Question about D-Link AirPlus DI-524 Wireless Router
Wireless only works in room where router is
DI-524 router is in the office of my home and this is the only room in the home I can get wireless signal. Taking laptop to next room disconnects me. How can I get the router to work throughout the entire home?
  • berly335 Feb 21, 2009
    And what is an extender and what does it do?
    thanks
    President:
  • 1,902 Answers
Get a extender at radioshack or local computer store. If your walls of your affice are concrete I would recommened that you more your wireless router out of that room and run a longer ethernet cable to help the signal out.
Posted on Feb 21, 2009
Choppy wireless signal of D-Link DI 524 Wireless Router
There are several problems that can cause you to lose wireless connection. Please click on this link and follow my instructions to help resolve this problem :-
http://www.fixya.com/support/r3559120-wireless_router_disconnecting
Jul 12, 2010 | D-Link DI 514 Wireless Router (DI-514)
D-Link DI-524 wireless router stopped working
You could spend $40 to have a qualified technician try to trouble-shoot, or you could spend $40 to buy a brand-new wireless-G replacement router. Your money; your choice.
Apr 16, 2010 | Office Equipment & Supplies
D-Link DI 524 behind VNC access remotely - Need help....
Open a browser and type in htp://192.168.0.1 to access your router's web management interface. Enter the username and password (default is username admin and no password)
Go to the Advanced Tab and Virtual Server
Name=VNC
Private IP=IP Address of your Home notebook
Protocol Type=TCP
Private Port=5800
Public Port=5800
Set Schedule as you like
Enable the rule and click Apply.
To access you Home notebook from anywhere other than your house, go to http://10.0.57.46:5800
Next - remote management of the router.
The IP address that you enter on the remote management page is the IP address that is allowed to connect to the remote management. If the 194.145.183.83 is the IP address of your office, this should work. Be sure you apply a password or anyone going to http://10.0.57.46 will have access to you router, I also recommend changing the port from 80 to 8080 so that http://10.0.57.46:8080 has to be typed to access the remote management interface.
Jan 02, 2009 | D-Link AirPlus DI-524 Wireless Router
Wireless signal offers sometimes & not many times
could be interference but have you tryed to reset the device? your settings will be lost? I supose you use a encryption so your going to have to enter it again to the settings.
Mar 25, 2008 | D-Link AirPlus DI-524 Wireless Router
Connecting a DI-524 to a DI-604
This shouldn't really be any problem simply use a short "Uplink" ethernet cable to join the routers thru the uplink port, or any port really, and that way ya should be able to wifi and access the net, set ya router that connects to the net for DCHP and disable that setting in the Wifi router and ya should be good to go?
Jan 30, 2008 | D-Link AirPlus DI-524 Wireless Router
DI-524 wireless router as wireless switch
You need to disable the DHCP server on your "slave" wireless router ( the di-524 ). In D-link routers this might be called configuring it to be an "Access point".
When this happens, connecting to the second wireless router should cause your computer to obtain an IP address which is in the range of the first router (that is to say, it will use the first router's dhcp server).
You should be able have your laptop connect with an automatic IP address and have it work.
Jan 24, 2008 | D-Link AirPlus DI-524 Wireless Router
DI 524 Router Not able to connect to office VPN on Wireless
I have the same model router at home, just checked the settings, you should be able to pass through the router with a normal vpn connection.
If you use a special VPN client, like a CheckPoint Secure VPN client, the router might block it. Also you might want to ask your office's sys admin if you are not blocked by the firewall or something similar. Your office's sys admin will prolly solve your problem since he knows your work network's configuration and setup and how to connect to it.
Nov 08, 2007 | D-Link AirPlus DI-524 Wireless Router
Router Configuration in "Wireless Client" Mode
Hi, If I understand you right, what you want to do is to make the DI-524 as a repeater, i.e. receive from the "external wireless access point" and re-broadcast to your "small home wireless LAN". Unfortunately, no. D-Link made it a point not to enable repeater mode in the DI-524 model (firmware has no support for wireless distribution service). Other than your old DWL-900AP+, one other model they have that can do this is the DWL-G710 but only in WiFi and not in the Ethernet port. On some other brands of similar feature models, the original manufacturer's firmware may be replaced with an open source firmware with more features enabled. An example is the LinkSys' WRT54G and the replacement firmwares by Sveasoft and another named DD-WRT. Hope this be of some information to you. Post back should you require additional information. Good luck and kind regards.
Sep 20, 2007 | D-Link AirPlus DI-524 Wireless Router
Problem with set up
it should be easy to set up unless it's faulty, it's a case of setting it up throug a web based menu through your internet browser; but to find instructions on how to set it up, you need to look underneath the extender for the version and then click on the link below:- http://www.dlink.co.uk/?go=jN7uAYLx/oIJaWVTALoeU8H8g50JcLpcX43jIuejxxi6E4R7gbckLJIhMa5i7DQlHA==
Jun 17, 2007 | D-Link AirPlus DI-524 Wireless Router
D-Link AirPlus DI-524 Wireless Router Logo
82 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
