Question about Sharp AR-5320 Black and White Copier
C0010 minolta di 30
    Sniper:
  • 87 Answers
IN MILNOLTA THIS CODE SHOWS THAT DRUM UNIT MOTOR IS NOT RUNNING.CHECK MOTOR S SUPPLY.OTHER WISE REPLACE MOTOR.CODE WILL BI REMOVED.DO NOT FORGET TO RATE SOLUTION .BY MIAN JEE
Posted on Feb 22, 2009
EP 3000 ERROR CODE COO10
Main Motor, remove the fuser and check the gears, also check the gears that are located in the back of the copier where pulled the fuser from. Also check the drum developer units
Jun 09, 2014 | Konica Minolta Office Equipment & Supplies
Why is amy copier throwing a sc 49-1 code?
What do you mean yo cleaned the control board?? Did you remove it????? IF you did major problem a Will have to go back and remove each connector looking for a bend pin and ensuring each connector is properly seated. Never remove board unless required. As for the code: please check code could not find in the service manual
May 22, 2014 | Konica Minolta Minolta Di 650 Di 551 Di...
How do i clear the user code on the minolta Di 2610
do you mean Di 2510 ???
Do you mean access code for adminstrator or the Password for accounts??
Mar 15, 2014 | Konica Minolta Office Equipment & Supplies
Error code sc23.03
Minolta Di 750 error code SC-23-01 i want solutions this code.
Sep 17, 2013 | Konica Minolta Minolta Di 650 Di 551 Di...
Error code c0-f24
Konica Minolta MINOLTA BRAND DIALTA... - Fixya
www.fixya.com/.../p4705803-konica_minolta_minolta_brand_dialta_89...
Konica Minolta MINOLTA BRAND DIALTA 8935-902 BLACK TONER TYPE 603AFOR USE IN MINOLTA DI-520 / MPN:8935902 SKU:1745166 - Recent Questions, Troubleshooting & Support. Recent; Popular · Answered ... Error code c0-f24.
Code c0510 in dialta 520 how to reset - Fixya
www.fixya.com/support/t16313340-code_c0510_in_dialta_520_reset
Feb 2, 2013 - Code c0510 in dialta 520 how to reset - Konica Minolta MINOLTA ...Home · Forum · Fax Machines · Konica Minolta · MINOLTA BRAND DIALTA 8935-902 BLACK TONER TYPE 603A FOR USE. ... BLACK TONER TYPE 603A FOR USE INMINOLTA DI-520 ... My minolta dialta copier has a c-of24 error code,.
C-0600 there is a code shown in my di520C-0600 tell me ...
www.fixya.com/support/t16673596-c_0600
Feb 14, 2013 | Konica Minolta MINOLTA BRAND DIALTA...
I have a minalta DI350 when I turn machine on the error c0010 come up seams that the motor is trying spin but can not can you help
remove the drum cartridge check the mechanical gear in that assy. try to rotate all the gears if its ok try to check the mechanical parts at the back of the machine to check the parts remove the back cover of the machine then inspect all mechanical gears & motor
Mar 27, 2011 | Minolta Office Equipment & Supplies
Minolta Copier EP 6000 copier error codes: C:C0010, C:C0992, C:C0410. Any ideas what these mean?
As for the C0992 code that deals with a paper draw fault, looking at the control panel do you see a small wrench located at the left hand lower corner. Touch it , it will take you to another screen when there open and close the front door, if the code comes back you have problem with main draw.
The C0410 is a problem with the very, bright lite under the big glass is bad. try to reset, open the front door to your left is a small access plate open and press trouble reset, if the code comes back replace the exposure lamp.
C0010 code main motor fault, remove the fuse unit the hot part and check for broken gears check the section where it goes look in the back for broken gears, remove the drum assy. check for broken gears, open close the front door to reset, If it comes back get a new main motor and or main control board,
Dec 03, 2010 | Minolta Office Equipment & Supplies
MInolta Di 183
Abnormally high toner density detected Black ATDC (auto toner density control circuit)
Replace black IU, check toner motors, make sure toner is loose not clumpy. Change dev reset toner level.
Thanks.
Mar 25, 2009 | Minolta DiALTA Di183 Copier
Problem in networking minolta di 520/620
do you have the optional print controller installed? if not you would need to buy one.
Jan 26, 2008 | Minolta DiALTA Di520 Laser Printer
Sharp AR-5320 Black and White Copier Logo
251 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
