detect headset within 10 - 30 seconds. It should eventually say BT-03A then ask for aOnce it does, type 0000 into the phone when it asked for a device ID.
May 05, 2011 | Genius BT-03A Bluetooth Headset
I have a Sitecom WL330 wireless repeater
Hi I'm having the exact same problem with a Sitecom WL330 and a BT business hub. Just get unidentified network when trying to connect. Did you resolve your problem? and if so how?
Thanks
Jan 16, 2010 | Computers & Internet
Connecting cell phone and Jabra
Check that both devices are BT enabled and in pairing mode -ie, leds blinking-. If one of the device is not in pairing mode, it is normal that the process fails.
If you experience the same problem on other phones with your Jabra BCE-250 -same as mine-, you might think of getting it checked first.
Dec 10, 2009 | Jabra BT250 Consumer Headset
My motherboard have four leds in red light, d0 dled2,dled3 and don`t start up
Hi ntamayo,
Here is the description of what the four leds indicate:
d9c5d26.gifSystem Power ON-The D-LED will hang here if the processor is damaged or not installed properly.
1d08ad7.gifEarly Chipset Initialization
14ff182.gifMemory Detection Test
- Testing onboard memory size. The D-LED will hang if the memory module is damaged or not installed properly
1719312.gifDecompressing BIOS image to RAM for fast booting
1cab634.gifInitializing Keyboard Controller
3b994fe.gifTesting VGA BIOS
- This will start writing VGA sign-on message to the screen
2b36bf2.gifProcessor Initialization
- This will show information regarding the processor (like brand name, system bus, etc...)
f53faac.gifTesting RTC (Real Time Clock)
9ec1db5.gifInitializing Video Interface
- This will start detecting CPU clock, checking type of video onboard. Then, detect and initialize the video adapter
4f7c881.gifBIOS Sign On
- This will start showing information about logo, processor brand name, etc
6a25253.gifTesting Base and Extended Memory
- Testing base memory from 240K to 640K and extended memory above 1MB using various patterns
1bef2e1.gifAssign Resources to all ISA
e664b69.gifInitializing Hard Drive Controller
- This will initialize IDE drive and controller
c3b6c58.gifInitializing Floppy Drive Controller
- This will initializing Floppy Drive and controller
3afd28f.gifBoot Attempt
- This will set low stack and boot via INT 19h
24b95b0.gifOperating System Booting
When your motherboard is stuck on any of these signals, that's a clue that something is wrong with that particular device on the board. Replace it and try again.
Good Luck
And don't forget to leave a rating,
Thanks
Mark
Sep 16, 2009 | MSI MB INTEL E7520|E7520 Master-S2M RTL...
LRD6399SWS
LED Display gives you your display visual alerts, signal strength, and operation mode. Here is an attached link for the manual.....http://www.uniden.com/pdf/LRD6399SWSom.pdf
But to answer your question here is what the difference between the green light and the red light are:
1. X-Band Signal Indicator—A green LED lights and blinks to
indicate the presence of an X-band radar signal. The blink rate
increases as the radar source gets closer. A distinct audio alert is
also heard.
2. K-Band Indicator— An amber (orange) LED lights and blinks to
indicate the presence of a K-band radar. The blink rate increases as
the radar source gets closer. A distinct audio alert is also heard.
3. Ka-SuperWideband Signal Indicator— A yellow LED lights and
blinks to indicate the presence of a Ka-SuperWideband radar
signal. The blink rate increases as the radar source gets closer. A
4. Laser Signal Indicator— A red LED under L lights and blinks to
indicate the presence of a laser signal. A distinct audio alert is also
heard.
5. SWS Signal Indicator— When an early warning hazard or
informational signal is detected, the yellow SWS LED begins to
blink and the amber K-band LED lights. A distinct audio alert is
also heard.
6. Power-On Indicator— A green LED under P lights to indicate
power is being supplied to the unit and the unit is turned on.
7. LED Signal Strength Meter—Four LEDs give an accurate visual
indication of the strength of radar or laser signals.
8. City Mode Indicator—A green LED under C lights to indicate
that you selected City Mode.
9. Auto Mute Indicator— A red LED under M lights to indicate that
you selected the Auto Mute feature.
Please make sure you give me a rating and I hope this helps,
cbinny1
Oct 18, 2008 | LRD6399SWS Radar Detector
How to use 1800 HG on a non BT IP
i got all green lights on my route and was working a week ago but for some reason it has stop work. please help
Jan 27, 2008 | 2wire 1800HG Router (RG1800HG00)
Arris Wireless G Broadband Router (wr850g) Logo
900 people viewed this question
Top Arris Computers & Internet Experts
Ekse
Greg Ulan
Ann Moroz
Ann Moroz
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
